? 3D setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 06-18-2012, 02:54 PM - Thread Starter
bzb416's Avatar
Hi there,
My setup:
HTPC with AMD 6670 graphic card (dual-link DVI, displayport 1.2, HDMI 1.4a)
Epson 3D projector
Pioneer AVR 7.1 with TrueHD (not 3D compatible)
I am planning to use my AVR to decode the bitstream audio and have a direct video output from the HTPC to the projector to watch 3D movie, but wondering if the displayport 1.2 on my graphic card is cable of carrying bitstream audio or 3D signal or the dual-link DVI is capable of carry 3D signal to the projector. Which ever connection route is ok as long as I get bitstream sound to the receiver and 3D video to the projector. I don't want to waste a great AVR just because it does not have 3D feature. All suggestions are greatly appreciated.
bzb416 is offline
post #2 of 35 Old 06-18-2012, 03:52 PM
ricabullah's Avatar
You just need to buy a second cheap card like 5450 for audio. ,
You have to use multiple screens; one for video, one for audio.
Chronical Tester
ricabullah is offline
post #3 of 35 Old 06-18-2012, 03:56 PM
Nimo's Avatar
Just run the display port to HDMI cable to your AVR for sound and HDMI to projector.
Nimo is offline
post #4 of 35 Old 06-18-2012, 05:15 PM - Thread Starter
bzb416's Avatar
I have been doing some online search to confirm that displayport can bitstream TrueHD to AVR, but found none frown.gif
bzb416 is offline
post #5 of 35 Old 06-18-2012, 06:42 PM
Nimo's Avatar
I assure you it works because I use two cables from my video card one to TV and one to my SC-07, extend the desktop set both refresh rates.wink.gif
Nimo is offline
post #6 of 35 Old 06-18-2012, 09:21 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
You will need an *active* DP-HDMI adapter in case DP carries HD audio bitstreaming (I don't know if carries it or not). As your card has a DVI port, you can use AMD's proprietary DVI-HDMI adapter to send audio over DVI port.
- HDMI -> projector
- DVI -> AVR
or vice versa (doesn't matter).
Update
The information above is wrong. A passive DP-HDMI adapter is enough for video + HD audio bistream. Or you can use AMD's proprietary DVI-HDMI adapter to the same effect. In other words,
- HDMI port
- DP port with a passive DP-HDMI adapter
- DVI port with AMD's proprietary DVI-HDMI adapter
are completely equivalent.
However, once you connect two displays, then only the connector to which the *main* display is connected acts as HDMI and the other connector acts as DVI (no 3D, no audio, no color space selection [RGB only]). This means that you can't send 3D video over one of the connector and HD audio over another. A workaround is:
a) If your CPU is Intel (Clarkdale, Sandy Bridge or Ivy Bridge) or AMD APU (Llano or Trinity), then activate its GPU and use it to send audio.
b) If your CPU does not have integrated GPU, then add another cheap GPU such as HD 5450 (~$20). The second graphics card works even with a PCI Express x1 slot! (just cut the closed end to make it an open end.)
renethx is offline
post #7 of 35 Old 06-18-2012, 11:01 PM
Nimo's Avatar
I bought this cable back in Feb for (9.00) for my 6850 and have no problem getting full lossless True HD, dts HD MA etc... I hope this answers your question good luck!smile.gif
300
Nimo is offline
post #8 of 35 Old 06-19-2012, 12:28 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
OK, I confused "three display support" with this case. For two displays (actual display and AVR), a *passive* DP-HDMI adapter should work and support HD audio bitstrreaming as Nimo says. An active DP-HDMI adapter is required for three displays. An alternative is use AMD's DVI-HDMI adapter.
renethx is offline
post #9 of 35 Old 06-19-2012, 08:14 AM - Thread Starter
bzb416's Avatar
Thanks you very much for all your helps.
I am planning to get all the accessories this week (projector screen, cable, ceiling mount etc...) and try it out. I did read up on DP-HDMI for sound and found the cable on Amazon.ca (http://www.amazon.ca/gp/product/B002CSRF9M/ref=ox_sc_act_title_1?ie=UTF8&m=A2UB5780NRC5IR) , but couldn't find anything to confirm that it capable of passthrough full lossless True HD and dts HD MA to AVR, thanks to Nimo for your confirmation.
