Hdd maximum capacity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-21-2012, 01:39 AM - Thread Starter
dlyz's Avatar
Hi, I am planning to put my bdmv into my external western digital 3tb HDD. I plan to use this on my htpc via USB 3.0. I am planning to max out the HDD.
My HT/hifi dealer told me that he has customer who filled their HDD to the max capacity and end up their htpc couldn't read or write the HDD anymore. However they tried on a oppo player and the movie files were ok.
So wondering if I should max out my HDD or just leave around 10-20gb for safety. My dealer recommends 40gb. My bdmv range from 22gb to 70gb per file. I am one those who likes to use every drop of toothpaste if you know what I mean. So I feel like trying to max out the HDD but worried about spoiling it. This is my 1st 3tb HDD, but I have experience maxing out both int and ext 1tb HDD with no problems with anime and Asian dramas.
So hopefully someone can share with me their experience. Thanks in advance.
dlyz is offline
post #2 of 11 Old 05-21-2012, 03:25 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Hard drives can become excruciatingly slow when they are down to their last few dozen gigabytes. The data blocks for files and directories can be intertwined and scrambled. Note that XP defrag won't even try to defrag a disc with less than about 15% free space.
Yes, I've maxed out hard drives, but I wouldn't do it intentionally. In theory if you are patient enough, you should be able to at least get enough control of the drive to move out enough files so that the drive has reasonable performance.
arnyk is offline
post #3 of 11 Old 05-21-2012, 03:40 AM
Qaq
Qaq's Avatar
ATM my HTPC has few HDDs 0,5-2Tb with 200-700Mb free space. No problem with any read/write operations.
Burned by the Audio Inquisition
Qaq is offline
post #4 of 11 Old 05-21-2012, 03:59 AM
hirent's Avatar
I have maxed out some of my drives with less than 500 MB of space remaining; never had a problem.
As pointed out above, data can be physically located in different areas of the drive.
I would recommend defraging the drive at regular intervals (maybe every 500 GB or so).
hirent is offline
post #5 of 11 Old 05-21-2012, 05:06 AM - Thread Starter
dlyz's Avatar
This is a virgin drive with the sole purpose of storing my movies and I will never delete the movies. I won't defrag it either.
How big are the drives you guys mentioned? I also have 2 maxed out 1tb int HDD with less than 1gb to spare and they are working fine.
dlyz is offline
post #6 of 11 Old 05-21-2012, 05:30 AM
bryansj's Avatar
Quoted: 1421 Post(s)
Liked: 645
I hate to say this, but Geek Squad is probably a better source of info than a HT dealer when it comes to PC support.
I'm sure you will be fine until you can't cram another file onto the drive.
bryansj is online now
post #7 of 11 Old 05-21-2012, 08:24 AM
spivonious's Avatar
Why waste the space? I wouldn't max out your system drive (i.e. the one with the OS installed) but data drives should be able to go right to the last byte with no ill effects. I'd also choose the largest cluster size you can when formatting. It will give you a small performance gain for larger files.
spivonious is offline
post #8 of 11 Old 05-21-2012, 09:20 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I would mirror that 3Tb, since it will be excruciatingly painful to reimage all that data from backups... Also, run defrag to compact the data before you get to the maximum fill capacity.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #9 of 11 Old 05-21-2012, 09:32 AM
spivonious's Avatar
Mirroring does not protect against accidental deletions. Unless uptime is a big concern, I'd be comfortable doing only backups and foregoing any RAID solution.
post #10 of 11 Old 05-21-2012, 09:59 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
You are absolutely correct, redundancy does not protect against operator error, but then, the operator has no one to blame, other than the operator itself.
Up time may not be of significance in a home setting, but in our household, the file server holds all of the recorded TV, movies, music, and pictures content.
But, let me tell you, when the wife has all of her "real housewives", "chopped", "glee", and "bethany" on the server, and my daughter has all of her Elmo, Abby, and Zoey on the server, uptime becomes an absolute necessity, if one were to keep their sanity.
The Server, HTPC and associated media center extenders are THE ONLY "cable box/DVR" in the house. While I can still read books with Elmo and Abby to my daughter, reading the newspaper article about "chopped" or "Real housewives" does not seem to work with the wife....
So, RAID 5 it is, and back ups.
post #11 of 11 Old 05-22-2012, 04:14 PM - Thread Starter
dlyz's Avatar
Yea, I guess you guys are right. I also believe i should be able to max out the HDD. After I had another chat with my dealer, seem like it only happen once to 1 customer and not a few as I was previously led to believe..
dlyz is offline
Reply Home Theater Computers
