Trouble with HD Audio on my Asus P8Z68 Gen3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-30-2012, 02:46 PM - Thread Starter
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
For the life of me I can't get HD audio to bitstream on my new build.
I'm using:
Asus p8z68 gen3
Intel i3 2105 H3000 graphics
W7 Pro 64
Denon 3808 AVR - fully HD audio compatible
Samsung TV - Can't remember the model off hand but could find out
Connections are all HDMI: HTPC-> AVR-> TV
I have been using Assassin's guides so I'm fairly confident that I should be able to do this. I can't get the files to play in WMC or XBMC. When I use the HD ready XBMC build I get no audio for anything including music. When I use the standard XBMC build audio plays but not HD.
Today I re-installed Windows thinking I may have messed up the drivers but I'm having the same problems.
Windows does recognize my AVR. I do get audio from other sources such as Youtube in Chrome and simple Windows sounds.
rec head is offline
post #2 of 10 Old 05-30-2012, 03:32 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Did you install the intel management engine?
Sammy2 is offline
post #3 of 10 Old 05-30-2012, 05:45 PM - Thread Starter
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
Yes. I have Intel Management Engine installed. This is really driving me nuts.
With the HD build of XBMC everything works except for the HD audio. I get "Failed to initiate audio device" and the file plays without sound. Dolby D files play fine and so does .flac.
rec head is offline
post #4 of 10 Old 05-30-2012, 05:54 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Download and install the trial version of TMT5 to see if you can bitstream with that.
audit13 is offline
post #5 of 10 Old 05-30-2012, 05:59 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
Make sure your connection type and settings are correct inside XBMC.
assassin is online now
post #6 of 10 Old 05-30-2012, 06:00 PM
jriver's Avatar
Quoted: 91 Post(s)
Liked: 69
It's probably a driver problem. Use Windows Control Panel/Sounds and the tests you will find there. If the device doesn't show itself as supporting the format you need there, it won't work in any application.
The TV doesn't matter. It's what your AVR sees that does matter.
I had a similar problem a year ago.
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
post #7 of 10 Old 05-30-2012, 06:06 PM - Thread Starter
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
Thanks. In the properties of my sound device (DENON-AVAMP) under encoded formats I only have DTS Audio, Dolby Digital Plus, Dolby Digital. No mention of any HD formats. All my drivers are up to date as of today. I'm really lost.
rec head is offline
post #8 of 10 Old 05-30-2012, 06:22 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
Use a different driver. When it comes to drivers newer does not equal better.
post #9 of 10 Old 05-30-2012, 07:31 PM
hlkc's Avatar
You should also see DTS MA, Dolby True HD... Go to intel.com driver download page using IE and install one of their check latest driver utility and after check, I expected it will ask you to update the latest video driver. FYI I've the same board but not Gen3 with i5 and bitstream for a long while.
hlkc is offline
post #10 of 10 Old 05-30-2012, 09:51 PM - Thread Starter
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
Thanks everyone. It is working now. I think it was rolling back the driver to the generic MS VGA and re-installing the Intel driver.
Now on to the fun stuff.
rec head is offline
Reply Home Theater Computers
