Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #361 of 2472 Old 07-18-2012, 05:58 PM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Originally Posted by Bryan Frederick View Post
Here's the info from my Xeon based one that I received last week:
Awesome, thanks for the pix. That's likely the one in mine too, it's also an Intel Xeon setup. Unfortunately I've not been able to find anything useful regarding that based on the part number. Nothing I've yet found breaks down the wiring from the dock to the motherboard.
I'm assuming there's a controller board under there? Any shot of getting pix or identifying numbers off it? Or is it just a pigtail of wires coming out of the dock chassis?
wkearney99 is offline
post #362 of 2472 Old 07-18-2012, 06:07 PM
potts.mike's Avatar
I have a core2 Quad Q 9400 with 4 GB of RAM in my current server. If I move to one of these new boxes how will it compare? It mostly serves files with Flexraid protection, does some home Automation stuff, and occasional blu ray transcoding.
potts.mike is offline
post #363 of 2472 Old 07-18-2012, 06:36 PM
mcturkey's Avatar
Liked: 43
The Xeons in these servers are pretty comparable - same architecture and core as the Core 2 series.
mcturkey is offline
post #364 of 2472 Old 07-18-2012, 06:39 PM
mcturkey's Avatar
Liked: 43
Unfortunately it seems that my old wiring harness has already been thrown out - I set the box of old parts that could not easily be reused/resold out in the garage and it looks like it has made it's way to the trash - doh! However, it was pretty much just a board with the PSU connections on one side and the mass of wires coming out the other side for connecting to the mobo/drives. I didn't spend a ton of time looking at it, but I did not notice any jumpers or easy way of modifying it.
mcturkey is offline
post #365 of 2472 Old 07-18-2012, 06:46 PM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Originally Posted by mcturkey View Post
Unfortunately it seems that my old wiring harness has already been thrown out .
Ah, no worries, thanks for the follow up. I may end up rearranging some of my gear to move this motherboard into another chassis. So while I'm in there I'll be able to get at the PSU guts. But not before next week, at the earliest.
post #366 of 2472 Old 07-18-2012, 08:01 PM
potts.mike's Avatar
I was under the impression the new batch has an older AMD opteron in it.
One other thing, If I am reading the specs right there should be 6 extra sata ports that aren't used for the drives?
post #367 of 2472 Old 07-19-2012, 04:00 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Depends on what you're trying to do. Some comparisons to consider:
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Core2+Quad+Q9400+%40+2.66GHz
http://www.cpubenchmark.net/multi_cpu.html
From the looks of it the previous Xeon setups upgraded to dual quad cores would be pretty good, the out of the box single wouldn't. Looks like the AMD setup in the new deal seems like it'd come in pretty underpowered in comparison. You could certainly upgrade just the CPUs to improve upon that. But then you'd still need to be using software that understands how to best take advantage of all those cores.
The deal here is in the case setup, not so much the components within it.
post #368 of 2472 Old 07-19-2012, 08:18 AM
Bryan Frederick's Avatar
Yes there are 6 sata ports on the motherboard of the box I received that are not in use. I am using one of them for the OS drive to leave all 24 bays open.
Bryan Frederick is offline
post #369 of 2472 Old 07-19-2012, 08:19 AM
From the psu to the motherboard is just your standard ATX power cables- nothing crazy there.
post #370 of 2472 Old 07-19-2012, 09:46 AM
bima's Avatar
well, you can look on http://www.avsforum.com/t/1412640/are-you-looking-for-a-less-expensive-norco-4220-4224-alternative/270#post_22213517
there is a pdf link, open the pdf link and you will find some of your questions.
in PDF. you can have on cables/pins explanation, for example. reset/atx cables/failed/buzzer/others.
But.
you can not find PSU module module specification.
the docking is pretty well explain in the pdf file
I guess, you need to find PSU module to look in detail.
You will see in the docking part as follows:
1) power distribution
2) a controller to maintain PSU modules and failed situation
3) SMBus/I2c where link to onboard controller to external I2C (your mobo that came with the server case has it)
bima is offline
post #371 of 2472 Old 07-19-2012, 10:03 AM - Thread Starter
Litlgi74's Avatar
I got some late news yesterday from Jason at TAMSolutions...
They got an unexpected shipment of servers from another customer... this time they are 2U
So if you really don't need a 24 drive server and would prefer the smaller form factor of a 12 drive setup... one of these these machines maybe perfect for you...
