HTPC for Bluray 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-19-2012, 06:27 PM - Thread Starter
JLarm's Avatar
I am going to build a HTPC to view Bluray 3D movies.
I have no plans on gaming etc just watching movies on it.
What would you recommend? Got links to it?
JLarm is offline
post #2 of 5 Old 06-20-2012, 01:12 PM
olegy's Avatar
If you're looking for a book sized one, then:
http://www.newegg.com/Product/Product.aspx?Item=N82E16856107106
or similar with dedicated GPU ( but more expensive)
http://www.itxdepot.com/xcart/product.php?productid=2460&cat=44060&page=1
CPU: ( note 35W only!)
http://www.amazon.com/gp/product/B005LMPN7M/ref=ox_ya_os_product
Add laptop memory, HDD, super slim BR drive, if needed
here is an example:
http://www.amazon.com/LG-Super-Multi-Blu-ray-Combo-CT21N/dp/B003E91KM6)
olegy is offline
post #3 of 5 Old 06-20-2012, 01:32 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
If your plan is to only watch blu-ray movies then buy a blu-ray player.
If you mean something else like ripping your blu-ray movies to a HDD and playing them back then a streamer is all you need.
If you want to add DVR functionality to the mix an HTPC is for you.
Sammy2 is offline
post #4 of 5 Old 06-22-2012, 02:38 AM - Thread Starter
JLarm's Avatar
I started to consider a bluray player but as I also need the HTPC feature (TV, downloaded content etc) I will get a complete HTPC for the bluray 3D aswell.
A i3 is enough to use for Bluray 3D playback?
JLarm is offline
post #5 of 5 Old 06-22-2012, 09:52 AM
olegy's Avatar
More than enough. Even 35W version of it.
olegy is offline
Reply Home Theater Computers
