360 extender no longer shows all my channels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-30-2012, 07:37 AM - Thread Starter
therealbiglou's Avatar
I have a strange problem that just started popping up. In our living room we have a HTPC using a Hauppauge HVR-2250 and a DCR-2650. This works great for our purposes and all our channels work great from our main TV.
We also use an Xbox 360 as an extender for television in the bedroom. Up until recently, this too was working great. However, now it only lists a random few channels, maybe 20 at tops. However, I can look at the living room TV at the same time and see all my channels.
I can even watch TV currently recorded from a channel that is not visible from the 360 extender's guide.
Restarting does not always fix this problem. Does anyone know what could be happening?
therealbiglou is offline
post #2 of 5 Old 05-30-2012, 10:54 AM
tgrinch's Avatar
Quoted: 23 Post(s)
Are you sure you don't have one of the guide favorites loaded? For example, on the left side of the guide, there's a vertical bar on the left that expands and you can Search or choose a list of favorites (Movies, Sports, Most Viewed(?), etc).
When one of these is selected, it'll always show the guide with this filter enabled. You can show everything by disabling the filter in the same manner.
tgrinch is offline
post #3 of 5 Old 05-31-2012, 05:49 AM - Thread Starter
That did the trick! I don't know if I'm more happy that it works again or more upset that I feel so stupid!
post #4 of 5 Old 05-31-2012, 06:31 AM
rdb4133's Avatar
Don't feel bad simple fixes like that happen all the time. Thankfully it was a quick and easy one, not some crazy drm/playready related one!
rdb4133 is offline
post #5 of 5 Old 05-31-2012, 07:34 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
The first time that happens it makes you crazy .
StardogChampion is offline
Reply Home Theater Computers
