Need help finding a quiet replacement cpu fan for slimline htpc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 51 Old 05-31-2012, 03:37 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
I have an older dual core AMD Athlon Brisbane 1.9 cpu on an HP Slimline. I want to make the system quieter but I'm not sure if I should be looking at replacing just the cpu fan or the fan and heatsink. The current stock fan is an Asus 70x70x20mm (specs listed in link below) and the heatsink is also an Asus which is bolted down to the motherboard in a square pattern with screws at all 4 corners.
I have been battling noise in this computer for awhile now. Several months ago it started making a loud pitched whine. The whine would change pitch depending on cpu use. After doing some research I learned about soft mounting and how sometimes the metal screws connecting the fan to the heatsink can cause vibration throughout the case which increases noise. I went ahead and removed the screws and mounted the stock fan to the heatsink using double sided tape on all 4 corners. This immediately lowered the whining noise, so much so that I was kind of shocked. Anyways, over the past week the whining noise has started to come back some, nowhere near as bad as before but enough to annoy me.
According to the specs the stock fan is 5000 RPM with a noise output of 44.3 dB. 5000 RPM is pretty high isn't is? The speed is always the same no matter what I'm doing. I've looked into Speedfan to try to change it but it doesn't do anything. It says the speed is around 2100 RPM but I don't know if that is correct or not. The computer is an OEM HP so no options to change speed in the BIOS. The computer runs pretty hot as it is. Usually 60-75C depending on load. From what I understand these older Slimlines run hot though and I've had the computer for 5 years without any problems.
What fan should I be looking at replacing it with? I want quiet as possible. The options on Newegg for 70mm fans are pretty sparse. From what I understand this size fan isn't really popular so the pickings are slim. Should I be looking at a 80mm fan instead? It wouldn't fit the currect bracket but I could just double sided tape it to the heatsink like I'm doing now couldn't I? There are a lot of quiet and highly rated options in the 120mm range, but that wouldn't fit in my case would it?
I'm trying not to spend any more than $20-30. If a $10 fan would be just as good I'm fine with that. Thanks for any help and suggestions on what I should do.
http://parts.digikey.com/1/parts/172...12dd-tp10.html
StinDaWg is offline
post #2 of 51 Old 05-31-2012, 06:52 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Or should I just try a fan controller?
http://www.newegg.com/Product/Produc...Ltd-_-35118217
StinDaWg is offline
post #3 of 51 Old 05-31-2012, 07:00 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
How does it connect to the power? Molex by chance?
assassin is online now
post #4 of 51 Old 05-31-2012, 08:59 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Yes, it's a standard 4 pin connector.
StinDaWg is offline
post #5 of 51 Old 05-31-2012, 09:03 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
Take a look at my FAQ (3rd post) in my sticky thread. You can slow it down manually.
post #6 of 51 Old 05-31-2012, 09:40 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
I'm not really understanding the diagram. The cables look the same to me. Is the $6 adapter I posted basically do the same thing? Would you recommend lower speed over getting another fan?
StinDaWg is offline
post #7 of 51 Old 05-31-2012, 09:52 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
No.
You change the way the wires are arranged in the harness/plug and that changes the speed of the fan (slows it down).
Its free.
post #8 of 51 Old 05-31-2012, 11:24 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Never mind, I don't have that setup after looking at it again. I obviously have the wires coming from the fan into the connector, but where I plug it into the pins are just sitting in the motherboard. There's no way to change anything.
StinDaWg is offline
post #9 of 51 Old 06-09-2012, 05:35 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Still looking for suggestions. I played around with Speedfan a bit more and got it working. I can slow the stock fan to around 1100 RPM which is definitely quieter than before, but still makes a little noise. I don't know if I can get my system any quieter, but I'm willing to try a new fan for $10-15 if it's going to help. Good 70mm fans are hard to find, but I found this Nexus which I heard gets good reviews. I'm not sure if that one will be adjustable with Speedfan though. Any more suggestions are appreciated.
http://www.amazon.com/Nexus-70mm-Real-Silent-Case/dp/B003PNLRLU/
StinDaWg is offline
post #10 of 51 Old 06-09-2012, 09:50 PM
rdunnill's Avatar
I put a 92mm Cooler Master Vortex RR-VTPS-28PK-R1 in my HP Slimline -- the fan intake is so close to the side case grille it doubles as a case fan.
