Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative? - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #2341 of 2472 Old 12-01-2014, 11:48 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Originally Posted by onyxbfly View Post
Yeah you are right the SQ models are are rather pricey. The cheapest I have seen them is $200ish. I haven't seen the PWS-920P-1R for less than $150. Feel free to share where you found them between $70-$90
Ebay haha, but looks like the seller I bought 2 from sold out. Seems like it's still around $80-$100 with shipping for the few on eBay currently
rc05 is online now
post #2342 of 2472 Old 12-01-2014, 11:50 AM
onyxbfly's Avatar
Quoted: 49 Post(s)
Thanks for the heads up.... I completely forgot to check eBay!
onyxbfly is online now
post #2343 of 2472 Old 12-01-2014, 12:06 PM
onyxbfly's Avatar
Quoted: 49 Post(s)
Found some on the bay. Now the million dollar question is if the difference between the PWS-920P-1R and PWS-920P-SQ with quite mode is worth extra $100+ per PSU. The original PSU PWS-902-1R sounds like your getting a hair cut with a vacuum cleaner instead of clippers.
post #2344 of 2472 Old 12-01-2014, 12:35 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
I had the PWS-902-1R and replaced it with the PWS-920P-1R. The PWS-920P-1R wasn't as quiet as I thought it was going to be, but it's still much quieter than the PWS-902-1R. I can't hear it from the other room anymore, and I can sit next to it too! It sounds like a medium size fan blowing I guess. I haven't tried the -SQ model since it's much more expensive.
onyxbfly likes this.
rc05 is online now
post #2345 of 2472 Old 12-01-2014, 12:56 PM
onyxbfly's Avatar
Quoted: 49 Post(s)
Anything has to sound better than a jet taking off in your ear. Thanks for your honest review. I'm on the fence but the boss aka my pocket is leaning towards the PWS-920P-1R. Its really hard not to choose the PWS-920P-1R. The SQ models are 2.5 x the price of the 920p. I would need to get 2.5 X the experience for that price LOL. Thanks once again!!
post #2346 of 2472 Old 12-02-2014, 10:25 AM
cantalup's Avatar
SQ is more quite. and this is the newest model from supermicro and 80 platinum( as you mentioned).
you can search 1K2P which is very low noise when loaded below 30%.
the key is PWM fans, only OLD supermicro server is using non PWM fans.
as I know, if you are using 920P within 30% range (~250W), the fan will running low with air pressured noise.
cantalup is offline
post #2347 of 2472 Old 12-02-2014, 11:15 AM
cantalup's Avatar
get 1K2P than 920P, if the cost is negligible.
cantalup is offline
post #2348 of 2472 Old 12-02-2014, 12:27 PM
onyxbfly's Avatar
Quoted: 49 Post(s)
If I could hear the difference between the PWS-920P-1R and PWS-920P-SQ, it would really help with the process. I was not aware that the fans in the PSU were PWM.
2*PWS-920P-SQ cost ~$400 and 2*PWS-920P-1R cost ~$160 That'sa big difference in price. are you currently using the PWS-920P-SQ?
post #2349 of 2472 Old 12-02-2014, 01:27 PM
cantalup's Avatar
Not on SQ. some member on serverthehome and hardforum forums have that. pricey but worthed it you need "quite" PSU
you need just one for home user . P-SQ is less fan noise that P. SQ-> supermicro style of Super Quite ().
I have 920P and 1K21P, this is depend on the load. < 30% fan run low rpm (thanks for PWM fan).
the best home user for low rpm fan running is using 10%-15% maximal of watt. EX: maximal usage is ~150W for 920P, or ~180W for 1K2P. I am assuming that no temperature control aka AC involved in home user, which room/house temperature will has fluctuation down and up.
you will know whay supermicro put "P" aka PWM :P...
ditch out old PSU that high noise fan (non PWM) and non efficient power usage.
Pick 920P or 1K21P, I prefer 1K21P where the price difference is minimal on ebay( 2 weeks ago).
P is 80 gold
P-SQ is 80 platinum where more effiecent than P.
you can not compare quiteness with desktop PSU, Such as: seasonic 750W X or other mid to high desktop PSU.
desktop PSU is more quite than server psu.
1k21P -> www. ebay. com/itm/POWER-SUPPLY-SUPERMICRO-PWS-1K21P-1R-SWITCHING-1200W-SERVER-POWER-SUPPLY-1U-/171530599475?pt=US_Server_Power_Supplies&hash=item 27f0053c33
$25+22 shipping .
cantalup is offline
post #2350 of 2472 Old 12-02-2014, 02:56 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Huh I should have gotten some of those lol
rc05 is online now
post #2351 of 2472 Old 12-02-2014, 09:43 PM
thomps33's Avatar
Well, I bit the bullet and picked up one of these. http://www.ebay.com/itm/171528374048...%3AMEBIDX%3AIT It's more than I wanted to spend, but it should be overkill for the application and I can upgrade the CPU's to Xeon X5670 if I need more horsepower in the future.
