Video Black Level - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-24-2012, 08:47 PM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I was checking out the video black level on my new build to see if it was OK. The HTPC has an ECS H61 mobo and Intel G620 CPU & is connected to a Sony HDTV via HDMI.
I used the THX Opimizer setup that was on a standard DVD & could not display the THX drop down shadow or more than 7 shades of gray/black no matter how I set the HDTV's black level / brightness. I went into the Intel Graphics properties & changed the Quantization Range from Limited to Full but it made no difference.
I used the same DVD on my Blu-ray player connected to the same HDMI connection on the HDTV and I can adjust the HDTV to display all 10 blocks of shades of black & the drop shadow. And IIRC my standard DVD player also would allow blacker-than-black.
The only variable is the HTPC. The 7 shades of black from the HTPC appear to match the 7 shades of black from the Blu-ray player with the HDTV properly adjusted. IOW I'm not losing anything from the HTPC.
But I am curious why the HTPC is not even able to output a B-T-B signal.
Is there another setting which controls that?
Mike99 is offline
post #2 of 5 Old 05-25-2012, 06:34 AM
mungee's Avatar
Since I posted a similar question a week ago.
Other than your TV, Graphic card, AV reciever (does not apply to your case), Graphics card settings there are also setting in the BD/DVD players software that you can tweek to get to "ideal black" and "ideal white".
Also you might want to invest in a decent video calibration software if you are that picky about video quality. I use Disney's World of Wonder HD there are a few others out there.
mungee is offline
post #3 of 5 Old 05-25-2012, 06:40 AM
Jon_R's Avatar
Could it be the output of PC range vs TV range?
0-255 (aka PC levels) and 16-235 (aka TV levels)
I'm new to hdmi having been on component for 5 years so it might not be relevant.
Jon_R is offline
post #4 of 5 Old 05-25-2012, 09:55 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I do have an Avia calibration DVD & do not have a problem displaying B-T-B with either of my two DVD players or the Blu-ray player. I don't recall the exact setting names & don't have the manuals in front of me at the moment, but all the players are setup to output the proper NTSC levels. They can all output B-T-B, but of course I don't have the HDTV calibrated for that. The HDTV is calibrated for the proper black level, at least as best as can be done with the calibration disc & other test patterns.
I do not want to display B-T-B with the HTPC, but am wondering why it cannot output such a signal. I an using the integrated Intel HD Graphics and am trying to find out what setting controls this.
Mike99 is offline
post #5 of 5 Old 05-25-2012, 10:09 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
That's probably it, but how do I control this?
My secondary concern is what happens when I display jpeg photos. Will the HTPC change the 0-255 to 16-235, and what happens to the photo black levels when this happens?
I can plug an SD card into my Blu-ray player & look at photos.
Is their color space being changed to TV's safe 16-235 colors?
Is this the correct process for viewing on an HDTV because it is expecting 16-235?
I think I'll put a few jpeg test patterns on an SD card & view them on the HDTV using the HTPC and Blu-ray player and see what the blacks look like.
Mike99 is offline
Reply Home Theater Computers