My Slimline has been upgraded to a Foxconn H67S, however, and I don't know if the Vortex will fit on a stock mainboard.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
post #11 of 51 Old 06-10-2012, 01:07 AM
dksc318's Avatar
Look for a 70mm Delta 4 pin PWM (pulse width modulation) fans such as these:
AFB0712HHB
AFC0712DB
Obviously the higher RPM will be noisy but move more air and lower RPM will be quieter but move less air. You can try a few and see what you like. There are other brands such as AVC, Top Motor too,
Using a fan controller for CPU is not a good idea as chip thermistors are much more accurate than external thermistors. Fan controllers or fans with thermistors for cases are ok.
dksc318 is offline
post #12 of 51 Old 06-10-2012, 01:16 AM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Thanks for the recommendation. What made you choose that model over the million others out there? I read the reviews on Newegg and the overwhelming majority complained that it was extremely difficult to install, taking up to an hour in some cases and needing an extra hand. Did you have any problems? The stock one in there now in extremely easy to take in and out. It just screws down on all 4 corners and that's it. I've never replaced a heatsink before but I don't understand what could be so difficult. I don't see the 4 feet like mine on the one you posted so I'm not sure how it gets secured. The 70mm fan I have right now is almost touching the side grill as well, but the fan faces the front of the case not the side. I don't know if it would fit either but right now I have the case off anyways because it runs too hot after I set the fan to 1100 RPM. The CPU is at ~65-70C under 10-20% cpu usage. Some people in the reviews said it only gave them a few degree improvement over stock while others said 20+ so I don't know what to believe.
The thing I care about most is making it as quiet as possible. The computer is 5 years old so if it eventually dies due to heat then I've got my moneys worth and I'll just get something else.
StinDaWg is offline
post #13 of 51 Old 06-10-2012, 01:34 AM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
AFB0712HHB
AFC0712DB
The stock fan I have right now is actually the Delta AFC0712DD, which looks to be the same as the AFC0712DB, just custom branded for HP or something. I'm limiting it to ~1100 RPM with Speedfan, but even that is not silent. Am I just asking for too much? Is there no fan out there that is 99% quiet during normal conditions? Would a brand new Delta be quieter than my 5 year old model? Do they get louder with age? Do I need to mount it another way, vibration dampening screws or something? confused.gif Right now it is doubled sided taped at all 4 corners with a 1/4" gap between the fan and heatsink. I did this a few months ago after some research showed that the metal screws were vibrating through the heatsink to the cpu. Every time cpu usage would go up or down a high pitched and extremely irritating whine would occur. I've eliminated that by removing the screws and mounting with x2 sided tape.
The fan I have now at 1100 RPM isn't *loud* by any means, but the whirling/humming noise is completely audible from 9 feet away and loud enough to be annoying.
StinDaWg is offline
post #14 of 51 Old 06-10-2012, 01:49 AM
dksc318's Avatar
Yes, bearings do wear out after a while. A new fan should be better. These things are not expensive so try a few different ones.
Also, cleaning the fan helps too.
dksc318 is offline
post #15 of 51 Old 06-10-2012, 02:09 AM
Stuie675's Avatar
Delta fans are not known for being quiet, they are reliable and most manufacturers use them because they move a good amount of air and do not cost much.
Sites like
frozencpu.com
performance-pc.com
will have some good choices for cheap.
You could also take it apart and clean it and relube it, which is not really that hard, but some people do not like to get that deep into it especially since a new one will only cost about 10 bucks.
Here is a good one for 10 bucks also
http://www.frozencpu.com/products/5579/fan5v-09/Evercool_70mm_X_15mm_5_Volt_Fan_-_EC7015M05CA.html?tl=g36c231s590#blank
Stuie675 is offline
post #16 of 51 Old 06-10-2012, 02:53 AM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
That one is 3500 RPM and does not have PWM to control the speed. Wouldn't that be louder than what I have now?
StinDaWg is offline
post #17 of 51 Old 06-10-2012, 09:27 AM
dksc318's Avatar
The stock fan I have right now is actually the Delta AFC0712DD, which looks to be the same as the AFC0712DB...
That last letter is thickness so D should be 20mm. B should be 15mm. That AFC0712DD actually can do quite a bit of airflow at 46.86 CFM.
http://www.delta-fan.com/ProductSeries.aspx?seriesname=AFB
But moving down to 40 CFM is probably ok. OEM are a bit more conservative since most owners doesn't watch this kind of things.
dksc318 is offline
post #18 of 51 Old 06-10-2012, 11:55 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
So the one that is slightly thinner and pushes slightly less air should be quieter at the same RPM?