The goal is to make it as quiet as possible. I'll be replacing all the fans and the PSU. Does anybody have recommendations for fans and a PSU? I plan on replacing fan wall with 140mm fans. I was thinking of this PSU, http://www.newegg.com/Product/Produc...82E16817151087 Good? Better options out there?
Need to decide on an OS, software raid, hdd's (greens vs reds?), etcetera... Choices, choice, choices All ready over my head. I'll have lots of questions in the future! Thanks for any advice.
thomps33 is offline
post #2352 of 2472 Old 12-03-2014, 12:52 AM
cantalup's Avatar
you bought 4U supermicro with sas1 expander :|.
sas1 expander mostly cause headache when so many sata drives are booting up all together.
I have sas1 expander that cause some sata drives are not recognized during booting up. I took off exapnder sas1, and use two perc H200 as end result. mucho problemo on sas1 expander.
if you want to buy: sas2 expander(working nicely with SAS and SATA drives), non expander.
check on this to know better:
https://forums.servethehome.com/inde...res-woes.3646/
as my memory serves me well, you would get only 1.5gb sata transfer rate on sas1 expander. sas drive would get 3gb transfer rate.
PSU that you linked is very good candidate.
cantalup is offline
post #2353 of 2472 Old 12-03-2014, 02:53 AM
thomps33's Avatar
Well, that's a bummer. I knew sas was backwards compatable with sata but I wasn't aware of the sas2. I just looked at the specs of the sas expander and it said it supported sata drives so I was a happy camper. It looks like they fixed the reliability of the sas expander using sata drives? Is 1.5 Gbs a limiting factor?
I looked at the sas2 expander and they are not cheap! I was hoping to use the sas expander backplane to reduce the amount of wires going in the case...now I may get a refund and look elsewhere.
By the way. Thanks for pointing that out! Just goes to show how much I have to learn!
thomps33 is offline
post #2354 of 2472 Old 12-03-2014, 08:17 AM
onyxbfly's Avatar
Quoted: 49 Post(s)
P is 80 gold
$25+22 shipping .
I had no clue about the PWS-1K21P-1R. After s/h they are just about the price of one PWS-920P-1R. Thanks for the info!
LOL Wait a few more days and someone will put us on to something even better LOL
post #2355 of 2472 Old 12-03-2014, 09:31 AM
cantalup's Avatar
there is always better deal haha....
Supermicro parts are easy to find on ebay.
just go to supermicro site, search the parts model and number, dig-in technical detail, search on forums, and start hunting on ebay
1K21P, is very quite for me, as long as <=20% load. the same situation on 920P when loaded with 20% usage
But.. can not be compare with desktop PSU, such as 750W seasonic semi modular.
people are hunting 920P and forget 1K21P.
same as past years with IBM M1015. some seller with many card were selling cheap!!. I missed that opportunity
at last settled with $60 price range. If more than 60, means not good price for me!
bought M1015 each $60 including shipping for two, and perc H200 each $60 for two including shipping too.
cantalup is offline
post #2356 of 2472 Old 12-03-2014, 09:46 AM
cantalup's Avatar
the last option is replacing backplane with sas2 or non expander version
sas2 expander backplane is pricey on ebay as I checked lastweek $200-$300, those sellers throw a bait:P
no-expander could be less than sas2 expander.
Totaly true, expander will reduces hay-wiring that only need one or two mini-sas forward/straight cable.
if you are interested, pick 3U 16 bays supermicro with dual 1k21P PSU, you just need to replace internal fans with pwm since the original fans makes high pitch noise (on my ears).
that case is getting popular -> http://www.ebay.com/itm/3U-Supermicr...item20f1907c04
I bought it 2 weeks ago, and receieved yesterday. $300(bestprice)+$50 shipping.
I check on serve...home forum. the seller firmed on $315 since unloading on ebay is easy;due on sas2 expander.
backplane has 2 x sas2 expander. you can do single(cover all 16 bays) or dual (cover 8 bays for each sas2 expander, with total 16 bays).
