"bitstream" LPCM audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-12-2012, 12:12 AM - Thread Starter
woody777's Avatar
Quoted: 17 Post(s)
I have a few BDs with uncompressed LPCM audio (some Harry Potter movies, the first Chronicles of Narnia). I bitstream pretty much everything except music (local files and Spotify) and YouTube videos. Since both of these are 2.0/44.1, that's what I set Windows at to avoid any unnecessary conversions.
Obviously, this is a pain for LPCM tracks -- they play in stereo unless I change my Windows settings. I know I can use Reclock to "bitstream" PCM and let WASAPI take exclusive control of the device. The problem is I'm using WMC to play the movies (MKV, Shark007) and Reclock breaks live tv if I let it open with ehshell.
Is there any other way to achieve what I'm after without reclock?
woody777 is offline
post #2 of 7 Old 06-12-2012, 08:28 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
There is no way AFAIK. A compromise is use AC3 track or encode LPCM to AC3 in real-time by ffdshow Audio Decoder.
renethx is offline
post #3 of 7 Old 06-12-2012, 10:42 AM - Thread Starter
woody777's Avatar
Quoted: 17 Post(s)
Thanks! The discs have a secondary compressed track (usually DD).
What about converting the PCM track to another lossless format -- wav or flac? Or does that just leave me in the same spot because those won't bitstream either without reclock?
woody777 is offline
post #4 of 7 Old 06-12-2012, 11:03 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
WAV is the same as LPCM. FLAC is lossless, but has to be decoded to LPCM before transmitted over HDMI.
You can create a small script to switch between stereo, 5.1 and 7.1 via keyboard shortcut (AutoHotKey, a hint). A similar one: Soundswitch (press Ctrl+Alt+F9 to switch between stereo and 5.1; I don't know how to select 7.1 with this program).
renethx is offline
post #5 of 7 Old 06-13-2012, 11:21 AM - Thread Starter
woody777's Avatar
Quoted: 17 Post(s)
Thanks renethx!
I appreciate the help! That may solve my problem (especially if I can figure out a way to make it happen automatically when launching certain titles (it's seriously like 3 titles out of my collection).
One more question... is it possible to convert PCM to a bitstreamable format? It seems like I remember eac3to being able to create AC3 tracks (but maybe it could just extract the DD core from True-HD).
woody777 is offline
post #6 of 7 Old 06-13-2012, 07:06 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes, eac3to can convert whatever audio format it supports into AC3. A nice GUI is HD-DVD/Blu-ray Stream Extractor. select "Extract As: AC3" for a LPCM audio track. Then merge the extracted streams into a single MKV with mkvmerge GUI.
renethx is offline
post #7 of 7 Old 06-14-2012, 11:51 AM - Thread Starter
woody777's Avatar
Quoted: 17 Post(s)
Thanks!!!
woody777 is offline
Reply Home Theater Computers