The Specs I know:
Supermicro Server Case SC826
Supermicro X7SBE
(1) AOC-SAT2-MV8
Intel Core 2 Duo CPU
I will update as soon as I know more...
The world ends when you're dead. Until then, you got more punishment in store. Stand it like a man -- and give some back.
~ Swearengen
Litlgi74 is offline
post #372 of 2472 Old 07-19-2012, 10:26 AM
Biggrich76's Avatar
If I am able to get in on the next batch I'm considering upgrading to one the below options;
Dual Opteron 2419 Six Core @ 1.8 GHz
or
Dual Opteron 2384 Quad Core @ 2.70 GHz
This will be my first official home 'server', I'm currently using a mixture of NAS and external drives attached to my main rig. The server will be used for storing my media collection, transcoding MKVs and hosting game / voice server(s). I would like to have maximum performance but I am also somewhat concerned with power draw. I'm sure the 900w PSUs and 10 drives will already be hammering my electric bill so I'm looking for recommendations on a good price / performance / power consumption balance. Thanks in advance.
XBL: Drunkn Joker
Biggrich76 is offline
post #373 of 2472 Old 07-19-2012, 10:31 AM - Thread Starter
Litlgi74's Avatar
or
I would try the single CPU the server comes with first... if it meets your needs... Save your money! biggrin.gif If not then go for a second CPU.
I doubt very much you will ever come close to 900w... At idle with 16 (always spinning) drives installed... my server is at around 200w.
Using a software RAID to access on the drive needed will help limit your power consumption... as apposed to a RAID 5,6,10 which accesses all the drives all the time.
~ Swearengen
Litlgi74 is offline
post #374 of 2472 Old 07-19-2012, 11:24 AM
Biggrich76's Avatar
Makes sense, thanks. I was just noticing that CPU upgrades are pretty cheap via Fleabay, and of course I love to tinker with things. wink.gif
I was planning on going with WHS and FlexRaid for the drive pooling and parity drives for backups. I'm guessing FlexRaid will follow the WHS power saving rules and power down drives not in use.
XBL: Drunkn Joker
post #375 of 2472 Old 07-19-2012, 11:34 AM - Thread Starter
Litlgi74's Avatar
No Problem...
Just an FYI... The CPUs can be found pretty cheap but not necessarily the HSF.
Also... I would check out SnapRAID prior to purchasing FlexRAID...Don't get me wrong FlexRAID is great... but SnapRAID is FREE!!!
Why do you need to drive pool? Killroy got me setup using JBOD... and I haven't looked back.
You are correct about the WHS power savings rules.
~ Swearengen
Litlgi74 is offline
post #376 of 2472 Old 07-19-2012, 12:55 PM
Biggrich76's Avatar
No Problem...
I figured I could pick up a pair of CPUs + HSFs for under $100, and that would give me a significant performance boost. But I will see how it works "out of the box" first before I go spending more money. The Steam Summer Sale has already put a hurt on my wallet this week.
I've been looking at several options for getting my drives all in one place, and FlexRaid seemed to have the most user-friendly GUI and provided a good level of parity in case of drive failure(s). I also use YAMJ to server media to a couple boxes, and it's easier to configure with a single media path (ie. pooling). I'm certainly open to ideas and suggestions for keeping things low budget though!
XBL: Drunkn Joker
post #377 of 2472 Old 07-19-2012, 01:13 PM - Thread Starter
Litlgi74's Avatar
I am using a Dune HD Media player with yadis as the jukebox... Killroy also taught me another trick:
Mounting a drive to an NTFS folder
This is quite a nice feature to allow access of multiple drives in one folder/location.
Here's a photo of how mine is setup:
~ Swearengen
Litlgi74 is offline
post #378 of 2472 Old 07-19-2012, 01:33 PM
bima's Avatar
or
if your concern on power consuming for multipurpose server (NAS/Trans/other tasks), you should stick with Xeon 54XX or 55XX:) series
opteron 24XX eats more power consumption and less powerhorse comparing with xeon 54XXX
if you prefer to stick with "old" style: pick Xeon L54XX and motherboard with chipset 5100 or 5410 ( it is ok with 5000, if you can get pretty cheap. hmm..40 bucks)
bima is offline
post #379 of 2472 Old 07-19-2012, 01:41 PM
bima's Avatar
mine is around 260W with dual Xeon L5410, non-green 10 HDs ( 2 Drives for esxi datastorage)..
it would jump to 260-310W, when runnning vmware+OI VM with 8 Drives+ ubuntu (with plex) VM.
if anyone to utilize 2U server, better to have a seperate room server/cabinet :P
1U and 2U iserver will generate much noise than 3U or 4U. this is hard to silent down the noise due on space limitation
I would say, good luck!!!
bima is offline
post #380 of 2472 Old 07-20-2012, 07:19 AM
JGFreeh's Avatar
It's also nice as a power-saving feature, because it keeps the drives from spinning up every time you open up My Computer or explorer.
