Anyone used one of the picoPSU-160-XT power supplies? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 06-11-2012, 11:31 PM - Thread Starter
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
Wondering if it will power a G530/4G RAM/SSD HTPC reliably. Anyone tried one?
Looky here!
robnix is offline
post #2 of 23 Old 06-12-2012, 07:05 AM
rsoares28's Avatar
Quoted: 110 Post(s)
Liked: 26
I think it will as per the reports in the "habey" case thread. My setup is the same except i have an i3 2100 and i'm looking at the 120wat pico
rsoares28 is offline
post #3 of 23 Old 06-12-2012, 07:21 AM
dksc318's Avatar
I have a 120W wide voltage picoPSU and it is powered by a 19V adapter. The setup is a i5-2390T, ASRock H67M-ITX MB, SSD and ODD.
Wattage should be enough as my new server with 3 HDDs is running at 50W.
dksc318 is offline
post #4 of 23 Old 06-12-2012, 07:30 AM
KevBel's Avatar
Never used one but you can probably go even lower-powered, closer to 100W, if that's all that's in your build.
KevBel is offline
post #5 of 23 Old 06-12-2012, 10:33 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
You'd be hard pressed to consume 60W at full load with that setup. The picoPSU-90 would be a nice choice for that setup since it comes with the P4 ATX connector which you need for the G530.
http://www.short-circuit.com/categories/powercombos.html
I use a 84W AC adapter with my G620/H61/4GB/128GB SSD bedroom HTPC.
StardogChampion is offline
post #6 of 23 Old 06-12-2012, 01:15 PM
rsoares28's Avatar
Quoted: 110 Post(s)
Liked: 26
Hey Stardog , will this adapter http://hqrp.com/hqrp-120w-ac-adapter-compatible-with-hp-pavilion-zd7000-zd7001ea-zd7001us-laptop.html work with a 120wat pico? i have a I3 2100/ssd/4gb ram I also want to power usb tv tuner which has a molex connection.
post #7 of 23 Old 06-12-2012, 02:19 PM
Quoted: 93 Post(s)
Liked: 160
That's a 18.5V adapter so you'd need to use the picoPSU 120-WI-25 "wide input". Most all the other picoPSUs are 12V only.
I would also double-check the adapter tip is 5.5mm * 2.5mm. It appears that it would need to be to fit a zd7000 as it claims.
I believe too this is the one Assassin recommends?
post #8 of 23 Old 06-12-2012, 02:26 PM
wolverinegod's Avatar
this site might help you figure out what you need: http://www.extreme.outervision.com/psucalculatorlite.jsp
pico's rock.
wolverinegod is offline
post #9 of 23 Old 06-12-2012, 03:02 PM
Quoted: 93 Post(s)
Liked: 160
pico's rock.
According to this site, a G530/4GB/SSD/ODD system needs a 174W PSU. That's not even close to the real world.
I've built a bunch of different LGA1155 mini-ITX systems that use DC-DC / AC adapter power supply combinations with this basic configuraton of CPU, RAM, SSD and ODD and none of them has drawn over 60W at 100% load (Prime95) as measured at the wall with a Kill-A-Watt. I've used the G530, G540, G620 and i3-2100.
post #10 of 23 Old 06-12-2012, 03:50 PM
It's hard for me to comment on that as I'm not entirely sure which options you selected and i'm by no means a power expert ... that said, I just filled out a regular desktop with the g530, one dram ssd, one dvd burner and it says the system needs 130 for me (not 174). I know that site adjusts for things like form factor as well, but i think it's a good starting point. I've read several writeups on it from sites like maximumpc and i have yet to see anyone say it's terrible (i'm not saying it is or it isn't, i'm in no position to judge ... i'm just saying that those that are seem to speak highly of it from what i can tell).
post #11 of 23 Old 06-12-2012, 05:41 PM
xfett's Avatar
I have a 10TB FreeNAS server running on a PIcoPSU 160
specs
ASROCK E350M1 {CPU fan lvl 1 in BIOS}
Pareema 4GB (2 x 2GB)
Intel EXPI9301CTBLK NIC
5 - WD20EARS 2TB HDD
picoPSU-160-XT PowerSupply
1 - Noctua NF-R8-1800 {lvl 1 manual speed control in BIOS}
Raidmax IT case
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #12 of 23 Old 06-12-2012, 07:27 PM
SUBCOB's Avatar
Here's mine with a 150 pico. I know I could have gotten by with a 90 to 120.
I3-2100T
8 gigs ram 2 X 4
60G SSD Vortex 2
1TB WD green drive
Hauppauge 2250
internal HD 2000
disabled in bios:
Onboard sound
COM ports
If I remember right it pulls 27-29 at idle and 40-45 playing 1080P. I haven't done a prime test.
