Should I buy a Seagate external HD and crack it open, in order to harvest the HD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-26-2012, 11:56 AM - Thread Starter
randalthor's Avatar
Greetings,
I need to purchase a new hard drive to add to my HTPC. I would really prefer to add an internal HD to my computer, than use an external HD. I have 2 spots left in my HTPC that I can fill with internal HDs. I have previously been buying only Samsung 2TB internal HDs. I love them. I haven't had a single one die on me. Unfortunately, Samsung has been absorbed into Seagate. So even if I buy the same Samsung 2TB, I'm really buying a Seagate. Plus, I want to start buying either 3TB or 4TB hard drives instead. So I really have no choice but to try out either Seagate or Western Digital.
I have been looking at 4TB hard drives, and the prices are still terrible. The best price I can get is a Hitachi 4TB Deskstar Internal Hard Drive on J&R for $270; actually $255 if I use the coupon code: MEMORIALDAY. The code is good on all purchases of $150 and up at J&R.
But I can get a Seagate 4TB GoFlex Desk External Drive - Drive Only for $190 ($175 after coupon code). I was thinking about buying this and cracking it open to harvest the internal hard drive. I would then pop it into my HTPC and format it. My concern is that I don't know what hard drive is inside of this thing. There may even be two 2TB hard drives inside of it, for all I know. I'm also concerned about voiding the warranty. If the thing dies after I pop it open, I'm screwed. I pretty much have to pop this one open if I buy it, because I can't even use it as an external HD, unless I also buy a Seagate FreeAgent GoFlex Desk Desktop Adapter for it.
My other option is to buy a Seagate 4TB GoFlexDesk V2 USB 3.0 for $200 (185 after coupon code). Unlike the above HD, this one is ready to use as an external HD. So I was thinking about keeping it in it's enclosure at first. I would format the HD and then use it as an external HD for maybe 3 months. If it survives that long, I would then crack it open and use it as an internal HD. Or am I voiding it's warranty just by formatting it?
How hard is it to crack open these external HDs? And with the atrocious failure rate of hard drives, am I nuts to even be considering this? If I do go through with this, which hard drive should I buy?
"Here on the moon, our weekends are so advanced, they encompass the entire week." Ignignokt from Aqua Teen Hunger Force
randalthor is offline
post #2 of 2 Old 05-26-2012, 01:12 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
The drive contained within is just a standard drive. I have a GoFlex Home hooked up to my network (ATM I can't find the model of the disk inside) and it's just a standard 2TB drive. An advantage to the GoFlex line is the base can be used for any standard bare SATA drive (it just cradles right into it).
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home Theater Computers
