Sharing USB tuner over network - AVS Forum | Home Theater Discussions And Reviews
Old 07-01-2012, 07:15 AM - Thread Starter
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
Can't seem to find the answer to this.
I have a WinTV-HVR-850 usb tuner stick that I'd like to connect to my media server (Win 7) and be able to access from other computers on my network. No DVR function needed, don't really even care about channel guides.
Is this a WMC/extender task or is there another way to accomplish this?
DanPackMan is offline
Old 07-01-2012, 08:41 AM
kegobeer's Avatar
You can't share that USB tuner to other computers. If you want to do that, you have to buy a networked TV tuner.
kegobeer is offline
Old 07-01-2012, 08:50 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 398
Yes, you will need WMC extenders which does not work on any PCs.
As for whether or not you can share the USB tuner on the network is dependent on the design of the tuner as well as the additional driver/software to make it happen. Ceton tuners, for example, make be configured to share on the network because the tuner itself is using USB as network transportation.
Foxbat121 is offline
Old 07-01-2012, 09:12 AM - Thread Starter
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
Thanks for the replies, confirmed what I was suspecting.
Old 07-01-2012, 02:36 PM
puzzledshrug's Avatar
Trying to wrap my head around OTA Tuner network sharing.
If I purchase a something like
HDHomeRun DUAL - High Definition Digital TV Tuner (Network Attached) HDHR3-US (Black) by SiliconDust
and connect it to GB port on my router will this allow Ethernet attached HTPCs to stream television to attached HD Televisions?
Or does this only allow HTPC with its own monitor (Not HD TV) accept the TV channels?
Not interested in any cable tv streaming only OTA.
thanks for any input!
puzzledshrug is offline
Old 07-01-2012, 02:42 PM
kegobeer's Avatar
Networked tuners require a computer connected to a TV in order to function. Connect the tuner to your network, install the required software on each computer that will use the tuner, connect the computer to any television, and watch TV.
kegobeer is offline
Old 07-01-2012, 04:15 PM
Old 07-01-2012, 05:03 PM
Boke01's Avatar
You can share it using either MediaPortal or NextPVR.
Boke01 is offline
Old 07-01-2012, 06:49 PM
TheTinkerer's Avatar
I use media portal. 5 tuners on the server all shared across 4 HTPC's. If 3 TV's want to watch the same channel it uses only 1 tuner.
TheTinkerer is offline
Old 07-02-2012, 05:20 AM - Thread Starter
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
Thanks, I'll give Media Portal a try.
Old 07-12-2012, 08:31 AM
Macromir's Avatar
You can try to solve this problem with software solution - USB network gate, it shares USB devices via internet an lan - http://www.net-usb.com/ I use it to sahre my scanner between 2 PCs for a year now
Macromir is offline
