TV reverts to 1024x768 when turned on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 05-17-2012, 06:11 AM - Thread Starter
uthijacker's Avatar
I am trying to find out why this is happening. I have a Samsung 6300 series LED tv hooked to my HTPC via an Onkyo TX-SR605 via the onboard HDMI. Windows res. is set to 1920 x 1080.
It also does it when the HTPC is connected directly to the TV and not the receiver.
When turning off my tv and then back on, the TV shows 1080 for a second then reverts to 1024x768. All i have to do to get it back is minimize WMC7 and then maximize it back and 1080 is there. Anyone know how to fix this issue?
uthijacker is offline
post #2 of 38 Old 05-17-2012, 06:45 AM
tehowell's Avatar
You could try the Gefen HDMI Detective. Can be found for ~ $85. It helped with my equipment.
Samsung UN65JS8500 65" SUHD TV FW1455; Yamaha RX-A750BL Receiver FW1.77; Samsung UHD-K8500 UHD BD player, FW1005, w/dual HDMI; one to TV (video), one to AVR (bitstream); Arris DCX-3600M Cable STB; Nvidia Shield Android TV Update 3.2, Server: Windows 10 Home and Emby Server.
tehowell is offline
post #3 of 38 Old 05-17-2012, 11:11 AM
walford's Avatar
If you turn on the TV and the receiver before you turn on the PC does it work correctly?
Do you have WMC7 set to start on Boot? If yes try disabling it on boot.
walford is offline
post #4 of 38 Old 05-17-2012, 11:43 AM - Thread Starter
uthijacker's Avatar
I leave the HTPC on all the time. In order to get 1920x1080 I have to minimize the WMC7 to the desktop and then it catches hi-def, and then i maximize it back and im fine.
post #5 of 38 Old 05-17-2012, 12:00 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
I have the Onkyo 605 and an ATI-based 5450 and 5670 in my system. It does the same -- reverts the resolution to 1024x768 and the sound goes away too. Closing and opening WMC via the remote fixes the issue.
WAF is very low on the living room HTPC because of this.
StardogChampion is offline
post #6 of 38 Old 05-17-2012, 12:13 PM
xnappo's Avatar
Quoted: 89 Post(s)
Liked: 86
Here is what I did to fix it:
1. Install a VNC server on HTPC
2. Turn off monitor
3. Connect to HTPC from another computer using VNC client
4. Change resolution to 1080p
Fixed it for me..
xnappo
xnappo is offline
post #7 of 38 Old 05-17-2012, 12:28 PM - Thread Starter
uthijacker's Avatar
Im going to try this:
http://www.avsforum.com/avs-vb/showthread.php?t=1305280
And if that doesnt work i guess ill try a HDMI Detective.
post #8 of 38 Old 05-17-2012, 12:32 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Turn off your TV and Receiver
Remote onto the HTPC with Team-viewer or VNC
Change the VGA resolution to 1080p
Andy_Steb is offline
post #9 of 38 Old 05-17-2012, 12:36 PM - Thread Starter
uthijacker's Avatar
Ill give that a whirl tonight after i get home.
Can i remote in from another pc on the network and do it?
post #10 of 38 Old 05-17-2012, 12:46 PM
Quoted: 93 Post(s)
Liked: 160
BTW, what GPU are you using? Intel? AMD? Nvidia?
post #11 of 38 Old 05-17-2012, 12:54 PM - Thread Starter
uthijacker's Avatar
Onboard Intel HD3000
I3-2125
post #12 of 38 Old 05-17-2012, 12:56 PM
Quoted: 93 Post(s)
Liked: 160
My upstairs G620 system is hooked directly to my plasma and this doesn't happen. There's definitely some bad EDID thing going on when the AVR is turned off. I would give anything to be able to tell the GPU driver that this and only this is the resolution no matter what EDID says. It's so annoying.
There's also no way I am going to tell my wife and 6 y.o. to remote into the machine to fix it . That might work for us geeks but they're already annoyed enough as it is .
post #13 of 38 Old 05-17-2012, 01:03 PM
DeanM's Avatar
I have programmed my Harmony remote to always close Media Center (Alt+F4) when "shutting down" and to restart (GreenButton) when "turning on." This seems to avoid both this issue and the black screen issue. Don't know if you have a Harmony or other programmable remote, but it can be handy to keep the WAF high...
