Best solution for HTPC with Cablecard - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-04-2012, 03:06 PM - Thread Starter
Deihmos's Avatar
Quoted: 43 Post(s)
I have been using XBMC on my HTPC for years and recently got a cablecard so I am using WMC with it. I would prefer to have one software that would do it all instead of switching back and forth. Can anyone using a cablecard tell me what setup they used?
Deihmos is offline
post #2 of 14 Old 07-04-2012, 03:30 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
Currently there is none. WMC+Mediabrowser is your best bet if you want a single solution.
assassin is online now
post #3 of 14 Old 07-04-2012, 04:29 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yup.
But isn't there an XBMC plug-in for WMC?
Sammy2 is offline
post #4 of 14 Old 07-04-2012, 04:30 PM - Thread Starter
Deihmos's Avatar
Quoted: 43 Post(s)
I tried that solution and frankly I think mb sucks mainly because of WMC. It is really leggy and in mkv videos there's no ff or rewind. Since there is nothing else I might as well stick with Xbmc and WMC.
Sent from my iPad using Tapatalk HD
Deihmos is offline
post #5 of 14 Old 07-04-2012, 04:58 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
Mine isn't laggy at all with WMC+MB. The ff/rew needs improvement as does subtitle control in WMC.
post #6 of 14 Old 07-04-2012, 04:58 PM
Mr. Pseudonym's Avatar
WMC + My Movies works best for us.
2nd choice would be WMC + Mediabrowser.
Mr. Pseudonym is offline
post #7 of 14 Old 07-04-2012, 05:05 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Subtitle control in MPC-HC/MadVR is very polished.
ff/rw.. Meh..
Sammy2 is offline
post #8 of 14 Old 07-04-2012, 05:33 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
ff/rw.. Meh..
All of the above are polished in XBMC.
Can't wait until it has a real DVR.
post #9 of 14 Old 07-04-2012, 05:37 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
When it supports CableCARD I'll consider switching.
Sammy2 is offline
post #10 of 14 Old 07-04-2012, 08:15 PM
rantanamo's Avatar
good luck on that. cablecard restrictions are getting tighter. FiOS was one of the few out there you could use, but not anymore.
rantanamo is offline
post #11 of 14 Old 07-04-2012, 08:28 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Yup.
Yes if you type XBMC Integration Tool in Google you come up with this... http://xbmcwmc.teknowebworks.com/
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #12 of 14 Old 07-04-2012, 08:30 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Media Browser is likely less problematic than XBMC. I recently added my TV and Movie folders and..... Two TV series are missing.....On the server yes, show up in XBMC, nope. Maybe it will sort itself out, but still... When people call XBMC polished, I just have a smirk on my face.
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #13 of 14 Old 07-04-2012, 08:31 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
All all great. None are perfect.
I say this all the time.
post #14 of 14 Old 07-06-2012, 06:11 AM
hockeyrcks9901's Avatar
You can still use FiOS perfectly fine. You just can't switch the device the cable card is in without reactivating it. As long as it is paired with the device, it works great.
hockeyrcks9901 is offline
Reply Home Theater Computers
