Bitstreaming...I know I know, not this again! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-11-2012, 07:12 PM - Thread Starter
hockeyrcks9901's Avatar
For those of you who actually looked at yet another bitstreaming thread...
I built my HTPC and didn't think there was a snowballs chance that I would add a SS system before the HTPC needed a rebuild. Well, I was wrong so I'm looking to add bitstreaming to my HTPC and wondering what the cheapest way to do this is. I really don't expect myself to add 3D anytime soon so I'm avoiding that, and I do say that with a lot of confidence, I'm still loving my Panny plasma and not looking to upgrade for some time.
Now that we've got that out of the way, I'm thinking either this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102882
or this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161367
Which one? Both going for $25 after rebate at Newegg (I really hate rebates). The Sapphire is going for $20 after rebate at Amazon. I'm leaning towards the Sapphire just due to the much higher number of positive reviews at the $5 cheaper at Amazon.
Side note: I guess I'll be buying 512MB of RAM at the same time as I'll be able to stop sharing it with the onboard GPU. w00t!
hockeyrcks9901 is offline
post #2 of 10 Old 06-11-2012, 08:21 PM
hirent's Avatar
hirent is offline
post #3 of 10 Old 06-11-2012, 08:44 PM
Zon2020's Avatar
I have an HIS 5450, think it's probably the same one. Been very happy with it.
What's the rest of your computer system?
Zon2020 is offline
post #4 of 10 Old 06-11-2012, 08:49 PM
Favelle's Avatar
I have seen 6450's and 5450's for like $15. I would NEVER pay $40 for one.
In terms of LFE, size does matter!
Favelle is offline
post #5 of 10 Old 06-12-2012, 12:37 PM - Thread Starter
Where do you see $40? They are $20 and $25 after MIR.
post #6 of 10 Old 06-12-2012, 12:37 PM - Thread Starter
Double tap...
post #7 of 10 Old 06-12-2012, 06:43 PM
Favelle's Avatar
IF you get the rebate. Its still $40 out of your pocket. I wouldn't pay $25 for a card that I routinely see at $15. Better?
Favelle is offline
post #8 of 10 Old 06-13-2012, 11:33 AM - Thread Starter
Understood.
Where are you finding these cards for $15 without rebates?
post #9 of 10 Old 06-14-2012, 12:16 AM
Favelle's Avatar
Even Newegg, which I find the highest prices out of anywhere have a 6450 for $25, NO rebate:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125378&nm_mc=OTC-sho6b0tCA&cm_mmc=OTC-sho6b0tCA-_-Video+Cards-_-GIGABYTE-_-14125378
Favelle is offline
post #10 of 10 Old 06-14-2012, 12:18 AM
Favelle's Avatar
Understood.
Usually every 2nd week or so at places like NCIX or MemoryExpress...
Favelle is offline
Reply Home Theater Computers
