Bitstream problem - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 63 Old 06-01-2012, 01:22 AM
Favelle's Avatar
Originally Posted by surroundsounder View Post
ive been reading that pcm is better than bitstream anyways
Where exactly did you read this?? Its an ODD statement considering that every single audio signal gets converted to PCM before it is sent to your speakers, even bitstreamed DTS-MA/Dolby TrueHD...
In terms of LFE, size does matter!
Favelle is offline
post #62 of 63 Old 06-01-2012, 12:17 PM
surroundsounder's Avatar
ya the guy that built the pc is coming down to walk we through it. i agree that i probably didnt need the sound card to begin with but at the time i thought it would do the trick. for some reason i have it stuck in my head that if i have a high end video and sound card ill get better blu ray and mkv file playback on my tv. better than a stand alone panasonic player.
surroundsounder is offline
post #63 of 63 Old 06-01-2012, 02:24 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
A htpc's sound will sound identical to any other Blu-ray player if they are both outputting the same signal (DTS-HD, DTS, TrueHD, DD, lpcm).
When it comes to picture quality, some htpc's require a lot of tweaking to get the picture to match the picture from a stand alone player.
I found that having my Asus HDAV made it incredibly easy to get bitstreaming everytime under WinXP, Vista, and Win7 since the card came with an oem version of TMT3.
audit13 is offline
Reply Home Theater Computers
