Would this old mobo work for a server? - AVS Forum
post #1 of 7 Old 05-30-2012, 09:20 AM - Thread Starter
Jackal55's Avatar
I was going to upgrade a my HPTC main drive to a SSD and then build a server later. But since I wanted to move the TV cards (2x Duets) into the server I was wondering if I should just try to use my current HTPC as the server and build an ITX box.
The mobo is a Gigabyte E7AUM-DS2H mATX HDMI. It only has 2 pcie slots which are using the duet cards.
I've never built a sever before and I'm not sure if there are some decent PCI controller cards for additional hdds and if it's worth it to use them. I would keep the BR drive in the server so I could rip new movies directly to it. That would leave 3 sata and a esata port.
I could just keep Win7 on it and access the hdds as shared drives over my wired network, I do this anyway. Think this could work? Could I reasonably expand the number of drives or should I just build a server from the ground up?
Jackal55 is offline
post #2 of 7 Old 05-30-2012, 10:24 AM
blueiedgod's Avatar
Quoted: 16 Post(s)
Liked: 56
Looks like the mobo still has 2 PCI slots. You can get PCI-to-SATAI/II controller card. I have Rosewill 206 or 209. One is SATA I and the other is SATAII.
Despite what someone may tell you, spinning hard drives will never saturate the PCI bus on constant read. Yeah, it may saturate it on a burst from the cache, but that is just a small amount of data. When you are "reading" a movie or a file from the server, the PCI bus will be more than enough.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #3 of 7 Old 05-30-2012, 10:48 AM - Thread Starter
Jackal55's Avatar
Thanks. I'll look into it.
Jackal55 is offline
post #4 of 7 Old 05-30-2012, 01:44 PM
Mrkazador's Avatar
Quoted: 33 Post(s)
Liked: 248
PCI has a maximum bandwidth of 133 Megabytes per second. Hard drives on the PCI slot is not a problem when streaming movies. Most blurays are around 30 megabits which is 3.75 megabytes. The problem comes in when you read or write multiple files from multiple drives.
Mrkazador is online now
post #5 of 7 Old 05-31-2012, 05:30 AM
StanF's Avatar
It looks to me like that is an entirely appropriate server motherboard, and a perfect way to reuse your older hardware.
If you need more SATA ports, you can use the x16 PCIe slot for a higher end adapter card. The x1 PCIe and PCI slots won't give you full SATA bandwidth, but for a home server application that is generally not necessary. (I'm using a x1 PCIe to SATA adapter in my server, BTW)
Since I said that, someone will chime in with a use case where they are streaming blurays to 5 different computers at the same time. /roll eyes/ That's great - I'm talking generalities here.
StanF is offline
post #6 of 7 Old 05-31-2012, 09:03 AM
Carlitos714's Avatar
the mobo is fine.
go to newegg and search using "PCI SATA Controller Card" you find plenty to expand sata slots if you need them.
Carlitos714 is offline
post #7 of 7 Old 05-31-2012, 09:11 AM
assassin's Avatar
Liked: 205
assassin is offline
Reply Home Theater Computers
User Tag List
