Curious of people's experiences with HD's that are 2.5+ TB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-29-2012, 06:52 PM - Thread Starter
bfhancock's Avatar
I want to eventually look into building a nice media server. Do any of you have much experience with internal HDs that are 2.5 TB or larger? Even upwards of 4 TB or more if that is even realistic? I would just love to fit as much space as I can into my server. Any input would be greatly appreciated!
Thanks everyone!
Don't make fun of me for my stupid questions!
bfhancock is offline
post #2 of 15 Old 06-29-2012, 07:15 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 253
What are you worried about? I have used 3TB and 4TB drives with no issues.
assassin is offline
post #3 of 15 Old 06-29-2012, 09:17 PM - Thread Starter
bfhancock's Avatar
What brands/models would you reccomend?
post #4 of 15 Old 06-29-2012, 09:37 PM
xfett's Avatar
Thats kind of a loaded question. Any size/brand of HD can fail. Just the luck of the draw.
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #5 of 15 Old 06-29-2012, 10:32 PM - Thread Starter
bfhancock's Avatar
I know. Let me rephrase. Have you had better performance and reliability with any specific brands/models in larger internal drives?
post #6 of 15 Old 06-30-2012, 09:14 AM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
There's all of two manufacturer's left. Pick one or the other.
almostinsane is offline
post #7 of 15 Old 06-30-2012, 10:48 AM
RVWinkle's Avatar
I would say that differences in performance are pretty minor for typical home theater file servers. Reliability seems to have dropped across the board in the past 6 months but my sample set of 100 or so drives probably isn't very accurate. I have read about some compatibility issues with certain 'green' drives in raid arrays but other than that I would just search for the cheapest prices at stores with a good return policy, many prefer amazon. Overall, it's not a good time to buy hard drives (winchester, not ssd) mostly due to lack of competition.
RVWinkle is offline
post #8 of 15 Old 06-30-2012, 11:08 AM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 253
Green drives are fine in software raid arrays.
assassin is offline
post #9 of 15 Old 06-30-2012, 02:43 PM
bomberjim's Avatar
Quoted: 13 Post(s)
I agree with Assassin concerning green drives, if you're anticipating hardware raid you need to be very careful and do some investigation before selecting drives.
I recently purchased 3 Seagate St3000... 3Tb drives for use in my dedicated server. I wouldn't recommend them if using them in an HTPC or anyplace where noise is an issue. They have this hard to describe, periodic clanking/ratteling noise that I've not heard on any other drive. Unfortunately they tend to be one of the cheapest alternatives of late.
bomberjim is offline
post #10 of 15 Old 07-01-2012, 10:07 AM
xfett's Avatar
Sounds like there gonna fail.
xfett is offline
post #11 of 15 Old 07-01-2012, 10:14 AM
Quoted: 47 Post(s)
Liked: 42
Could just be the head parking.
post #12 of 15 Old 07-01-2012, 02:07 PM
bomberjim's Avatar
Quoted: 13 Post(s)
Exactly, it's not the "click of death". It would be extremely unlikely that all 3 basically new drives would be failing that quick. It's annoying though, can't recommend them.
post #13 of 15 Old 07-03-2012, 06:21 AM
djearl81's Avatar
Quoted: 12 Post(s)
I have a 3TB WD Green. If you power down your drives when they aren't in use I wouldn't recommend the green drives. They have built in power saving functions. I don't have data to back it up, but I think the extra wear and tear of the drive power saving and windows drive power saving is the reason I lost one of these drives a little while back. (The one I have now is the replacement for the failed drive.)
I know you are looking internal, but I have a 3TB external seagate that has been running like a champ.
I'm confused too.
djearl81 is offline
post #14 of 15 Old 07-03-2012, 06:25 AM - Thread Starter
bfhancock's Avatar
I've been considering daisy chaining externals until I can afford a storage server case. Does this work well? Is firewire sufficient for 1080p x264?
post #15 of 15 Old 07-05-2012, 01:31 PM
Tong Chia's Avatar
It depends on the version of Firewire that is used. The older spec is 400Mbit/s the newer one is 800Mbit/s.
Actual payload on Firewire 400 is about 200-250Mbit/s
Bluray off the disc tops out around 50Mbit/s, this gives you about 4 usable streams, more if the movie is re-encoded to reduce the bitrate.
When daisy chaining check the particular disk enclosure will keep downstream devices connected in the event of problems with the disk it holds.
Tong Chia is offline
Reply Home Theater Computers
