Need Onkyo TX-SR875 Firmware 1.05 as mutch as possible :C - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-20-2012, 02:37 AM - Thread Starter
Multipaco's Avatar
Hi all,
Im new here and german. I search for the Onkyo Firmware Update 1.05 for the TX-SR875 Receiver because i have the E2PROM (or so) error. Please help me :C All Links are death :C
LG
Paco
Multipaco is offline
post #2 of 13 Old 06-20-2012, 09:36 AM
hirent's Avatar
Here, check this thread:
http://www.avsforum.com/t/1386826/onkyo-tx-sr875-1-04-firmware/0_40
Related Threads:
http://www.avsforum.com/search.php?search=tx-sr875
You might want to post in this forum, it is specifically for AVRs, you will get better responses there.
http://www.avsforum.com/f/90/amps-receivers-and-processors
hirent is offline
post #3 of 13 Old 06-20-2012, 02:20 PM
a2clark's Avatar
a2clark is offline
post #4 of 13 Old 06-20-2012, 02:47 PM - Thread Starter
Multipaco's Avatar
In the Link you have postet there is no 1.05 Firmware to download :c
post #5 of 13 Old 06-20-2012, 06:28 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
audit13 is offline
post #6 of 13 Old 06-21-2012, 08:12 AM - Thread Starter
Multipaco's Avatar
A Member of the Forum have send me the 1.05 Firmware =). All works fine. If somebody else would need it, he can contact me!
post #7 of 13 Old 07-21-2012, 06:55 AM
uksub's Avatar
Hi
I also have an Onkyo tx-sr 875 that i haven't used for ages because of the e2prom error so it would be great if you have a firmware update that fixes this. If you could send this with instructions maybe this would be fantastic
look forward to your reply
uksub is offline
post #8 of 13 Old 08-25-2012, 03:10 PM
MykP's Avatar
Hello, I would like to upgrade my TX-SR875 as the E2PROM error is a pain. Can you send it to me please and also the process I need to follow to perform the upgrade.
Best regards
Myk
MykP is offline
post #9 of 13 Old 08-27-2012, 01:43 AM - Thread Starter
Multipaco's Avatar
You have an PN
post #10 of 13 Old 05-27-2013, 01:34 PM
der-gee's Avatar
Hi,
I'm also having the E2PROM ERROR on the TX-SR875. Could you please send me the instructions and files too?
Thanks in advance,
Michael
der-gee is offline
post #11 of 13 Old 09-13-2013, 07:34 AM
serpents's Avatar
Hi,
I'm having the E2PROM ERROR on the TX-SR875, too. Could somebody please send me the instructions and files for the 1.05 firmware?
Thanks in advance,
Michael
serpents is offline
post #12 of 13 Old 10-22-2013, 06:16 PM
Spirals's Avatar
I am also looking for the 1.05 firmware and instructions for installation. If somebody could send them to me I would appreciate it very much.
Thank you,
Derrick
Spirals is offline
post #13 of 13 Old 07-26-2014, 08:57 AM
Liked: 0
In need of Firmware Updates
Anyone here is so kind of sending me the files to update my 875 to firmware version 1.04 and the most recent one (I have an old firmware and I was reading I have to update to version 1.4 before updating to the most recent one)?
I called Onkyo but not sure if they would send the update to me or not, since they do not want to admit the problems, and I cannot find a link .
I did find the instructions though, so just need the update files.
Thank you very much.
Angelo Sabatini is offline
Reply Home Theater Computers
