Issue with Logitech K400 keyboard/trackpad not getting into BIOS menu of HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-30-2012, 07:01 AM - Thread Starter
gtmtnbiker's Avatar
My HTPC is using GIGABYTE GA-Z68MA-D2H-B3 Intel Z68 Motherboard. I have the Logitech K400 keyboard/trackpad which works fine in Windows but for some reason, I'm unable to get into the BIOS selection menu (Press DEL to enter BIOS setup just does not work). At first, I thought it might be some setting with the motherboard where only a PS2 connector keyboard will work but then I used my Microsoft Natural Ergonomic 7000 keyboard/mouse and it works fine. Not sure why it doesn't work with the K400. I did try the K400 on a couple of other computers and I had no problems getting into the BIOS menu.
Do you think this is a bug with the BIOS? I guess I should contact Gigabyte to see what they think.
gtmtnbiker is offline
post #2 of 8 Old 06-30-2012, 08:27 AM
kegobeer's Avatar
Have you tried different USB ports for the dongle?
kegobeer is offline
post #3 of 8 Old 06-30-2012, 08:45 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
The K400 gets into BIOS on my ECS H61 mobo.
Mike99 is offline
post #4 of 8 Old 06-30-2012, 10:11 AM - Thread Starter
gtmtnbiker's Avatar
I had tried the one in the back but same effect. I guess I will go and try all of them. The Microsoft one works just fine in the front port that I normally use.
I have another Z68 Chipset board (ASUS P8Z68-V LX LGA 1155 Z68 ATX) where the K400 keyboard works just fine (Can get into the BIOS). Since the Microsoft wireless keyboard works just fine with the HTPC, I have to think it's a BIOS issue.
post #5 of 8 Old 06-30-2012, 11:59 AM
Zon2020's Avatar
Try doing it on a restart rather than a cold start. Sometimes that makes a difference.
Zon2020 is offline
post #6 of 8 Old 06-30-2012, 08:03 PM - Thread Starter
gtmtnbiker's Avatar
Cold start, warm start, usb 2.0 port, usb 3.0 port, front, back, left, right. Did not make a difference.
post #7 of 8 Old 07-01-2012, 01:58 AM
ben7337's Avatar
Quoted: 24 Post(s)
Some mobo's have a feature I believe, in the bios, to keep from initializing or using anything plugged in via usb on boot. I could be wrong but I think some have that. So wireless keyboards don't work for getting into bios unless you turn that feature off or enable usb devices on boot. Did you look all over your bios for a feature like that?
ben7337 is offline
post #8 of 8 Old 07-01-2012, 07:11 AM - Thread Starter
gtmtnbiker's Avatar
There's nothing like that in my BIOS other than something that says "Enable Legacy USB Support". Toggling it doesn't do anything.
What's really puzzling is that my Microsoft Natural Ergonomic 7000 keyboard/mouse works fine (It's also wireless). That keyboard & the Logitech K400 work fine (get into the BIOS) for my desktop PC. Bizarre.
Reply Home Theater Computers