Its good know another option about AMD's proprietary DVI-HDMI adapter to send audio over DVI port. Thanks to renethx
K
bzb416 is offline
post #10 of 35 Old 06-20-2012, 02:49 PM
Nimo's Avatar
Another thing you can do is also use the DP to HDMI as video only and still be able to watch stereo 3D. I have my set up using HDMI to audio and DP to TV. Either way it doesn't matter but ATi uses the DP as display 1 so that's another reason why I have it set up this way.
Nimo is offline
post #11 of 35 Old 06-20-2012, 03:58 PM
jstabb's Avatar
Just an FYI to anyone reading this thread that your results may vary. It might be model dependent, or driver dependent, who knows maybe even display device dependent. But anyway, here was my experience trying to get this to work.
With my Gigabyte HD7770 I was not able to get HDMI audio and frame packed 3D working on separate connections (attempted on all available driver versions that support the 7000 series up to 12.5 beta). I could split audio and video fine, but as soon as frame packed 3D is thrown into the mix, no go. My experience was that regardless of which connections were used (I tried all possible combinations DP + HDMI, DP + DVI, HDMI + DVI and also reversed audio/video for each combo) the card always wanted to classify one of the connections as an HDMI connection and one of the connections as a DVI connection (which had nothing to do with which connector was used, the driver would happily call the AVR hooked up to the DVI connector an HDMI connection and my projector hooked up to the HDMI connector a DVI connection). The limitation of only one of the connections being classified as HDMI is what breaks audio and 3D. Obviously the AVR's connection must be classified as HDMI in order to leverage HDMI audio. Unfortunately the display's connection also has to be classified as HDMI in order for frame packed 3D to work (as it is part of the HDMI spec). The driver would not allow switching to a frame packed resolution on a DVI classified connection. This was tested through TMT, PowerDVD, and PowerDVD's BD advisor.
FYI: Projector was a Sony VPL-HW30ES and the AVR was a Denon AVR-3808CI.
If you purchase an AMD card with this usage in mind, please buy it from a place with a good return policy.
jstabb is offline
post #12 of 35 Old 06-20-2012, 04:51 PM
Nimo's Avatar
ATi broke 3D on my rig with the late 11 & 12 series drivers. 11.4,11.5's 11.5b hotfix 11.6 worked for me so you might want to give that a go I settled on 11.5's. It's usually the drivers...
Nimo is offline
post #13 of 35 Old 06-20-2012, 06:34 PM
jstabb's Avatar
Thanks, that's very useful information. Unfortunately 7xxx series owners can only go back to 12.2 IIRC, so we're kind of stuck. But it sounds like earlier generation owners have an option there with the older drivers.
jstabb is offline
post #14 of 35 Old 06-20-2012, 08:12 PM
Nimo's Avatar
Maybe try these ones they seemed to have fixed a lot of bugs. http://downloads.guru3d.com/AMD-Catalyst-12.x-(8.980.0-June-4)-Unofficial-BETA-download-2923.html
It's basically for gamer's but you never know with ATi. You can also use older drivers for any card certain forums hack the CAT files, same with nVidia...
Nimo is offline
post #15 of 35 Old 06-22-2012, 12:00 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
This is correct. See my post in FAQ 3D thread. A workaround is:
a) If your CPU is Intel or AMD APU, then activate its GPU and use it to send audio.
b) If your CPU does not have integrated GPU, then add another cheap GPU such as HD 5450 (~$20) for audio. The second graphics card works even with a PCI Express x1 slot! (Just cut the closed end to make it an open end.)
renethx is offline
post #16 of 35 Old 06-23-2012, 06:20 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I tried 11.5 hotfix b, 11.6 hotfix b, 11.7 with PowerColor HD 5750 and Sapphire HD 6670 (DP to 3D and HDMI to AVR, and all the other possible combinations). None of them supported HDMI + HDMI. Are you sure DP is sending *Frame Packing* to your display while HDMI is sending audio to AVR? DP as DVI can still send the other 3D formats (checkerboard, SBS, TAB, etc.).
I am more and more convinced that AMD HD 4xxx/5xxx/6xxx (and 7xxx as of now) do not support HDMI + HDMI. Perhaps this is because HD audio controller in AMD GPU does not support dual audio stream.
renethx is offline
post #17 of 35 Old 06-23-2012, 07:01 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Here is a summary.
In AMD HD 5xxx/6xxx/7xxx GPU, any of:
- HDMI connector
- DP connector with a passive DP-HDMI adapter
- DVI connector with AMD's proprietary DVI-HDMI adapter
works as a HDMI 1.4a connector that supports Frame Packing 3D video, HD audio and YCbCr color space as well as RGB.