Based on your post a 90 or 120 pico would be fine, but if you are going to load up the drives that's when you may want to go to a 150 or 160.
SUBCOB is offline
post #13 of 23 Old 06-12-2012, 07:55 PM - Thread Starter
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
WOW. Thanks all for the excellent info. Ordering one in just a few minutes.
Looky here!
robnix is offline
post #14 of 23 Old 06-12-2012, 08:12 PM
Quoted: 93 Post(s)
Liked: 160
Without knowing how they calculate it, it's hard to understand how accurate it is for these low power systems. I can't explain the discrepancy without knowing their method. I only know what's I've measured which has been pretty consistent. I measure the usage of every new build that uses different components with the Kill-a-Watt at the desktop, playing 1080p and with Prime95. Of course, who knows where I wrote it down... smile.gif. SandyBridge 65W TDP, 4GB RAM, 64-128GB SSD and a tray or slot-load burner is usually around 25W-30W desktop, 40W 1080p video, 55-60W Prime95.
post #15 of 23 Old 06-12-2012, 09:39 PM
dksc318's Avatar
....you'd need to use the picoPSU 120-WI-25 "wide input". Most all the other picoPSUs are 12V only.
I would also double-check the adapter tip is 5.5mm * 2.5mm....
The older Thinkpad 16V, 72W AC adapters will fit. I have one powering the following:
i5-2400S (65W)
ASUS P8H61-I
intel 80GB SSD
BluRay ODD
Most power systems will be at maximum efficiency when it is operating close to maximum power rating.
dksc318 is offline
post #16 of 23 Old 06-13-2012, 08:24 AM
Quoted: 93 Post(s)
Liked: 160
i5-2400S (65W)
ASUS P8H61-I
intel 80GB SSD
BluRay ODD
That's the same adapter I've used with the picoPSU 120-WI-25. My office was just throwing them out -- from old T30s and T41s -- so I grabbed a few.
post #17 of 23 Old 06-13-2012, 08:44 AM
dksc318's Avatar
Our notebooks at the office and at home all changed to the newer 20V types so we have a lot of these 16V Thinkpad adapters too. They are well built and more efficient than Targues adapters at standby.
dksc318 is offline
post #18 of 23 Old 06-13-2012, 10:41 AM
rsoares28's Avatar
Quoted: 110 Post(s)
Liked: 26
i5-2400S (65W)
ASUS P8H61-I
intel 80GB SSD
BluRay ODD
Excellent, thats the same motherboard i have. So i would need this? http://www.itxcanada.com/products/picoPSU_120_WI_25_120w_Wide_Input_12_25V_Wide_Input_DC_DC_Power_Converter-599-43.html
and it would work with the adapter i posted earlier? I worried about the adapter tip comment.... are you saying its the right size as "it would need to fit a zd7000"?
post #19 of 23 Old 06-13-2012, 10:44 AM
Quoted: 93 Post(s)
Liked: 160
Yes, the picoPSU 120-WI-25 is the "wide input" one that can take from 12V to 25V input.
The picoPSU needs a 5.5mm * 2.5mm adapter tip. The specs for the linked AC adapter don't show the tip size. However, other adapters said to fit the zd7000 do say 5.5mm * 2.5mm so it's seems to be the right one. I would confirm the adapter's tip size before ordering. The voltage/amperage ratings look just right for the 120-WI-25.
rsoares28 likes this.
post #20 of 23 Old 06-13-2012, 01:52 PM
rsoares28's Avatar
Quoted: 110 Post(s)
Liked: 26
Thank you very much for the help and advice, much appreciated!
post #21 of 23 Old 06-13-2012, 08:06 PM
Quoted: 93 Post(s)
Liked: 160
No problem -- happy to help!
What case are you putting this all in?
post #22 of 23 Old 06-13-2012, 08:35 PM
dksc318's Avatar
You will need a 4 pin Molex to 4 pin ATX12V adapter cable. Some MB will boot without this cable and some won't. If you also have an ODD, then you will need 4 pin Molex Y splitter and other pieces. My case is now full of wires. Use the Thinkpad 72W 16V adapter if you can stay under that power budget. Most of my computers will.
dksc318 is offline
post #23 of 23 Old 06-14-2012, 07:05 AM
rsoares28's Avatar
Quoted: 110 Post(s)
Liked: 26
I already have a habey 800, its already setup, been working since november but ive been reading the psu and brick that comes with the habey is not the greatest... just looking to upgrade.
I dont have an ODD so my current molex is not being used. I have a genpix skywalker usb tuner that has its own brick connected with a molex cable. i'd like to remove the brick and just have the genpix power on and off with my pc using the pico's molex cable.
233
Reply Home Theater Computers
