Different between passive DP and DP++ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-12-2012, 07:01 PM - Thread Starter
hlkc's Avatar
Is there any different between passive DP and DP ++?
My MB has a DP++ port and I got one of the passive adapter, DP to HDMI, but it is not working, no AV.
Is that menas since my MB has a DP++ port, therefore I need an adapter which can do DP++ and pass thru DVI/HDMI signals?
Is that means there are 2 DP ports/standard out there, DP++ and DP, and DP++ can pass thru DVI and HDMI signals without conversion?
hlkc is offline
post #2 of 8 Old 06-12-2012, 07:52 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
DP++ can transmits DVI/HDMI signals as well as DP (so a passive adapter is enough). DP transmits DP only; it requires an *active* adapter to convert DP signals to DVI/HDMI.
I assume you want to attach three DVI/HDMI displays. Then you will need an active adapter (~$30 like this) whatever i/dGPU you use (Intel/AMD).
renethx is offline
post #3 of 8 Old 06-12-2012, 08:04 PM - Thread Starter
hlkc's Avatar
renethx welcome back! We all missed you here!
Regarding my problem... my new MB has a displayport powering by the Intel HD4000 and should be DP++, which triggers passive DP signal, right? But I got one of the passive DP to HDMI adapter, se belo, but no luck. Any idea why?
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10428&cs_id=1042801&p_id=4826&seq=1&format=2
hlkc is offline
post #4 of 8 Old 06-12-2012, 09:09 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Which mb are you using? I checked ASRock, ASUS, GIGABYTE Z77 mb with DP port, but none of them has this logo:
renethx is offline
post #5 of 8 Old 06-12-2012, 09:31 PM - Thread Starter
hlkc's Avatar
Thanks for looking into this one with me. I've the Asus P8Z77-V Premium.
I wrote to Asus Support and below is their reply.
"The display port provided by the Intel HD4000 is DP++, which triggers passive DP to HDMI cable."
hlkc is offline
post #6 of 8 Old 06-12-2012, 09:45 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
P8Z77-V Premium does not have *DP++ logo* either. Perhaps better not trust tech support (the majority of these tech support people actually don't know technologies, even of their own products). smile.gif
renethx is offline
post #7 of 8 Old 06-12-2012, 09:54 PM - Thread Starter
hlkc's Avatar
LOL!!!
So I guess I need to be creative now...
What do you think one of below and DVI to HDMI converter them HDMI to my projector? I should have picture there, right?
http://www.newegg.com/Product/Product.aspx?Item=N82E16815129011
hlkc is offline
post #8 of 8 Old 06-12-2012, 10:24 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
Reply Home Theater Computers
