Video Connection Question-DVI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-23-2012, 12:28 PM - Thread Starter
brianlund186's Avatar
My son is trying to set up a quasi HTPC with a new Radeon card (Don't know which one). It has (1) DVI-I and (1) DVI-D out put and he wants to feed a Samsung HDTV with HDMI and VGA inputs and a new but not high end monitor. I'm not sure what the monitor in is but I'm assuming either DVI-D or DVI-A but it could be VGA. Exactly how would you cable this? please let me know if you need more info.
Brian
brianlund186 is offline
post #2 of 4 Old 05-23-2012, 01:10 PM
jdmag00's Avatar
I would get an dvi to hdmi cable, check monoprice.
jdmag00 is offline
post #3 of 4 Old 05-24-2012, 11:12 AM
sitlet's Avatar
Yes, HDMI and DVI can be converted using a simple cable adapter. DVI to VGA however cannot.
sitlet is offline
post #4 of 4 Old 05-24-2012, 11:17 AM
Zon2020's Avatar
Before you invest very much in convertors, you might consider getting a $20 video card that already has HDMI and VGA outputs.
What new Radeon card did he get that doesn't have HDMI?
Zon2020 is offline
Reply Home Theater Computers
