Need a good RAID NAS solution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-23-2012, 06:06 AM - Thread Starter
audioseduction's Avatar
Like to store my DVDs/blu-rays on to a 10-12TB RAID NAS. WHat do you recommand? Is there a better storage solution. I think BD are on avarage 35GB per movie.
audioseduction is offline
post #2 of 14 Old 05-23-2012, 06:45 AM
ljo000's Avatar
There was a recent thread on this topic with some good ideas:
Code:
http://www.avsforum.com/avs-vb/showthread.php?t=1411579
My advice is to build a FreeNAS server. Cheap hardware, free software, built in redundancy, fairly easy to set up. The biggest expense will be the drives ($50/TB )but you don't need to buy them all at once.
ljo000 is offline
post #3 of 14 Old 05-23-2012, 07:03 AM - Thread Starter
I was thinking of using a Drobo S load it up with 3TB drives.
post #4 of 14 Old 05-23-2012, 07:07 AM - Thread Starter
Code:
Looking for something simple, effective and reliable. Do not want to build a PC.
post #5 of 14 Old 05-23-2012, 07:31 AM
ljo000's Avatar
Home NAS solutions are way overpriced and underwhelming in features. If you don't want to build a server, get 4 bay enclosure and plug it into your existing PC via eSATA. Lots of good info on various options in this recent thread:
Code:
http://www.avsforum.com/avs-vb/showthread.php?t=1410553
An enclosure should set you back about $100 + HDDs. It would help if you provided a budget and what you're hoping to get out of the system.
ljo000 is offline
post #6 of 14 Old 05-23-2012, 07:40 AM - Thread Starter
Budget $1500. Like to relocate my blu-ray files from the HTPC to a dedicated storage device with at least 10TBs.
post #7 of 14 Old 05-23-2012, 08:01 AM
rockytt's Avatar
Man, there are probably 100 threads on this already...
Got an unRaid box myself with around 16tb of storage. Cost? About $200 in parts + a few bits lying around + drives. Dirt simple and very flexible (which was key for my setup)
There are others out that with different levels of speed and functionality, but I've been very pleased with the setup
If you don't want to build one yourself, I believe the guy at unRaid will build one for you...
rockytt is offline
post #8 of 14 Old 05-23-2012, 08:17 AM - Thread Starter
How about this?
Buffalo Technology DriveStation Quad 12 TB
post #9 of 14 Old 05-23-2012, 08:58 AM
gurkey's Avatar
Quoted: 113 Post(s)
Liked: 89
The best of the breed - looking at reviews , excluding the quite expensive high end business solutions - seem to be the Synology family of NAS, like the 212+ model or bigger, featuring i.e. a 2 GHz CPU and hardware-based on-the-fly encryption.
Different RAID options can be configured and a lot of protocols are been supported. Throughput seems to be excellent.
Depending on the model chosen it may provide a *lot* of storage really.
Check the manufacturers site for this http://www.synology.com/us/index.php
gurkey is offline
post #10 of 14 Old 05-23-2012, 09:03 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
There is at least one company that makes custom servers for HTPC.
That's what I would do.
assassin is online now
post #11 of 14 Old 05-23-2012, 09:16 AM
ljo000's Avatar
The Buffalo would work but you're essentially paying $430 for the enclosure ($1,030 - 4x $150 for the disks). For that price you could get a server that you could add more disks to later or use for all sorts of different things. Also keep in mind the Buffalo isn't a NAS. You would have to plug it into your PC.
If you go the enclosure route, I would recommend getting something cheaper and doing software raid.
ljo000 is offline
post #12 of 14 Old 05-23-2012, 09:26 AM
Gary Quiring's Avatar
I had very bad experiences with Buffalo. I forgot which one I had but you need their drives as the OS is on the drive. It ending up failing about 4 weeks after I bought it. Sent it back to Buffalo and they sat on the RMA for over a month.
I went with a TheCus N4100Pro. I liked it so much I now own three of them. They all have 2tb drives in them configured as RAID 5. The rebuild works easily, I had a drive failure and it was easy to hot swap a drive. The web interface is easy to use. They are not the fastest king of the road out there but to stream bluray rips and music with XBMC they work perfectly. I paid less than $400 for it and they support BYOD.
Gary Quiring is online now
post #13 of 14 Old 05-23-2012, 09:46 AM
Zon2020's Avatar
I think the Qnap are the equal of the Synology.
I've had the Qnap TS-412-US on my "one of these days" list for a while.
Zon2020 is offline
post #14 of 14 Old 05-23-2012, 01:51 PM - Thread Starter
After some research I decided to purchase a Drobo S Beyond RAID 5-Bay and 5 3TB 7200RPM drives. I plan to set it up as RAID 5 and attach it directory to my HTPC via firewire or USB 3.0. I decided I don't need it on the network.
Reply Home Theater Computers
