New Home Server - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-22-2012, 01:35 PM - Thread Starter
Bigmix's Avatar
Ok, I have held off long enough on this. I have been reading a lot on a home server, and I need something pretty fast. I am running out of room on my NAS and my movie shelf. I am also editing so many photos and graphics, it is hard to keep them orderly.
Here is what I need the machine for immediately:
1. Backup Pictures and other documents from other PCs and laptops.
2. Movie collection - Blurays, dvd rips.
I need to be able to:
1. Rip and encode (MKV, iso, mp4) to the server.
2. Back up pictures to RAID.
I would like my budget as close to $500-$700 (not including all the HDD)
Here is what I like so far (have not ordered):
Case- Ark 4U-500s
http://www.newegg.com/Product/Produc...82E16811128069
Optical - LG Black 12X Internal Blu-ray
http://www.newegg.com/Product/Produc...82E16827136246
Memory - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Produc...82E16820231314
PSU
http://www.newegg.com/Product/Produc...82E16817151095
Now the components I need help with:
OS Drive: Crucial M4 64GB or WD Scorpio Black 320GB
http://www.newegg.com/Product/Produc...82E16820148441
http://www.newegg.com/Product/Produc...82E16822136280
CPU - Phenom II X4 965 or Pentium G850
http://www.newegg.com/Product/Produc...82E16819103727
http://www.newegg.com/Product/Produc...82E16819116397
Motherboards - determined by CPU
ASROCK Z68 or ASROCK 880GM
http://www.newegg.com/Product/Produc...82E16813157292
http://www.newegg.com/Product/Produc...82E16813157271
OS - I have a copy of Windows 7, WHS 2011, and Windows Server 2008. Suggestions?
Flexraid or HighpointRocketraid 2720
http://www.newegg.com/Product/Produc...ketraid%202720
I am trying for the most economical system I can. I do not plan on running high intensity programs on here, but I am looking to serve HD files to two WD Live TV, 3 HTPCs, Laptop. I went rackmount on the case because of future home plans. Thanks for the input.
Bigmix is offline
post #2 of 21 Old 05-22-2012, 03:30 PM
flocko's Avatar
Sweet server build you have going there
Considering your budget , I think you have chosen some good parts .
Just a few suggestions :
1) I would go with a G620 . Will be plenty strong enough for a server .
2) I will proly get pawned for saying this but other than initial o.s. installation and a few other minor instances , an ssd is just not needed in a server . Savings right now would be about $80 .
3) I use whs 2011 with flexraid . Hands down love it for it's ease of use after it is properly set up . Or should I say lack of use . Once done , you will rarely touch it . Flex will also spin down the drives when not in use which is always a plus for power saving . Remember , most servers run 24/7 if you truly use it as intended .
I really can't comment on your selection of AMD items as I have refused to use them in any capacity since about 1995.
I also HIGHLY reccomend the below link for a great read prior to any purchases . Best info on the subject you will find
http://www.assassinserver.com/
Good luck and post back
flocko is offline
post #3 of 21 Old 05-22-2012, 06:26 PM
dksc318's Avatar
620W PSU is probably too much. Even it may be 80+bronze at 620W, could be poor at a more realistic 250-300W. Get a 300-400W 80+ PSU.
WHS 11 needs at least 160GB for OS. There may be a way to get around this such as install on a HDD then clone to SSD. So Win7 or WHS 2008 may be better.
dksc318 is offline
post #4 of 21 Old 05-22-2012, 06:36 PM
gregzoll's Avatar
Liked: 33
What you are needing, is some kind of content server for the pictures, or Photo Gallery Content Management server, so that you can better find them out there on the server or NAS that is holding them. Gallery server is one http://store.dotnetnuke.com/home/pro...server-pro-261 Here is a list of Linux Apps for Photo managers http://linuxappfinder.com/graphics/photomanagers Shotwell comes with Ubuntu now http://www.makeuseof.com/tag/shotwel...ment-software/
There are some others out there. If you are running Windows Home Server, it should already have a photo manager in it, which would be the best if you want to stick with windows, but with Linux, you have better control for being able to not be restricted to just one type of gallery server, or roll your own.
gregzoll is offline
post #5 of 21 Old 05-23-2012, 01:10 PM
StanF's Avatar
Are you doing the encoding "ON" the server or just storing the encoded file on the server?
