Help with ffdshow audio decoder and AC3(S/PDIF) option - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-30-2012, 04:56 PM - Thread Starter
isamu's Avatar
Quoted: 34 Post(s)
Hi guys. I'm using Media Player Classic, and I'm having a problem with the FFDshow audio decoder. If I check "AC3(S/PDIF) encode mode", it automatically disables FFD Audio decoder *entirely* upon restarting MPC and I get no sound. This never used to happen before. I have resample checked and have the rate set to 48000hz
My receiver is a 7.1 Toshiba and I'm feeding it from PC via HDMI.
My graphics card is ATI 5870.
Finally, here's a screenshot of my settings:
Can anyone tell me how to resolve this issue? I'd really like to be able to utilize the AC3(S/PDIF) encode mode option. Any help would be appreciated, thanks.
isamu is offline
post #2 of 3 Old 05-30-2012, 05:38 PM - Thread Starter
isamu's Avatar
Quoted: 34 Post(s)
OK I can now get ffdshow to enable with the AC3(S/PDIF) encoder option checked, but I still get no sound at all. I've tried setting my AMD 5870's audio output to both 16bit 44000Hz and 24bit 48000Hz. No dice. Please help
isamu is offline
post #3 of 3 Old 05-30-2012, 06:03 PM - Thread Starter
isamu's Avatar
Quoted: 34 Post(s)
OK guys I figured out the problem....In ffdhow, under the "Mixer" tab, turns out I had "OutPut Speakers Configuration" set to 3/1/2 - 6 Channels, when it should have been set to 3/0/2 - 5 Channels.
I also had "Allow applications to take exclusive control of this device" unchecked under the Exclusive tab within my AMD5870 Audio properties settings. That box should always be checked. I made a couple other changes as well, but I don't quite remember what they were LOL.
I'll keep you posted if the sound cuts off or if ffdshow disables again. In the mean time the AC3(S/PDIF) Encoder option is working for now so all is good
isamu is offline
Reply Home Theater Computers
