3D Capable GPU for a projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-08-2012, 11:10 PM - Thread Starter
shuasha's Avatar
I'm in the process of finishing my home theater, and just moved my older HTPC down to the rack to play some content while I do the finishing work. The HTPC consists of a GeForce 8300 based motherboard/GPU, which has been great for Blu-ray playback with Windows Media Center and TMT3 and 5. I ripped a 3D iso today to see how that did, and had no luck. After looking around, it seems that my older GPU can't handle the 3D part.
Here is what confuses me:
When I look at what GPUs from AMD are capable of 3D, they don't list any projectors that they're compatible with. Does that matter at all? I'm running an Epson 5010.
Is it as simple as adding a HD 6570 to my existing system to make this work? If not, I guess I'll move to a different motherboard with onboard graphics, but simple is better at this point.
shuasha is offline
post #2 of 6 Old 06-09-2012, 10:41 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
I'm in the exact same boat as you and am hoping someone responds to your thread.
I have some 3D iso's and have a 5770 videocard. I don't think I can do 3D because of it.
If it's just a matter of changing the Videocard than that's not to much of a big deal.
Good luck
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #3 of 6 Old 06-09-2012, 10:28 PM - Thread Starter
shuasha's Avatar
To follow up on this, the 6570 worked perfectly!
shuasha is offline
post #4 of 6 Old 06-11-2012, 12:25 PM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
Good luck
The 5770 should work for 3d, even including hardware decoding, IIRC.
Roussi is offline
post #5 of 6 Old 06-11-2012, 12:31 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
I can't seem to get the 3D ISO's to work.
Is it because I am trying to watch them with MPC-HC?
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #6 of 6 Old 06-11-2012, 02:37 PM
ricabullah's Avatar
Sure, you need a commercial SW like PDVD, TMT or WinDVD.
Chronical Tester
ricabullah is offline
Reply Home Theater Computers
