Storage formats - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-28-2012, 09:59 AM - Thread Starter
Krispy Kritter's Avatar
Quoted: 53 Post(s)
Just curious what everyone is using as their storage format of choice. I'm sure it will vary depending on the content type.
DVD material, for example, do you convert to avi/mkv (which is possible without losing much/if any quality and cut file size in half)? Use disc images? If you use disc images, are they untouched, or movie only? Also, which tools are used?
Just trying to get an idea of the "norm" and form a plan for my new server size.
Krispy Kritter is offline
post #2 of 7 Old 06-28-2012, 10:04 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
For movies I only keep the main title.
mkv (most content)
m2ts
avi (not much)
wtv (RecordedTV)
Sammy2 is offline
post #3 of 7 Old 06-28-2012, 05:46 PM
potts.mike's Avatar
I keep 1 to 1 rips
potts.mike is offline
post #4 of 7 Old 07-02-2012, 07:34 AM
djearl81's Avatar
Quoted: 12 Post(s)
Main title to MKV with audio track and forced subtitles. No idea what the format of the actual tracks is inside the mkv file. I'm happy in my ignorance. I don't see the reason to spend more time trying to make the file smaller and degrade the quality of the original track. Others may see it differently and factor in screen size, storage requirements, love of tinkering, etc...
I'm confused too.
djearl81 is offline
post #5 of 7 Old 07-02-2012, 07:36 AM
kneedragger's Avatar
Quoted: 18 Post(s)
I do the same. MakeMKV I think puts the mpeg2 video in a .mkv container with no compression.
kneedragger is offline
post #6 of 7 Old 07-02-2012, 07:09 PM
kegobeer's Avatar
Originally Posted by potts.mike View Post
I keep 1 to 1 rips
Same here - with affordable priced hard drives, I just rip the entire disc.
kegobeer is offline
post #7 of 7 Old 07-07-2012, 10:42 AM - Thread Starter
Quoted: 53 Post(s)
Thanks for the info.
Reply Home Theater Computers
