LG BD drive won't recognize "Rampart" blu ray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-06-2012, 04:33 PM - Thread Starter
C E Jones's Avatar
I have the LG GGC-H20L on my HTPC. I haven't had problems running other titles using AnyDVD, but for some reason the drive won't recognize the "Rampart" blu ray. My AnyDVD is up to date, and I don't see how it can be an AnyDVD issue because the drive doesn't even recognize that there is any disc in the drive. In My computer it shows the drive as empty. I've tried using 2 different discs from Netflix, so I don't think it's a damaged disc issue.
Any ideas on how to fix this issue? Again, all other blu rays I've tried have worked.
C E Jones is offline
post #2 of 10 Old 06-06-2012, 08:47 PM
xfett's Avatar
Can you rip the disc using AnyDVD HD ? Have you checked on the Slysoft forums? Have you tried any other software/OS ?
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #3 of 10 Old 06-07-2012, 04:26 PM - Thread Starter
C E Jones's Avatar
As I said in my post, the problem is that the drive does not recognize the disc at all. The computer has to recognize a disc before AnyDVD can do anything with it. Not every playback issue is about AnyDVD.
post #4 of 10 Old 06-07-2012, 05:57 PM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
Sometimes I get a disc from Netflix that looks brand new with no scratches or fingerprints but neither of my bluray drives will read it at all. I just ask for a replacement and the next one will work fine. I think sometimes the discs are just screwed up when they are manufactured.
squeakybirnbaum is offline
post #5 of 10 Old 06-08-2012, 02:31 PM - Thread Starter
C E Jones's Avatar
Does anyone around here read posts, or just the titles???
As I said in my post, I got a replacement disc from Netflix, still have same problem. I've gotten plenty of damaged blu rays from Netflix, but never 2 in a row. I guess I'll try one more replacement disc, then just get the DVD if that one doesn't work either.
post #6 of 10 Old 06-08-2012, 02:44 PM
shortcut3d's Avatar
Quoted: 21 Post(s)
Liked: 29
Sometimes pledge wipes help. Seriously. I had the same problem with multiple replacement Star Wars discs and finally, I used pledge wipes to "clean" the disc. In this case, I tried everything including changing the drive mode from DMA.
shortcut3d is offline
post #7 of 10 Old 06-08-2012, 03:33 PM - Thread Starter
C E Jones's Avatar
Thanks Shortcut, I'll try a more thorough clean on the disc I have now (my second one from Netflix). I did a quick T-shirt wipe on both discs, but I do remember having success in the past with some glasses-cleaner when nothing else would work (forgot to try that this time).
post #8 of 10 Old 08-18-2012, 01:39 PM
tomlom's Avatar
It's odd, but i had exactly the same problem with the Rampart Blu-Ray in my Samaung Player. The disk would show the copyright screen, then the production company, and then nothing. I purchased the disc at Best Buy, and they exchanged it for a new one. Exactly the same thing happened, fresh out of the shrink-wrap.
tomlom is offline
post #9 of 10 Old 08-19-2012, 09:28 AM
JMGNYC's Avatar
Quoted: 51 Post(s)
Liked: 43
I've had a few disks that my LG drive wouldn't recognize even after getting a replacement. There's really nothing you can do about. It's caused by DRM and authoring of the disk. They basically will only work in a BD player.
JMGNYC is offline
post #10 of 10 Old 08-19-2012, 03:33 PM
mcturkey's Avatar
Liked: 43
mcturkey is offline
Reply Home Theater Computers