If the latter, consider an HP Proliant Microserver like this:
http://www.newegg.com/Product/Produc...82E16859107052
This is the server that I have, and it is really great. Much, much better than my previous homebuilt server. Maybe not enough disc slots for you? And not rack mount...
Other thoughts:
I was an AMD fan for a long time, but Intel is really better value at this point. If buying new parts, go Intel.
That Rocketraid controller gets some really bad reviews...
Yes, to the M4 SSD for your boot drive.
Yes to WHS 2011
Consider Raid 1 or just using the Windows Disc Mirroring feature instead of the RocketRaid controller. A small penalty in usable space for greater simplicity
RAID will ideally use matched hard drives, and not WD Green drives...
Your post is missing details about your hard drives and total storage space needed, so some of my comments may not fit your needs...
StanF is offline
post #6 of 21 Old 05-23-2012, 01:17 PM
Zon2020's Avatar
If that's the case, you can get an Intel 330 180GB SSD for $139.99 after rebate at either Amazon or Newegg for the next few days. Would that be large enough?
Zon2020 is offline
post #7 of 21 Old 05-23-2012, 01:19 PM - Thread Starter
Bigmix's Avatar
I would want to encode on the server. If possible.
Probably not enough storage space. I have already filled 1TB and have not begun to touch the extent of movies I want at full capacity 30GB each. And the TV series. I finished "LOST" and that was a couple 100GB by itself!
The rackmount is more future planning. I will, (when ever I get to start my new house) , have a patch panel to rackmount, a couple of switches, some other shared resources, and theater equipment. All in a basement closet near the theater.
Bigmix is offline
post #8 of 21 Old 05-23-2012, 01:30 PM - Thread Starter
Bigmix's Avatar
1. Do you think the G620 will be powerful enough to encode?
2. It is hard to determine whether or not it makes a difference. You read threads and people go back and forth. When in doubt, go for the more economic choice, I guess.
3. I think that sounds great. Hard core server guys like hardware solutions, but I am all for simplicity.
Thanks for the link. It seems it is just pictures?
Bigmix is offline
post #9 of 21 Old 05-23-2012, 01:32 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
No. Much more than pictures. But not all free.
assassin is online now
post #10 of 21 Old 05-23-2012, 01:33 PM - Thread Starter
Bigmix's Avatar
1. I was worried about power when I got 6 storage drives in there. I found a 500W for 69.99, anything lower just did not have good ratings.
2. I want to keep this as simple as possible. I will just go with the 2.5 Scorpio Black and stick with WHS 2011.
Bigmix is offline
post #11 of 21 Old 05-23-2012, 01:43 PM
Zon2020's Avatar
Ratings from who? There are plenty of quality lower power PSUs.
If you want reliable information about PSUs, then read JonnyGURU.com or Tom's Hardware Power Supply Articles.
Zon2020 is offline
post #12 of 21 Old 05-23-2012, 01:47 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Or from people at AVS that have actually used them in a server/HTPC setting.
Even better.
post #13 of 21 Old 05-23-2012, 01:52 PM
Zon2020's Avatar
Even better.
Very true and an oversight in my response.
I was just hoping that the whole "there aren't any good PSUs less than 500w" wasn't based on Newegg stars.
As an aside, the SeaSonic S12II comes in a 380, 430 and 520, and you can't do much better than that.
Zon2020 is offline
post #14 of 21 Old 05-23-2012, 02:07 PM
jdmag00's Avatar
Fyi there are ways around this check google.
jdmag00 is offline
post #15 of 21 Old 05-23-2012, 04:10 PM
flocko's Avatar
#1 Yes or I would not have made that statement .
#2 I did not base my information or choice on economics . I made it on what I was told would be a wise choice for my server by a reputable member of this forum .
The server guides are worth 10 times the asking price . I , by nature am a very difficult person to please and set my expectations of other folks as high as i set them for myself. So when I say the server guides are a "steal" to purchase ... It aint no joke . I also feel the same about the htpc guides as well and have purchased them too . What is $25 on a $500.00 build ? Easy choice that's what !
