WMC windows priority - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-16-2012, 06:47 AM - Thread Starter
jefejt's Avatar
Is there a way to make the WMC window have priority? The problem is that while watching TV if someone calls my house the Magic Jack window jumps to the front. I'd rather it not.
jefejt is offline
post #2 of 3 Old 06-16-2012, 07:07 AM
Sammy2's Avatar
Quoted: 516 Post(s)
Liked: 250
Try "always on top" in WMC settings.
Sammy2 is offline
post #3 of 3 Old 06-17-2012, 06:58 AM
SUBCOB's Avatar
Majic Jack will always pop up no matter what the priority is set to. You need to run a program to have it minimize into the task bar. I have found that this doesn't work 100% either, but much better than the alternative. Go to the magic jack forum and you should find a couple of small programs that will do what you want.
SUBCOB is offline
Reply Home Theater Computers