JGFreeh is offline
post #381 of 2472 Old 07-20-2012, 09:40 PM
rsmclay's Avatar
OK everyone, question for you. Where can I get motherboard stand offs? In the past I would have went to CompUSA, but they went out of business. Does Best Buy, or some place like that, sell these? I would rather buy locally, rather than waiting for an online place, if at all possible. If not, where did you guys buy them online?
Thanks!!!
rsmclay is offline
post #382 of 2472 Old 07-20-2012, 11:50 PM - Thread Starter
Litlgi74's Avatar
Thanks!!!
Try a local, independent PC repair shop... I bet they will just give them two you.
~ Swearengen
Litlgi74 is offline
post #383 of 2472 Old 07-21-2012, 04:52 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Or places like microcenter:
http://www.microcenter.com/single_product_results.phtml?product_id=0218465
http://www.microcenter.com/single_product_results.phtml?product_id=0260739
I almost never run out of screws because I scavenge all of them from any PC that's getting thrown out. Or from just about anything else getting disposed of.
post #384 of 2472 Old 07-24-2012, 06:19 PM
Z-95's Avatar
My home lab is coming along!
(Really need to use my real camera next time).
Specs:
Modded AIC 4U 24-bay case (modded to accept an ATX PSU and quiet fans)
Supermicro X9DRI-F
2x Intel E5-2620 6-core CPUs
32GB DDR3 EEC RAM
3x IBM M1015 flashed to IT for the 24 bays
Its purpose will be an ESXi all-in-one router/firewall, NAS, DB, HTTP, VPN, media, and whatever else I want to throw on there. Just waiting for Amazon to get some 3TB WD Reds in stock (direct from Amazon) to fill half of the bays (12) to start.
Litlgi74 likes this.
Z-95 is offline
post #385 of 2472 Old 07-24-2012, 06:59 PM
fzdog2's Avatar
Quoted: 16 Post(s)
Specs:
Supermicro X9DRI-F
32GB DDR3 EEC RAM
Dang thats pretty close to what I'm planning on getting mine to.
fzdog2 is offline
post #386 of 2472 Old 07-24-2012, 08:03 PM - Thread Starter
Litlgi74's Avatar
Specs:
Supermicro X9DRI-F
32GB DDR3 EEC RAM
Looks sweet!
Can we see the inside?
~ Swearengen
Litlgi74 is offline
post #387 of 2472 Old 07-24-2012, 09:56 PM
Z-95's Avatar
Took some better pics with a real camera:
Z-95 is offline
post #388 of 2472 Old 07-24-2012, 10:00 PM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
This is quite interesting, i have a similar setup, but how does this work for scrapping tv folders and movie folders on a single drive. Each one of my drives has a tv and movie folder.
Wont you still need to setup each as tv and movie folder so it users the correct scraper?
Murilo is offline
post #389 of 2472 Old 07-24-2012, 10:11 PM - Thread Starter
Litlgi74's Avatar
Originally Posted by Murilo View Post
This is quite interesting, i have a similar setup, but how does this work for scrapping tv folders and movie folders?
Here is my Yadis... setup...
The main reason I did this is because my Dune player can only have one SMB share open at a time...
~ Swearengen
Litlgi74 is offline
post #390 of 2472 Old 07-24-2012, 10:26 PM - Thread Starter
Litlgi74's Avatar
Thanks for the added pictures...
I like how you mounted your SSD. Did you reuse the internal HDD hardware?
I am curious about your fan wall... it looks like you don't have a gap between the side of the case and the fan wall... How did you manage that?
~ Swearengen
Litlgi74 is offline
Reply Home Theater Computers
Norco Rpc 4020 4u Rackmount Server Chassis W 20 Hot Swappable Sata Sas Drive Bays , Norco
