24 hour skip function? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-09-2012, 03:07 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Is there a 24 hour skip or jump function in the guide?
My Dish DVR has this ability & it’s real handy to check the same program every day of the week. For example there may be a daily program but I only watch it when the topic interests me. I can check it Monday at 3pm & then just jump to Tues, then Wed, etc in order to view the details. This saves a lot of time by not having to scroll hourly to get to the same listing on he following day.
Can this be does with WMC?
Mike99 is offline
post #2 of 7 Old 06-09-2012, 03:35 AM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
Just push next or chapter skip or whatever the button is called twice. It skips ahead 12 hours every press.
squeakybirnbaum is offline
post #3 of 7 Old 06-09-2012, 08:34 PM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Thanks for the information.
I’m using a wireless keyboard & clicking on the menu option buttons displayed on the HDTV. Here’s what’s happening for me.
If I start out & select the Guide none of the Skip or FF or FR buttons work. They are grayed out, as are the Stop & Play buttons.
If I’m watching a recording or live TV & then switch to the Guide screen the Skip, FF & RW buttons work within the Guide. I can also pause the recording or live TV & switch to the Guide screen & the buttons work. I also noticed the FF & RW buttons do a 3 hour skip.
Sometime when watching live TV & Stopping & then switching to the Guide only the Skip back & RW buttons work. I’m still trying to figure out what sequence of button pushes causes this scenario.
But I do need to have some program playing or paused in the background in order for the 12 hour skip to work. Is this normal behavior or do I need to change some setting?
Mike99 is offline
post #4 of 7 Old 06-10-2012, 10:56 AM
pohh-bah's Avatar
Quoted: 29 Post(s)
WMC really isn't designed for full-time use without a remote control. They are very cheap so you should get one.
With a remote, the guide skips 12 hours forward or back with the 4-way rocker switch. Some addons might take over certain buttons while playing TV (e.g. DVRMStoolbox).
pohh-bah is offline
post #5 of 7 Old 06-10-2012, 01:30 PM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I do plan on getting a remote. I just built this HTPC and am using a wireless keyboard I already had in order to make sure everything works.
But I am curious, when you use the remote for the 12 hour skip does your HDTV display those skip & FF buttons as grayed out? I'm concerned that I might not have something set correctly. IOW if they are grayed out for me then perhaps a remote will not control them either.
Mike99 is offline
post #6 of 7 Old 06-10-2012, 04:53 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
That's normal if you have live TV stopped.
For a keyboard use Ctrl - F
Andy_Steb is offline
post #7 of 7 Old 06-10-2012, 11:14 PM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Thanks, that works. And I tried Ctrl - B and that skips back 12 hours.
I searched all over for documentation on using the guide and everything just comes up with the basics. Is there a comprehensive tutorial on the guide or WMC?
Is there a keyboard function that duplicates the 3 hour FF & RW functions of clicking on the screen buttons?
Mike99 is offline
Reply Home Theater Computers
