2 extenders on one HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-30-2012, 08:32 PM - Thread Starter
zeedub's Avatar
Is it possible to run 2 extenders at the same time utilizing different tuners through WMC? I am trying to create a setup strictly for DVR use via extenders? Can I run a less powerful HTPC if I only plan on serving media off of it to the extenders and not playing video out from it?
Thanks in advance
zeedub is offline
post #2 of 10 Old 05-30-2012, 09:55 PM
daidavel's Avatar
Sure ... I have 3 extenders (2 Xbox 360, 1 Linksys) running off a single HTPC (Core i3). The PC has 6 tuners (Ceton InfiniTV 4, SiliconDust HDHomeRun).
daidavel is offline
post #3 of 10 Old 05-31-2012, 07:12 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
We have 4 extenders and 8 tuners (CetonInfiniTV4 and 4X Magyca ClearQAM)
Not sure what you mean by "less powerful" HTPC does not need to be "powerful" to begin with. Without the extenders, or with just one extender, Intel ATOM Dual core was more than enough to drive live TV from 2x ATI DCT's.
One thing to keep in mind is that Microsoft recommends 1 CPU core and 1 Gb of RAM per extender connected.
If you have TV connected to the HTPC, add another core for it, as well.
With 4 extenders and a TV connected to HTPC, I can run all 5 TVs with 8 Gb of RAM without a hitch.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #4 of 10 Old 05-31-2012, 08:15 AM - Thread Starter
zeedub's Avatar
Thanks for the reply. As far as powerful I meant SandyBridge vs Atom. I am going to try and build a Sandy box but was curious how cheap i can go.
zeedub is offline
post #5 of 10 Old 05-31-2012, 08:22 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
atom will be a non starter. i have a 2.3ghz core 2 duo and having one extender on tests its limits. i have two extenders, but i cant i dont have any reason to run both and my pc at once.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #6 of 10 Old 05-31-2012, 10:31 AM
mcturkey's Avatar
Liked: 43
I'm running dual extenders with a Pentium G630. It's one of the lowest-end Sandy Bridge offerings there is, and it works fine. I believe the Celeron G430 (dual core 2.4GHz SB) is about $50. Add a cheap mobo (just be wary of non-Intel NICs on board), and it's not much more than Atom while offering massively better performance.
mcturkey is offline
post #7 of 10 Old 05-31-2012, 11:22 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Thanks for the reply. As far as powerful I meant SandyBridge vs Atom if I wasn't
using the HTPC to directly play the media on a display but rather the extenders.
Im not sure if it pegs the CPU as much by using the box in that way.
Playing on the HTPC does not peg CPU since the video is handled by the GPU. But, with Sandybrdige, I don't know if those two are seprated, or it uses CPU cycles to render video.
Using extender peg CPU, since most of the work is done by the CPU, and only little of the work is actually performed by the extender it self.
post #8 of 10 Old 05-31-2012, 11:39 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
I believe WMC supports up to five extenders, IIRC.
captain_video is online now
post #9 of 10 Old 05-31-2012, 12:44 PM
tgrinch's Avatar
Quoted: 23 Post(s)
This is five extenders at once, yes? You can register more than that, but can only have 5 running at the same time. I haven't hit this max, but thought that was the general rule.
tgrinch is online now
post #10 of 10 Old 06-01-2012, 05:23 AM
Quoted: 510 Post(s)
Liked: 336
I believe that is the case. I don't think there's a limit as to how many extenders you can connect to the main PC but rather how many it can support simultaneously.
Reply Home Theater Computers
