Cablecard question - AVS Forum
post #1 of 12 Old 06-17-2012, 06:54 PM - Thread Starter
jefejt's Avatar
In theory if I wanted to add a cable card to my Comcast account to use with my hd prime. Would i be able to use it at my office or would it only work at home.
jefejt is offline
post #2 of 12 Old 06-17-2012, 06:58 PM
Foxbat121's Avatar
Quoted: 121 Post(s)
Liked: 200
Only at home. It requires a cable feed and an account with specific home address on it.
Foxbat121 is offline
post #3 of 12 Old 06-17-2012, 08:16 PM
Zon2020's Avatar
Just out of curiosity, could you use some sort of remote desktop to view it remotely on a home pc?
Zon2020 is offline
post #4 of 12 Old 06-18-2012, 04:58 AM
bryansj's Avatar
Quoted: 34 Post(s)
Liked: 169
No. There may be other solutions to port your TV feeds remotely, but remote desktop and VNC won't work.
bryansj is offline
post #5 of 12 Old 06-18-2012, 10:07 AM - Thread Starter
jefejt's Avatar
Even if my cable feed to the office is also comcast? Obviously the address is different, but why does that matter as far as the card is concerned. Isn't it simply "translating" the information? How does the card no what location it is in?
jefejt is offline
post #6 of 12 Old 06-18-2012, 10:16 AM
pittsoccer33's Avatar
Quoted: 63 Post(s)
Liked: 193
a cablecard is basically a cable box (to be more exact cable boxes have cablecards inside of them).
suppose you subscribe to every single channel comcast offers and you have their cable box. if you disconnected the box and walked next door to the neighbors (not comcast subscribers) and tried plugging your box in the provisioning would be all messed up.
My HTPC front end set up
Integration for whole home ATSC, CableCARD, FM radio, Blu-Ray, HD-DVD, DVD, VHS control & capture, video games, and archived & streaming media playback
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
post #7 of 12 Old 06-18-2012, 10:39 AM
gregzoll's Avatar
Liked: 32
Even if my cable feed to the office is also comcast? Obviously the address is different, but why does that matter as far as the card is concerned. Isn't it simply "translating" the information? How does the card know what location it is in?
It doesn't, since it is considered a "dumb" device. Now of course, if you take it to another headend, or another system, it will not work, due to it is not authorized on that system.
gregzoll is offline
post #8 of 12 Old 06-18-2012, 11:12 AM
jdmag00's Avatar
+1 as long as your on the same head end, which chances are you would be it should work in both locations.
Sent from my DROID BIONIC using Tapatalk 2
jdmag00 is offline
post #9 of 12 Old 06-18-2012, 11:28 AM - Thread Starter
jefejt's Avatar
What does head end mean? Other than testing to see if it works, how would I know?
jefejt is offline
post #10 of 12 Old 06-18-2012, 11:42 AM
Foxbat121's Avatar
Quoted: 121 Post(s)
Liked: 200
You can via a VPN setup. Remote desktop is too slow for live video. But keep in mind, a HD feed typically requires about 15mbps of data rate which means you need at least 15 mbps of UPLOAD speed on your home internet connection. Download speed does not apply here,
post #11 of 12 Old 06-18-2012, 11:45 AM
Foxbat121's Avatar
Quoted: 121 Post(s)
Liked: 200
You really have to test it out yourself. Headend is where your cable box/cable card connects to at the cable plant. Depends on how it is setup, you may or may not be able to get anything. When I moved about 15 miles within the same county and same cable provider 10 years ago, my existing cable box no longer worked when I plugged into the new location.
post #12 of 12 Old 06-18-2012, 11:52 AM - Thread Starter
jefejt's Avatar
Got it, thanks.
jefejt is offline
Reply Home Theater Computers
User Tag List
