I am getting stuttering in 3D Bluray ISO, will TMT5 fix this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-07-2012, 06:59 AM - Thread Starter
Singuy's Avatar
I am getting some stuttering while playing 3d bluray using an nvidia 550ti/powerdvd 12 ultra/epson 3d 5010 projector. Stuttering is usually not a big deal to me except that it can cause headaches while watching 3d (stuttering makes the moving object looks like it's ghosting..and your eye can't focus on the object as the object seems transparent/clear).
I've tried power dvd's FI support (smoothing they call it) but I don't think it is working for 3d content. Also my graphics card can only output at 24hz (projector reads 23.999hz). You think TMT 5 can fix this issue?
Anything else I can try?
Singuy is offline
post #2 of 2 Old 06-07-2012, 07:03 AM
hirent's Avatar
Download the trial and use it.
No one except you can answer whether it will work on your system.
Good Luck!
hirent is offline
Reply Home Theater Computers