DeanM is offline
post #14 of 38 Old 05-17-2012, 01:04 PM - Thread Starter
uthijacker's Avatar
Is what they are saying is to remote in once, change it and its fixed?
post #15 of 38 Old 05-17-2012, 01:05 PM - Thread Starter
uthijacker's Avatar
Yes, I have a Harmony 650. I can not shut it down as i have a Ceton recording tv.
post #16 of 38 Old 05-17-2012, 01:09 PM
xnappo's Avatar
Quoted: 89 Post(s)
Liked: 86
Yes.
xnappo is offline
post #17 of 38 Old 05-17-2012, 01:20 PM - Thread Starter
uthijacker's Avatar
Ill remote in from my desktop and see if it will work.
post #18 of 38 Old 05-17-2012, 01:37 PM
DeanM's Avatar
Even when Media Center is not running, your recordings still continue/start/end independently. Recordings happen in a Windows "service", which runs unrelated to the Media Center user-interface.
DeanM is offline
post #19 of 38 Old 05-17-2012, 01:45 PM - Thread Starter
uthijacker's Avatar
Ahhh....didnt know that. If all else fails, ill look into this direction.
post #20 of 38 Old 05-17-2012, 02:33 PM
CFC
CFC's Avatar
I was about to point you to that thread.
It worked for me. Hope it fixes your issue as well.
CFC
Signature goes here
CFC is offline
post #21 of 38 Old 05-18-2012, 09:33 AM - Thread Starter
uthijacker's Avatar
So far nothing has worked. I am looking at the HDMI Detective.
Does it go between the HTPC & receiver?
post #22 of 38 Old 05-18-2012, 10:03 AM
praz's Avatar
Liked: 26
I've been through this same song and dance and sooner or later all these posted solutions have failed. I bought a HDMI Detective Plus last year and have had no issues since. Connect the output of the HTPC to the HDMI Detective and it will always see the EDID of the TV that you stored regardless of the state of the TV.
praz is offline
post #23 of 38 Old 05-18-2012, 10:05 AM
xnappo's Avatar
Quoted: 89 Post(s)
Liked: 86
Does this also help with HDMI audio? First channel I tune in the morning I always get 'No audio device available' then just tune something else and it starts working...
xnappo
xnappo is offline
post #24 of 38 Old 05-18-2012, 10:16 AM
robbo100's Avatar
I have two possible solutions to this problem listed in my MediaPortal Setup Guide: http://www.avsforum.com/avs-vb/showthread.php?t=1410346
See section 15.3 for instructions.
Robbo100
robbo100 is offline
post #25 of 38 Old 05-18-2012, 10:20 AM - Thread Starter
uthijacker's Avatar
Robbo100
But i am not using an ATI card. Its onboard Intel HD3000.
post #26 of 38 Old 05-18-2012, 10:31 AM
robbo100's Avatar
It is the same occurrence and it has been reported on intel cards too. I will change the wording in that section of the guide to make it clear that the problem exists on other cards.
robbo100 is offline
post #27 of 38 Old 05-18-2012, 10:38 AM
robbo100's Avatar
This method won't work because the problem occurs when the AV Receiver does it's HDMI switching. You need to pull the HDMI cable out of the PC to get the same effect - switching off the TV won't achieve this.
I have now tweaked my guide to make it applicable to all cards. The two solutions are two different methods, so if one works, you don't need to do the other.
Robbo100
robbo100 is offline
post #28 of 38 Old 05-19-2012, 01:52 AM
gonzo90017's Avatar
Quoted: 42 Post(s)
Might it have something to do with the screensaver? Have you tried disabling it?
Or I would recommend setting your computer to go to standby or hibernate after a set period of time. Then install StandbyHelper and configure it to close ehshell.exe just before it goes to sleep. This way your wife won't have to do it manually.
You can also set it to launch ehshell.exe to relaunch once it wakes up but you might end up with your original problem?
gonzo90017 is offline
post #29 of 38 Old 06-13-2012, 01:19 PM
xnappo's Avatar
Quoted: 89 Post(s)
Liked: 86
Add me to the list of people who gave in, bought the Geffen HDMI detective, and no longer have this problem.
Other stuff helped, but only the Geffen made all issues go away.
xnappo
xnappo is offline
post #30 of 38 Old 06-13-2012, 02:07 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
How long have you tested it now? I've had "other solutions" that worked for a few days only to have the resolution change rear it's ugly head again.
Did you put it between the HDTV (sync) and the AVR (source) or between the HTPC (source) and the AVR (sync)?
Sammy2 is offline
Reply Home Theater Computers
