16GB or 32GB memory? Wich latency and speed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-24-2012, 10:16 AM - Thread Starter
LeandrodaFL's Avatar
Hey all, Im choosing the memory for a HTPC build. Im getting a H77 motherboard and a Ivy bridge intel graphics 4000 processor
The HTPC will be used for 720P and 1080i recording from TV shows and movie editing. I will not be gaming on this HTPC or using a videocard.
so, my questions:
1)Should I go with 16GB or max out 32GB? I may want to edit movies while recording in the background, and I dont know if 16GB is already enough
2)Regarding Latency, I've seen 7-8-8-24 and 9-9-9-24 timings. Should I go with the standart CL9 or get the CL7?
LeandrodaFL is offline
post #2 of 5 Old 05-24-2012, 10:26 AM
Zon2020's Avatar
so, my questions:
The right question is 4GB or 8GB, and the answer is, 4GB is plenty. Unless you're planning on running a 50-node Exchange server I can't imagine why 32GB would even enter your mind.
The answer is: it won't matter the slightest bit. Buy the 9.
By the way, the only way you're getting HD4000 video today is with an i5-3570K, which is several orders of magnitude more CPU than you need for your planned HTPC.
Zon2020 is offline
post #3 of 5 Old 05-24-2012, 01:51 PM
ctviggen's Avatar
Quoted: 119 Post(s)
Liked: 33
I have an i3 with the 3000 processor, and I does perfectly well with my dual use computer (HT and home). I can let the daughter watch movies on the 92 inch screen/projector while I work on the second monitor, with no problems whatsoever. I do not, however, do any gaming.
Bob
ctviggen is offline
post #4 of 5 Old 05-24-2012, 04:06 PM
idividebyzero's Avatar
Quoted: 42 Post(s)
4, I dont know why you think you need a workstation as an HTPC
Recording has virtually no effect on performance, when Im playing a game and the computer starts to record I dont even notice it.
idividebyzero is offline
post #5 of 5 Old 05-24-2012, 05:26 PM - Thread Starter
Thanksf or the reply, Im gonna get intel 4000hd anyways, but Im gonna wait for the batch of low tdp processors. I might in the futre add a videocard and do gaming
Reply Home Theater Computers
