My New Budget HTPC Build - AVS Forum | Home Theater Discussions And Reviews
Old 07-04-2012, 08:58 PM - Thread Starter
joe531's Avatar
This build is a wee bit on the budget side. Namely, wired keyboard/mouse, used HDD and non-HTPC case. The rest seems to be suitable. The parts arrive on Friday (would have been Thursday but you know, a certain nation's birthday today.)
Rosewill Micro ATX Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147112
Intel Pentium G620 CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116399
Gigabyte GA-B75M-D3H Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128555
G.SKILL 4GB RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231396
Cooler Master PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171046
Logitech M/K
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126220
Rosewill Card Reader
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
Windows 7 HP OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Rosewill Media Center Remote
http://www.newegg.com/Product/Product.aspx?Item=N82E16880101007
I'm going to use the HDD in my old netbook until the price of hard drives comes down a little. Also, I'm planning to upgrade to an Ivy i3 in the near future. Proper case, Blu-ray drive and Wifi card are also planned expansions for the future.
joe531 is offline
Old 07-07-2012, 02:02 PM - Thread Starter
joe531's Avatar
Here are a couple of pics (sorry for the quality, I only have a 3.2mp phone cam):
By joey5312012 at 2012-07-07
I have to admit, the case doesn't look that bad on it's side. It's sitting next to my Wii and the keyboard is hidden away on top of the case. I decided to use a faster HDD from my main PC and give it the netbook drive.
On the software end of things, Windows 7 Home Premium 64-bit and XBMC Aeon MQ3 skin.
joe531 is offline
Old 07-07-2012, 02:09 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Looks like a great build. We need more posts like this.
joe531 likes this.
assassin is offline
Old 07-07-2012, 02:19 PM - Thread Starter
joe531's Avatar
joe531 is offline
Old 07-07-2012, 03:13 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
joe531,
Let me know how you like the Rosewill RHRC-11001 remote.
I bought the Rosewill RRC-126 on sale, however I find it too narrow with small buttons. According to Newegg’s website these both have the same dimensions, 1.57" x 7.28" x 0.94". However if I look at the Rosewill RHRC-11002, which looks similar to the 11001, it is 2.13" x 7.09"x 0.79".
It makes me wonder if the 11001 is really 1.57” or 2.13” wide. If you get a chance please let me know if yours is closer to 1.5” or 2”. FWIW the 126 does measure about 1.5”
Thanks in advance.
Mike99 is offline
Old 07-07-2012, 03:23 PM - Thread Starter
joe531's Avatar
Hmm, I don't have a ruler on hand but by eyeballing it, I'd say it's closer to 2. And the remote's not bad. You do have to press hard though to make the buttons send the signal to the receiver.
joe531 is offline
Old 07-08-2012, 01:47 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
joe531,
Thanks for checking. My RRC-126 button presses seem normal, however I'd like to get a remote that better conforms to my hand. Something similar to my Dish remote.
Mike99 is offline
Old 07-08-2012, 08:29 AM - Thread Starter
joe531's Avatar
Sure, no problem. This remote does have a nice feel in my hand. I used to have one of the longer, glossier remotes awhile back. This one here: http://www.amazon.com/gp/product/B000W5GK5C/ref=oh_details_o06_s00_i00. I can't say that one was very ergonomic.
joe531 is offline
Old 07-08-2012, 08:42 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Why not keep the IR dongle and get a universal remote? The Xsight 12G has a great feel, is very inexpensive and has much better macro capabilities than harmony. That way you can integrate and control all your home theater devices, not just your PC.
mdavej is offline
Old 07-08-2012, 09:03 AM - Thread Starter
joe531's Avatar
I'll probably do that eventually.
joe531 is offline
Old 07-08-2012, 12:07 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Guys look into Flirc. If you have a remote that you love then its a great option to be able to use that remote. Its not mentioned enough on AVS.
assassin is offline
Old 07-08-2012, 12:37 PM - Thread Starter
joe531's Avatar
That looks pretty cool!
joe531 is offline
Old 07-08-2012, 01:15 PM
mdavej's Avatar
Liked: 940
Sorry, that reply was meant for Mike99 who doesn't like his remote. On second thought, the Xsight 18G is more similar in size to a Dish remote but more expensive than the 12G. I personally find a universal remote indispensable in a home theater. I much prefer to press one button to watch tv rather than a dozen or more.
Anyway, getting back on topic, nice build, Joe.
mdavej is offline
Old 07-08-2012, 01:38 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Thanks for the suggestions & I'll look into those.
I do use my Harmony one button function to turn on everything & it works great for that. I usually watch the Dish DVR and I find it's remote more comfortable & better laid out than the Harmony's. Once everything is fired up I use the Dish remote which also seamlessly controls the A/V receiver's volume & mute.
Mike99 is offline
Old 07-08-2012, 01:56 PM
mdavej's Avatar
Liked: 940
Didn't realize you already had a harmony. In that case, Xsight won't be much different. Sounds like all you need to do is some button customization to match the layout and functionality of your other remotes and set up your activities properly. Harmony should seamlessly control your AVR volume as well. But Harmony's default button assignments usually stink. You really need to change them for best results.
mdavej is offline
Old 07-08-2012, 02:01 PM - Thread Starter
joe531's Avatar
lol No problem.
joe531 is offline
Old 07-08-2012, 06:22 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
The Harmony 550 is a few years old & does work quite well. But the volume +/- buttons really blend in to each other & the surface of the remote. These, & the channel +/-, are the only buttons like this. It's as if there was one plastic volume button & Harmony sliced it in half. You almost need a fingernail in order to find the split where one ends & the other begins. I'll have to see what can be re-assigned.
Mike99 is offline
Old 07-09-2012, 08:22 AM
C17chief's Avatar
Liked: 24
I had one of those as well. I think that style was just built extremely cheap. Besides that issue with some of the buttons, some stop responding well. I found this out after my down arrow would no longer respond without significant effort mashing down on it...read on the internet I am not alone and different people have different keys giving them same sort of problems. Also just felt cheap with creaky plastic and all. Other then that it was just fine. I think they just cheaped out with build quality on that style. Luckily I lucked out when bestbuy had the harmony one's for $49 awhile back. Picked up 2, sold one for $120, so end result was I got a free upgrade to the one, which is a night and day difference in feel. biggrin.gif
C17chief is offline