Just FYI :
When you open the server blog guides that Assassin was nice enough to provide , The pictures of the server is mine . I was chosen by Assassin to assist him in supplying the parts and he did the actual build . We collaborated back and forth on the parts selection and quite frankly he kept me from making some choices that while not a disaster , were not the best decisions . I am not going to delve into the build as that would be un fair to him. I will say that you now may be able to see why I lead you the way I did
I will take a moment to Thank Assassin in public for his patience and dedication to our temporary partnership on this project. We had over 100 e-mails prior to building and he is a true professional and quite honestly a great internet pal
flocko is offline
post #16 of 21 Old 05-23-2012, 04:14 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Just FYI :
Wow, man. Thanks a lot.
You just made my day.
post #17 of 21 Old 05-23-2012, 04:20 PM
Zon2020's Avatar
Just FYI :
Wow, that sounds like a great experience. And after all the effort Assassin put in to protect your identity. . . .
Zon2020 is offline
post #18 of 21 Old 05-23-2012, 04:31 PM
flocko's Avatar
I had my reasons for protecting my identity during the project build . Yes, he completely respected my wishes the entire time . See what i mean ?
I did however ask his permission prior to giving up my identity as related to the build and he had no issue what so ever with my request .
The server is just flat out "KICK ASS " . It is with out exaggeration , the finest piece of computer equipment I have ever used ! and with out bragging , I have built some really intense systems.
flocko is offline
post #19 of 21 Old 05-23-2012, 05:55 PM
tomandbeth's Avatar
That is one heck of a nice server. Congratulations!
The thread detailing the construction, and subsequent Blog by Assassin, has inspired several others to make the plunge.
tomandbeth is offline
post #20 of 21 Old 05-24-2012, 02:13 PM
txmxer's Avatar
Quoted: 20 Post(s)
You are a lucky person. I read that thread the other day with great interest and was very impressed by what you received.
txmxer is offline
post #21 of 21 Old 05-26-2012, 08:00 AM
najames's Avatar
If you want to encode video, you may want to consider a i3 CPU so you can use Quicksync at some point. I haven't checked recently but don't think the Pentuim series has it.
Asrock has several motherboards with 8 Sata ports, wish I had one right now.
I bought a 400W FSP Aurum Gold power supply recently. It is very efficient and seems to work well so far in very limited use. When I bought on Newegg it was only $59.99, but after some good reviews they've jacked up the price a little bit. It has 4 sata connectors, can use molex to dual sata for more if needed. With an i3-2100, single 2.5" hard drive, 2 sticks of RAM, my old 330W Seasonics used 8W more at idle than the FSP, a newer 300W Seasonic Bronze used 3W more. FWIW I traditionally only buy Seasonic.
Comparison of systems using a Killawatt meter to measure wattage, all used the FSP setup as above, "onboard" graphics. Most CPUs were undervolted.
i3-2100 on Intel DH61WW - 18W idle (max on boot 48W)
i3-550 on Gigabyte H55M-S2H - 31W idle (max on boot 58W)
Sempron 140 unlocked (same watts with 1 or 2 cores) on Asus M4A785-M 35W idle (max on boot 48W)
Athlon 445 unlocked (same watts with 3 or 4 cores) on Asus M4A785-M 43W idle (max on boot 77W)
AMD Sempron system with one 2.5" OS drive and 5 Samsung 2TB drives with Win7 in power save mode uses 54W idle and maxes at 108W on startup.
AMD Sempron system was only about $35 for the CPU maybe $65 for the motherboard. Not all CPUs will unlock either, I just got lucky.
Another thing you might consider, although not mentioned, is getting a motherboard that supports VT-d virtualization. The VT-d CPUs are more expensive, not sure if you want one though.
My problem is software/file systems, I want a system that will run off a USB stick to conserve sata ports, but need Windows for Sagetv which will require another hard drive. I've tested Openfiler (didn't work), Freenas (required manual command configuration, menu settings didn't seem to "stick"), Nexentastor works ok using menus, kudos to them. Standard RAID or ZFS type systems will spin up all drives when writing so I am back to finding something that only spins up the drive in use grrrr, looks like either Linux with LVM and Snapraid or WHS 2011 + Drivepool + Snapraid. Might need to run 2 PCs for what I want.
Jim
najames is offline
Reply Home Theater Computers