Doing transplanting TS140 i3 model to the supermicro case to replace my old setup with braking hot-swap rack.
good luck
please remember, if not sas2 expander, just forget it.
cantalup is offline
post #2357 of 2472 Old 12-03-2014, 10:29 AM
onyxbfly's Avatar
Quoted: 49 Post(s)
Have you consider plugging the fans directly to the mobo instead of the fan wall header? If you plug the fans into the mobo you should be able to use PWM to quite them down some?
post #2358 of 2472 Old 12-03-2014, 10:31 AM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
The thread you linked from servethehome concludes your issue was related to lsi raid firmware and has since been fixed. Also it would appear to be a non issue with a card using "it" firmware. As far as speed concerns, I also feel that is invalid. If you are using something like flexraid you are bottlenecked by the drives not the controller. Someone using zfs should probably get a sas2 backplane, but I think there are better alternatives for home use anyways.
berstuck is offline
post #2359 of 2472 Old 12-03-2014, 03:21 PM
cantalup's Avatar
reread again, sas1 is the issue..
there was thread on hardforum too years back.
I still have one sas1 expander lsi (chenbro) that acts identical with the symptom in the link that I gave,
I tested (M1015 and perc H200) IT and IR, nada result,
including adaptec 3 series.
the problem no vendor want to update sas1 expander firmware, since already discontinued,
try yourself.....
sorry, I am a linux guy when talking server related :P,
if you happy with 1.5Gb speed, it is up to you.
but random missing drives during booting?
if you read sas2 expander chips tech doc, they put extra features that missing in sas1 expander chips
all I can say:
I already let you know from my experience, if you do not care, nothing to worry about
cantalup is offline
post #2360 of 2472 Old 12-03-2014, 03:25 PM
cantalup's Avatar
doable.
server fans is a beast . still generate pitch noise when running low.
this makes sense, since server fans pull a lot of pressure even in low rpm
there are 3 front fans, and 2 front fans, the easy way is using 2 pwm controllers for front and back.
this is the third time buying server cases.
1 4U AIC
1 4U supermicro
1 3U supermicro with sas2 expander.
the first two were heavily modded with desktop fans and good desktop psu.
I do not have time much, will use pwm controller or replace with good desktop fans.
for the record:
if you planning buying "non-server" 5x3.5 raid cage. please do not buy. mine is breaking and inside connector getting loose aka do not touch the server while running. Case is rosewill 4U with 3 of 5X3.5 raid cage, the server has been with am2 sempron with ddr2 ecc unbuffer.
this is the reason I bought the third real server case with hot-swap and transplating ts140 i3 motherboard to supermicro.
cantalup is offline
post #2361 of 2472 Old 12-03-2014, 06:55 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
try yourself.....
all I can say:
Not to be a jerk, but you might want to reread that thread you linked. A member there clearly states that lsi has updated firmware on the 9260, and 9240 to fix the issues with the sas1 expanders. Clearly it will be slower than sas2, but as I mentioned that won't matter to flexraid users. No one wants to deal with unforseen problems so it's good that you posted your experience. But scaring people away from cheap hardware that might be a better fit for their needs seems silly. Right now supermicro cases with sas2 backplanes are rare on ebay. Sas1 is everywhere and cheap. If there were more sas2 options available on the second hand market it would be a no brainer.
berstuck is offline
post #2362 of 2472 Old 12-04-2014, 06:55 AM
cantalup's Avatar
not to be a jerk too, am I
I try to help everyone to avoid unneeded steps, since has been doing almost 3 build server.
and
NOT scaring everyone, as I said nothing to worry about in my post!
please reread my posting that based on my experience.
I DO have sas1 expander sitting on my desk, two M1015, and two H200 that based on lsi chipset
H200 flashed with HBA 6G dellizer,
M1015 flashed with newest LSI firmware as today.
and rebuilding a server to replace my old server
did you follow my posting about 3U 16 bay sas2 expander? that is pretty cheap...
No excuse to blame on the cost..
well, check on hardforum too,
I posted serve... link since on my bookmark.
my suggestion as on my previous post, avoid sas1 expander, better buy non expander, which mostly the same price as sas1 expander version.
this is my last reply to this matter, do not want trashing this thread.
I am just letting everyone decide for a long run to pick his/her own decision.
cantalup is offline
post #2363 of 2472 Old 12-08-2014, 10:01 PM
AVTechMan's Avatar
Quoted: 31 Post(s)
Liked: 37
In my Supermicro 24-bay chassis that I gotten from TAMS sometime ago, I am considering replacing the AMD based H8HME-2 motherboard and the PCI-X SATA MV8 controller cards. I could get another server board or a consumer level board to replace the existing one, but would have to support PXE network booting as I have WDS setup now on the Server 2012 R2 VM. Thing is, since the backplane of the case has the individual SATA connections, what's a good controller card that's possible SAS with the SATA connectors for all 24 bays? I'm also wondering if any mods would be needed to fit an micro-ATX or ATX board in that chassis with the original back window? I could search on the pasts posts on this thread but have no time to search tonight.
This server will just be a file server loaded with an OS, with Drivepool and Flexraid since I still have both those licenses unused right now. No transcoding will be done on this box since my ESXi Win7 VM till take care of that running the Xeon 1230 V2.