However if two displays are connected to the GPU at the same time, then only one connector works as HDMI and the other connector always works as DVI (no Frame Packing 3D video, no audio, only RGB color space). Precisely speaking, if you use HDMI and DP/DVI, then HDMI always works as HDMI and DP/DVI works as DVI; If you use DP and DVI, then DP always works as HDMI and DVI as DVI. In other words, HDMI-likeness decreases in this order:
HDMI > DP > DVI
That means, unlike NVIDIA and Intel, you can't send Frame Pakcing 3D video over one of the connector and HD audio over another (you can still send other 3D formats such as checkerboard, SBS, TAB, interleaved over DVI, however). Apparently this is because of a limitation of the HD audio controller of AMD GPU, i.e. non-support for dual audio stream.
A workaround is use another GPU to send HD audio:
a) If it is a discrete AMD GPU and your CPU is Intel Clarkdale/SNB/IVY or AMD APU, then activate its GPU and use it to send audio.
b) If it is a discrete AMD GPU and your CPU does not have integrated GPU, then add another cheap GPU such as HD 5450 (~$20) for audio. The second graphics card works even with a PCI Express x1 slot! (Just cut the closed end to make it an open end.)
c) If it is iGPU of AMD APU, then add a cheap discrete GPU such as HD 5450 (~$20) for audio.
Also read this post.
  HD 5450-5670 HD 5750- HD 6310 (E-350) HD 6xxx (E-450, A Series, dGPU), HD 7xxx GT 210-240 GTS/X 250- GT(X) 430-460/520-560/all 6xx GTX 465/570- Intel HD Graphics (Celeron/Pentium SNB) Intel HD Graphics 2k/2.5k/3k/4k (Core i3/i5/i7 SNB/IVB)
MVC hardware decode No Yes No Yes Yes No Yes Yes Yes Yes
HDMI 1.4a 3D (Frame packing) Yes Yes - Yes Yes Yes Yes Yes No Yes
Frame packing to 3D display + HD audio to HDMI 1.3 AVR No No - No Yes (LPCM only) No Yes Yes (LPCM only) - Yes
Frame packing + HD audio to HDMI 1.4a AVR / 3D display Yes Yes - Yes Yes (LPCM only) No Yes Yes (LPCM only) - Yes
renethx is offline
post #18 of 35 Old 06-23-2012, 09:53 AM
Nimo's Avatar
My combination set up is HD6850 DP to HDMI to TV HDMI to HDMI to AVR. extended desktop W7 see's AVR as display #2. When booting make sure ATi see's the audio formats for lossless. If I boot the PC with no AVR in the chain then ATi will load it's basic 48k driver although stereo 3D still works there is no support for lossless. That's where nVidia kicks ATi's ass because nVidia gives you two drivers for this type of set up with ATi it's one or the other.
Nimo is offline
post #19 of 35 Old 06-23-2012, 10:39 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
DP to TV + HDMI to AVR with HD audio bitstreaming is no problem. wink.gif My point is different. Perhaps your DP works only as *DVI*. Check "Pixel Format" in CCC; if you don't see your TV name there, almost DP = *DVI*, that can't transmit the frame packing 3D format. It can still transmit other 3D formats such as checkerboard and SBS.
(DVI supports only RGB, while HDMI supports YCbCr too; if "My Digital Flat Panel" is connected via *DVI* [that could be a DP connector physically], you won't see the entry name "Pixel Format" as only full-range RGB is supported, while if it is connected via *HDMI* [that could be a DP connector physically], you will see it and be able to select color spaces.)
If your CPU is either SNB/IVB or Llano, this AMD GPU's limitation is actually no problem: use the integrated GPU for audio. smile.gif
renethx is offline
post #20 of 35 Old 06-23-2012, 04:51 PM
Nimo's Avatar
DP-HDMI My digital flat panel reports TV name with pixel format listed under SC-07 YCbCr. If I were getting SBS, checkerboard I would have to manually adjust the TV. This is not the case when I launch either PDVD or TMT it see's it as stereoscopic 1.4. SC-07 uses Faroudja DCDi 1080p built in video scaler, 6850 see's it as such.
Nimo is offline
post #21 of 35 Old 06-23-2012, 11:23 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
What's that? confused.gif You will not see your TV model number *under* SC-07 even if your TV connected to DP supports YCbCr. Here's how it works: you click the name of "SC07", see the list of selectable displays (the picture below; TX-SA606X is my AVR), select the other display (your TV) and only then you will see the model number of your TV and a drop down list of color pixel formats supported by your TV. The screenshot was taken with 11.4 Catalyst suite (with dual GPU; with a single GPU, only one display supports multiple color pixel formats and I even won't see the list of displays).