I'm still a little confused on whether I should be getting another PWM fan and limiting the speed, or just getting a so called "low noise" fan at a fixed speed.
StinDaWg is offline
post #19 of 51 Old 06-11-2012, 12:04 AM
dksc318's Avatar
You can try an AFB0712HHB and see if the CPU temp is acceptable. Actually, it seems the AFC0712DD is a bit harder to find. I think a newer fan will be quieter.
dksc318 is offline
post #20 of 51 Old 06-11-2012, 12:13 AM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
You have any ideas where I can buy that model? A google search brings up a few stores I've never heard of, and Newegg but it's been discontinued and the reviews are from over 4 years ago.
StinDaWg is offline
post #21 of 51 Old 06-11-2012, 01:16 AM
dksc318's Avatar
Try eBay. I can see quite a few with search terms "70mm 15mm fan". There are not much results with 20mm.
dksc318 is offline
post #22 of 51 Old 06-11-2012, 02:42 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Just bumping to see if anyone else has any other suggestions before I make a purchase. I'm either going to get the Delta AFB0712HHB mentioned above with PWM function or get something marketed as "low noise" like the Nexus Real Silent 70mm and then buying a fan controller if it's not quiet enough.
StinDaWg is offline
post #23 of 51 Old 06-12-2012, 02:55 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Does it has to be a 70mm fan? I would buy a good low-noise PWM 80x80x25mm (or even 90x90x25) fan (generally much more air flow/noise than a 70x70x15mm fan) and attach it with epoxy adhesive.
renethx is offline
post #24 of 51 Old 06-12-2012, 06:27 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Well, I don't think anything larger than 70mm will fit in my case. As it currently sits the left side of the fan sits right up against the side panel. I have maybe half an inch between the other side of the fan and the power supply, so I would have to jerry-rig it if even possible. It would probably fit fine without the side panel on.
That being said what recommendations do you have for those sizes?
StinDaWg is offline
post #25 of 51 Old 06-12-2012, 07:06 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Noctua NF-R8 PWM
GELID Silent 8 PWM (FN-PX08-20)
ARCTIC F8 Pro PWM
There is also a 92mm version of each.
renethx is offline
post #26 of 51 Old 06-12-2012, 10:37 PM
dksc318's Avatar
I have the TC (thermal control) and PWM versions of this Gelid Silent 8 (80mm). It is pretty quiet, about 20dbA at full speed of 2000 RPM. In the box are 4 rubber mounts instead of screws.
However this fan is only rated at 27 CFM. The AFB0712HHB is rated at 37 CFM and the original AFC0712DD is rated at 47 CFM.
Generally there are no free lunch here. Quiet fans move less air or larger size.
dksc318 is offline
post #27 of 51 Old 06-12-2012, 10:47 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I bet in general a 80x80x25mm fan is quieter than a 70x70x15/20mm fan at the same CFM. smile.gif That's the point of using a 80mm, 25mm-thick fan instead of a 70mm, 15mm or 20mm-thick fan.
renethx is offline
post #28 of 51 Old 06-12-2012, 11:17 PM
Stuie675's Avatar
haha you are right I linked you to the wrong fan, I was actually looking at that one for myself for something else, I was up to long haha
Stuie675 is offline
post #29 of 51 Old 06-13-2012, 12:40 AM
dksc318's Avatar
Sure, 1U servers use 40mm fans and they scream.
The standard intel PWM fans that came with the CPUs are actually pretty good and can be from Foxconn, Delta or Nidex. I have some very quiet PWM CPU fans from AVC and Dynatron (Top Motor) as well but they are 80-90mm dia.
dksc318 is offline
post #30 of 51 Old 06-13-2012, 01:01 AM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Aren't those 37 and 47 CFM numbers rated at full speed though? I've increased the stock Delta fan I have to 5000 RPM just for testing purposes, and it sounds like a jet engine revving up for takeoff. There is no way anyone could live with something that loud. It has to run at ~1500 before it's acceptable and I have it at the lowest it will go which is 1100 now. I guess what I'm getting at is if I'm never going to run the fan at full speed what does it matter what the CFM rating is?
StinDaWg is offline
Reply Home Theater Computers