As for the chassis, it still has the original PSU's (one replaced with the 920-R sometime ago) so I don't really plan to replace them either. The original fans I have a fan controller to turn those down to a manageable noise level.
What's a good controller card to replace the MV8's, and drivers that supports Windows OS?
AVTechMan is offline
post #2364 of 2472 Old 12-09-2014, 01:11 PM
cantalup's Avatar
do you need to replace motherboard and sata/sas card? just try to understand.
cantalup is offline
post #2365 of 2472 Old 12-22-2014, 08:54 PM
golf7's Avatar
Very new to the SAS/JBOD world. I have been looking for a way to increase the capacity of my setup. I run windows 7 (i7 4790K, 32 GB RAM, Asus z97-PRO Mobo) and currently have a RAID5 Hardware array in an external USB enclosure, but that is being filled very quickly. I also have multiple HDDs internal to the tower that are used as mirrors for important files.
I want a way to be able to add disks or replace them with higher capacity disks if I ever want to expand the storage, while still having protection and pooling that RAID5 brings.
I have decided on this setup, and let me know if there are any problems with it:
- FlexRaid tRAID for the Pooling and Parity (I realize its slower, but I feel more confident on real-time raid than snapshot raid)
- SGI SE3016 JBOD Enclosure
http://www.ebay.com/itm/Rackable-Sys...item58b7ed85f1
- IBM ServeRAID M1015 Controller
http://www.ebay.com/itm/IBM-SERVERAI...item20f2fa7655
I have a couple questions:
1) Will this setup support 6TB HDDS (Looking at HGST Deskstar NAS)? If not, what is the size limit?
2) Will I need any additional hardware to implement this setup on my current Windows 7 box? (There are many open PCI slots)
3) Would there be a problem for running the external SAS from the JBOD to the internal SAS connections on the M1015 ?
4) What other cables would I need to connect everything? (mini-SAS cables, sata cables, power cables?)
5) How would I go about configuring the M1015 to see all the drives, and will SMART Data be available to the OS?
Thanks for the help. If there are other suggestions in the same ~$250-300 price range overall for a quieter system, even if its 8 slot, I am all for recommendations.
golf7 is offline
post #2366 of 2472 Old 12-22-2014, 09:14 PM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
I'd suggest getting an internal to external SAS adapter like this (or this if you plan on expanding)
Then you'll need an internal SFF-8087 cable to go from the card to the bracket, and then a SFF-8088 cable to go from the bracket to the external enclosure.
Other than that it looks like you're all set.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #2367 of 2472 Old 12-23-2014, 05:21 AM
golf7's Avatar
What about >4tb support and smart data ?
And will the controller I chose support all 16 drives since the jbod had a built in expander ?
golf7 is offline
post #2368 of 2472 Old 12-23-2014, 06:02 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
I'm assuming you'll be flashing your ServerRAID card to operate as a standard HBA as that's what nearly everyone on here has done with their's (at least when using it with FlexRAID)
The JBOD case/backplane supports >4 TB drives as does the IBM controller so you should be fine there.
The backplane basically assigns a logical unit number to each drive, so all 16 can be seen and utilized at once. SMART data should be passed through just like they were connected directly to the HBA.
Unlike with a traditional hardware RAID setup, this configuration will always have direct disk access available to the OS. When using a RAID controller they typically obscure the individual drives and only present the RAID volume to the OS. Generally you can use the tools that come with the controller to access SMART data, perform firmware updates or anything else that requires direct access to the drives, but 3rd party utilities usually won't be able to see the individual drives. Using a standard HBA (like the IBM card you have) alleviates those problems.
ajhieb is offline
post #2369 of 2472 Old 12-23-2014, 06:33 AM
golf7's Avatar
Thanks for the info. Now to get these things to my house and replace the fans so it doesn't sound like a rocket going off.
Anyone got any suggestions for some good quiet fans to replace on this thing ?
golf7 is offline
post #2370 of 2472 Old 12-23-2014, 05:56 PM
cantalup's Avatar
I just do not get it on flashing M1015(9240) to IT(9211 IT) since by default all unconfigured drives are treated as JBOD in 9240
Unless you are talking on Open Solarias variances that no support 9240 very well..
mine, I just keep M1015 firmware and flash with the newest firmware, all running perfectly under Centos or ubuntu with ZoL, even... I had been replace 1 bad drive where smart notifying failed/failing drive..
rule of thumb:
if OS support 9240 well, No bother to flash with 9211 IT firmware...
cantalup is offline
Reply Home Theater Computers
Norco Rpc 4020 4u Rackmount Server Chassis W 20 Hot Swappable Sata Sas Drive Bays , Norco