What's your TV model? Do you actually see its model number in the "Pixel Format" pane? If not (I bet not), your DP is not sending Frame Packing 3D.
BTW does "Faroudja DCDi 1080p built in video scaler" have anything to do with the current discussion? You are using SC-07 only as an audio processor/amplifier.
renethx is offline
post #22 of 35 Old 06-24-2012, 09:49 AM
Nimo's Avatar
Your right lol I got lost in translation, and actually forgot about what we were talking about redface.gif! If it's not sending the frame packing why does the 1.4 3D work without me having to adjust SBS or checkerboard. I know for a fact that it's not doing SBS, or checkerbaord because my TV will not auto tune to that I have to manually set the TV for both signals.
Nimo is offline
post #23 of 35 Old 06-24-2012, 10:22 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
So your DP acts as DVI, no audio, no YCbCr. But you claim it is sending HDMI 1.4a 3D video signal...that's not happening to anybody except for you (afaik, of course).
renethx is offline
post #24 of 35 Old 06-25-2012, 06:07 PM
Nimo's Avatar
TV is a Panasonic 50" VT-25, that's why I shot that video to show you guys that stereo 3D is active and working.
Nimo is offline
post #25 of 35 Old 06-25-2012, 10:33 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
It even does not support checkerboard. I have a VT30. Let me try it...
renethx is offline
post #26 of 35 Old 06-26-2012, 09:33 AM
Nimo's Avatar
This is what it looks like on my set up using 11.5 cat drivers.
Nimo is offline
post #27 of 35 Old 06-26-2012, 01:03 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
The third picture is it. Apparently DP to PanasonicTV0 is unable to support YCbCr, but support HDMI 1.4a 3D ... ? BTW thanks for your time to take screenshots.
renethx is offline
post #28 of 35 Old 06-26-2012, 10:02 PM
Nimo's Avatar
Ah..no biggie:) yes it sends 1.4a 3D. If I disable extended then it will display the TV's pixel format once the SC-07 is out of the chain.
Nimo is offline
post #29 of 35 Old 07-01-2012, 09:06 PM - Thread Starter
bzb416's Avatar
Hi all,
Thanks for all the input.
To update:
I finally got everything hooked up.
PowerDVD 11
MKV 3D SBS (testing sample)
ASUS HD 6670
DVI to Samsung TV (monitor, non-3D)
HDMI to PJ
DP-Adaptor-HDMI-AVR
Scenario 1:
DVI-Sam TV
DP-AVR
Extended mode
able to play MKV with audio bitstream to AVR
CC indicated that AVR support both pixel format (4:4:4, 4:2:2 and other RGB)
Scenario 2:
DVI-disconected
HDMI 1.4a - PJ
DP-AVR
Extended mode
Able to play 3D, but unable to get audio to AVR. No "sound to external AVR to decode" option available in PDVD (setting-audio).
Only audio come out of PJ speaker
CC indicated that PJ support both pixel format (4:4:4, 4:2:2 and other RGB)
Screnario 3:
DP-PJ
HDMI 1.4a- AVR
Able to get audio to AVR to decode, but unable to play 3D SBS on PJ (non-3D MKVs are fine)
Any suggestion before I try the 2nd video card for audio? BTW, is HD 5450 fit PCI 2.2? my MB is P5B-VM (micro-ATX) http://www.asus.com/Motherboards/Intel_Socket_775/P5BVM/#specifications.
OT: I am not sure if this was just me, but I get headache when watching 3D. It got worse as I watch longer. I didn't have that when I watch IMAX 3D in theater
my sitting distance from a 92" diagnose screen is 9feet (within the viewing distance I guess). I hope this is temporary, otherwise is such a waste of all
the setup, because I can't stand the headache and I bought PJ just for 3D smile.gif.
Thanks so much for all the helps.
bzb416 is offline
post #30 of 35 Old 07-01-2012, 09:44 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
HD 5450 does not fit a PCI slot. The slot has to be PCI Express. Cut the closed end of the PCI Express x4 slot and make it an open end. Then a graphics card should work. A smarter solution is use a GeForce card (e.g. GT 430) that supports dual audio stream.
renethx is offline
Reply Home Theater Computers
Pioneer , Pioneer Vsx 91txh 7 1 Channel A V Receiver Featuring True Hd Dts Hd Master , Projectors
