Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative? - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #2461 of 2475 Old 12-15-2016, 09:32 AM
MATA7's Avatar
Quoted: 54 Post(s)
Liked: 37
thanks
wow that backplane cost like 700.00 canada
Sony XBR-X940E | Yamaha CX-A5100 | Anthem MCA 50| Sunfire TGA-7201 | SVS 16-Ultra Subwoofer| 7.1.4 Klipsch RP-450C - RP-260F - RP-240S - RP-160M - 4 In-Ceiling MartinLogan | Nvidia Shield TV | Xbox One | AppleTV
English Is Not My First Language
MATA7 is offline
post #2462 of 2475 Old 12-15-2016, 09:37 AM
likelinus's Avatar
Quoted: 140 Post(s)
Liked: 52
Originally Posted by MATA7 View Post
thanks
Not sure where you are looking, but I got mine off eBay for $146. It was new in box.
likelinus is offline
post #2463 of 2475 Old 12-15-2016, 09:40 AM
MATA7's Avatar
Quoted: 54 Post(s)
Liked: 37
im searching now on ebay, but i dont fiend it lol, all i see is SAS no SAS2
MATA7 is offline
post #2464 of 2475 Old 12-15-2016, 09:49 AM
likelinus's Avatar
Quoted: 140 Post(s)
Liked: 52
Sorry bud. Like with anything on eBay, sometimes you have to wait and keep searching for the right item or deal. Good luck in your search.
post #2465 of 2475 Old 12-15-2016, 09:50 AM
MATA7's Avatar
Quoted: 54 Post(s)
Liked: 37
thanks for you help, i really appreciated
take care
MATA7 is offline
post #2466 of 2475 Old 12-15-2016, 03:22 PM
MATA7's Avatar
Quoted: 54 Post(s)
Liked: 37
ok i think im gone go with this case Norco RPC-4224
http://www.ebay.ca/itm/181391974486?...%3AMEBIDX%3AIT
i am concern i read a lot of bad reviews with this case backplane problems and norco costumer support i read is no that great also
someone please confirm if this card is what i need for the extra 8 Hard drive that i need to connect, my motherboard only support 8 and i need 16 HD
http://www.ebay.ca/itm/201079205126?...%3AMEBIDX%3AIT
please do i need anything else?
thanks in advanced for all you help i really appreciated
btw i cant browse norco site, can anyone please check if the site work for you
www.norcotek.com
MATA7 is offline
post #2467 of 2475 Old 12-15-2016, 05:09 PM
toohip's Avatar
If your not using SAS connections you could also look for a SM case with the passive connections. Backplane (SAS846TQ) This supports all size hard drives to date. You could also use SAS breakout cables.
The build quality on the SM is superior to the Norco cases.
Something like this: Just replace the power supply for noise and your good to go. You could also gut the whole thing.
http://www.ebay.com/itm/Supermicro-2...3D152016795815
toohip is offline
post #2468 of 2475 Old 12-15-2016, 06:15 PM
foxxiu's Avatar
www.norcotek.com
Bad reviews are probably for the older version of Norco case. The one I bought Down Under about a year ago has upgraded backplane v2.0, 3 backplane fans (instead of four) and SSD disks holder. Can't complain.
Weird is, it's still nowhere mentioned that this is upgraded version. Even Norco's website says nothing.
Sent from my ZX Spectrum 48k
foxxiu is offline
post #2469 of 2475 Old 12-15-2016, 09:24 PM
MATA7's Avatar
Quoted: 54 Post(s)
Liked: 37
for some reason norco web site is no working for me, so i cant even check the site
MATA7 is offline
post #2470 of 2475 Old 12-15-2016, 09:27 PM
MATA7's Avatar
Quoted: 54 Post(s)
Liked: 37
wow thanks that a great deal, the seller dont ship to canada, im gone keep locking
this is becoming a bit confuse to me, i trough it was gone be more easy, buy a case and dump hard drives to it
MATA7 is offline
post #2471 of 2475 Old 12-26-2016, 09:57 PM
claymca's Avatar
Need a little help. I purchased one of these SGI Rackable Half Depth servers http://www.ebay.com/itm/SGI-Rackable...torefresh=true
It has a backplane that is a standard non-expander SAS backplane that has one SFF-8087 port for every four disks. 12 HDD Bays in total. The Motherboard, an Intel S5520HC, has 5 onboard SATA ports. I am currently using Mini-SAS (SFF-8087) to 4 SATA Cables to get at least 5 SATA drives loaded. I need a controller card to connect the other bays.
I have searched and only found this card that uses SATA ports and not SAS ports. http://www.newegg.com/Product/Produc...-070-_-Product Every other card I find uses Internal Mini-SAS ports and is expensive.
claymca is offline
post #2472 of 2475 Old 12-28-2016, 10:46 AM
holyindian's Avatar
Quoted: 123 Post(s)
Liked: 50
Anyone has tried swapping out the PSU on the 2U or 3U chassis? is there enough headroom in the 2U chassis if i go with a seasonic gold?
holyindian is offline
post #2473 of 2475 Old 06-16-2017, 06:54 PM
clonemother's Avatar
Liked: 0
Sorry to bring this thread back from the dead but does anyone have the original power supply cages/distribution blocks that they would like to get rid of for a reasonable price?
clonemother is offline
post #2474 of 2475 Old 06-16-2017, 09:02 PM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
For what case? If it's the AIC, I have two sets. What would you consider a reasonable price?
Quaraxkad is offline
post #2475 of 2475 Old 06-18-2017, 04:21 PM
ja00's Avatar
Quoted: 216 Post(s)
Liked: 144
I have the Supermicro set - 2 PSUs, fan cage, disty block. It's yours if you want it. Just pay for shipping. What is your location?
ja00 is offline
Reply Home Theater Computers
Norco Rpc 4020 4u Rackmount Server Chassis W 20 Hot Swappable Sata Sas Drive Bays , Norco
