Bitstream problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 63 Old 05-29-2012, 02:52 PM - Thread Starter
uthijacker's Avatar
Can anyone tell me why i have nothing under encoded formats? My receiver shows i can get multiple formats.
HTPC - HDMI Detective - TX-SR605 - Samsung LED tv
HTPC is using onboad video I3, Driver is Feb 2011 that assassin shows in his blog
uthijacker is offline
post #2 of 63 Old 05-29-2012, 03:02 PM
Sammy2's Avatar
Quoted: 558 Post(s)
Liked: 264
What codecs and player are you using?
What AVR do you have?
Have you enabled the HD Audio?
Sammy2 is offline
post #3 of 63 Old 05-29-2012, 03:22 PM - Thread Starter
uthijacker's Avatar
Installed lav splitter
Onkyo TX-SR605
i dont see a place in the bios for it.
Z68MX-UD2H-B3
post #4 of 63 Old 05-29-2012, 03:36 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Your receiver is sending the signal through to your TV and that's why it says "Samsung". Your Samsung TV likely cannot decode anything except for maybe dolby digital. Your HTPC recognizes that it is connected to the Samsung and doesn't even know the Onkyo is in the chain.
Tell your AV receiver that you want it to process the HDMI signal. The screen then should say "Onkyo" or "AV Receiver" or something similar.
assassin is offline
post #5 of 63 Old 05-29-2012, 03:38 PM - Thread Starter
uthijacker's Avatar
Is it because the hdmi detective is before the receiver?
post #6 of 63 Old 05-29-2012, 03:39 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Change the receiver's settings to capture and process the HDMI signal and not send it through.
assassin is offline
post #7 of 63 Old 05-29-2012, 03:41 PM - Thread Starter
uthijacker's Avatar
Wow....any idea where that would be?
post #8 of 63 Old 05-29-2012, 03:43 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Page 84.
assassin is offline
post #9 of 63 Old 05-29-2012, 03:43 PM
Sammy2's Avatar
Quoted: 558 Post(s)
Liked: 264
Is this an Onkyo thing?
I've never experienced that with my Denon.. Windows>Control Panel>Sounds has always shown it as Denon which I selected as the default device but never had to make any changes in the Denon itself to get the audio because I think it knows you want to process the audio with it and not with the TV.
Sammy2 is offline
post #10 of 63 Old 05-29-2012, 03:57 PM - Thread Starter
uthijacker's Avatar
HDMI audio out has been tried in the on and off settings.
no difference. rebooted as well.
wondering if the hdmi detective should be between the receiver and tv rather than the htpc and receiver.
post #11 of 63 Old 05-29-2012, 04:02 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
What video card are you using?
If it's an ATI, you should disable the realtek device completely and use ATI HDMI output device.
audit13 is offline
post #12 of 63 Old 05-29-2012, 04:04 PM - Thread Starter
uthijacker's Avatar
Onboard Intel
post #13 of 63 Old 05-29-2012, 04:13 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Onboard Intel
Did you install the Intel Management Engine and hdmi audio driver? The sound playback device should be Intel HDMI audio or Intel Display Audio I believe.
Disable your onboard audio in the motherboard's bios.
audit13 is offline
post #14 of 63 Old 05-29-2012, 04:14 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Just echoing other's thoughts on making sure you have all motherboard AND Intel CPU drivers installed.
assassin is offline
post #15 of 63 Old 05-29-2012, 04:22 PM
Zon2020's Avatar
Onkyo makes a big deal about having "passthrough." A lot of people here have indicated they bought their Onkyo for that very reason so they could watch TV using the TV speakers without turning on the AVR and surround sound system.
Personally, I've never had any interest in doing that and my Sony ES AVR doesn't have passthrough so I've never needed to worry about this issue. The HTPC only sees the AVR. Seems to avoid a heck of a lot of problems that way.
I do think some other brands also have that passthrough feature.
Zon2020 is offline
post #16 of 63 Old 05-29-2012, 04:30 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
The Onkyo 605 is not capable of 3d or passthrough so it shoould not be an issue.
audit13 is offline
post #17 of 63 Old 05-29-2012, 04:30 PM - Thread Starter
uthijacker's Avatar
I have no items in device manager that would show that the Intel Management Engine and hdmi audio driver are not installed.
Again...Could it be the hdmi detective being before the receiver?
post #18 of 63 Old 05-29-2012, 04:31 PM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
In the settings of the Onkyo itself,
set the input to 'Direct' to allow the AVR to receive and decode HD audio.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #19 of 63 Old 05-29-2012, 04:39 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Does it work without the hdmi detective in the chain?
What sound devices are listed under Device Manager? Intel Display Audio should be there.
audit13 is offline
post #20 of 63 Old 05-29-2012, 04:45 PM - Thread Starter
uthijacker's Avatar
This doesnt help as the htpc cant see the AVR as shown in the pic.
post #21 of 63 Old 05-29-2012, 04:46 PM - Thread Starter
uthijacker's Avatar
As in the above pic...intel display audio is listed under the samsung
post #22 of 63 Old 05-29-2012, 04:48 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Take the HDMI detective out. Use as little variables as possible to start.
assassin is offline
post #23 of 63 Old 05-29-2012, 04:49 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Did you try it without the hdmi detective and disabling the Realtek?
The monitor should be the Onkyo, not the Samsung tv and this looks like it's causing the problem.
audit13 is offline
post #24 of 63 Old 05-29-2012, 04:51 PM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
I also own an Onkyo and for the formats to show on the PC you 1st need to do as I have suggested.
I have no need for the hdmi detective
In Control Panel | Sound, I see my onkyo's model number listed as the device.
Shark007 is offline
post #25 of 63 Old 05-29-2012, 05:00 PM
Sammy2's Avatar
Quoted: 558 Post(s)
Liked: 264
Denon has passthrough audio too but the default is off. IDK why anyone would kick out some decent cash for speakers and an AVR and then pass the audio through to the TV.
Question for the OP, why are you using the HDMI detective?
Sammy2 is offline
post #26 of 63 Old 05-29-2012, 05:00 PM - Thread Starter
uthijacker's Avatar
It was the hdmi detective that was the problem.
but now with it after the receiver, when i switch to another function and back it reverts to 1024x768....grrrrr
post #27 of 63 Old 05-29-2012, 05:03 PM
Sammy2's Avatar
Quoted: 558 Post(s)
Liked: 264
Remove thr HDMI detective from the chain and try again.
Sammy2 is offline
post #28 of 63 Old 05-29-2012, 05:04 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Did you get out the power adapter to redo the detective settings?
audit13 is offline
post #29 of 63 Old 05-29-2012, 05:07 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
FYI this is what my Sound control panel looks like (yes, I do a lot of testing as you can see)
assassin is offline
post #30 of 63 Old 05-29-2012, 05:18 PM
blushrts's Avatar
It's been a while since I've done it, but did you use the receiver to program the detective? If you used the TV, that might be the reason you don't see the other audio options.
blushrts is offline
Reply Home Theater Computers
