TV reverts to 1024x768 when turned on - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 06-13-2012, 02:57 PM - Thread Starter
uthijacker's Avatar
Originally Posted by Sammy2 View Post
How long have you tested it now? I've had "other solutions" that worked for a few days only to have the resolution change rear it's ugly head again.
Did you put it between the HDTV (sync) and the AVR (source) or between the HTPC (source) and the AVR (sync)?
Mine is going on 2 weeks solid. My HDMI detective is between the HTPC (source) and the AVR (sync).
Make sure you dont do what i did, I programed it from the TV and it should have been programed from the AVR
uthijacker is offline
post #32 of 38 Old 06-13-2012, 06:40 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I thought you wanted to learn the EDID of the HDTV to lock the resolution. This solves the resolution issue where if you minimize WMC and then maximize it, it comes back at 1920x1080?
Sammy2 is offline
post #33 of 38 Old 06-14-2012, 07:41 AM - Thread Starter
uthijacker's Avatar
Exactly what i thought. But if you look at the picture below of my HTPC when it was programed to the EDID of the TV there were no encoded formats found.
So when the HDMI detective is programed to the AVR and not the TV, then all my encoded formats were shown (DTS-HD, TRUEHD...etc)
Yes, i always had to minimize to get 1920x1080 back. I have not had an issue since.
This picture shows my HDMI Detective programed to the TV and not the AVR. As you see, no encoded formats. It SHOULD be programed to the AVR, and the formats will show.
post #34 of 38 Old 06-14-2012, 07:43 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
This start up sequence in my H 900 seems to be working:
557
I know this is the third time I posted this but thought I should put it in all relative threads as there's at least two threads discussing this resolution change issue. This worked at least 10 times successivelly and again this morning after a 6 hour shutdown.
What this does is give time for HDMI sync to occur with a couple 5 second remote pauses and closes WMC (alt F4) and then loads it again in LiveTV. This replicates what I've been doing manually, although I minimize/maximize WMC and this closes it and opens it.
Sammy2 is offline
post #35 of 38 Old 06-14-2012, 07:47 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So do you have the HDMI connected from the HTPC to the TV or AVR? When I go to that screen I see my AVR not my TV.
Sammy2 is offline
post #36 of 38 Old 06-15-2012, 08:32 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Just wanted to add that I changed the Media Center PC2 to go to the MCE Startpage because if Windows Media Center was not already open, Alt F4 brings a pop up to shut down the computer. Although the original sequence was working, this new sequence removes the possibility that the computer will shut down when starting the Activity. Not that it won't due to some other reason but at least not due to the start up sequence programmed into the H 900.
Other than that this start up sequence is working well.
Sammy2 is offline
post #37 of 38 Old 06-16-2012, 07:02 AM
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
3.5 weeks. Two of those I was out of town and my parents (70s) were down watching our 4 year old. The used my HTPC setup without any issues! I consider that a big success biggrin.gif
xnappo
xnappo is offline
post #38 of 38 Old 06-16-2012, 04:38 PM
praz's Avatar
Liked: 26
7 months with the Detective Plus for me. I only wish this would have been the first method I tried.
praz is offline
Reply Home Theater Computers
