Looking for a compact single USB 2 to wireless converter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-05-2012, 12:54 AM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I need a very compact solution to convert USB 2.0 to wireless. The only products that I can find is discontinued. If someone can find the below brand new or another one that could replace it, please let me know (not looking for multiport wireless USB device since they are too big).
http://www.amazon.com/Cables-Unlimited-Wireless-Transmitter-Receiver/dp/B0036VNZHA/ref=pd_bxgy_cps_img_c
MKANET is offline
post #2 of 11 Old 07-05-2012, 09:20 AM
hirent's Avatar
How much space do you have?
Can you use an USB extension cable to bring the connection elsewhere?
Newegg has a bunch of these micro/nano USB adapters.
Check out the specs and reviews and see which one works best for you.
Though with this kind of design, the range will probably be limited.
The EDIMAX nano adapter has 480 reviews, seems popular as well as cheap; only 10 bucks.
hirent is offline
post #3 of 11 Old 07-05-2012, 10:04 AM
Zon2020's Avatar
I don't know how small you need, but I bought a couple refurbished Linksys/Cisco AE1000 300Mbps 802.11n Dual-Band Wireless LAN USB 2.0 Adapter w/Extension Cable from Amazon, and they still have them for only $13.99, and they really work great. They don't seem any bigger than the one in your linked picture. Cisco also has the AE 1200 for $16.99 and the AE 2500 for $19.99 refurbished on their website.
But if you want something really small, you might prefer something like the D-Link DWA-131 or Belkin F7D2102.
Zon2020 is offline
post #4 of 11 Old 07-05-2012, 10:27 AM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I really wish I had a way to explain this more clearly. I'm guessing you guys didn't actually see the link the first post.
I am looking for a USB 2.0 ---> Wireless CONVERTER, not USB 2.0 wireless dongle; which is already available everywhere.
These things dont really have a standard name. I think a less confusing name would USB wireless kit with transmitter and receiver.
I don't blame you guys for not know what this type of device is. They were never really that popular since they only work with a very limited range of products; hence lot of bad reviews.
MKANET is offline
post #5 of 11 Old 07-05-2012, 10:32 AM
Zon2020's Avatar
Sorry about that. I did misunderstand. Without looking, I wonder if there are also bluetooth devices that do what you're looking for?
Zon2020 is offline
post #6 of 11 Old 07-05-2012, 10:34 AM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Audioengine makes a wireless USB DAC that has a digital output, it would work, but it's fairly expensive.
saeyedoc is offline
post #7 of 11 Old 07-05-2012, 10:57 AM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Wow, thanks for all the responses! I need something very small that even with a battery pack, the transmitter can fit in someone's pocket. I don't need it for audio.
When the Cables Unlimited Wireless USB Kit was still available at Amazon a month ago, I didn't think it was actually think it was the only commercial product in existence that's this small and priced at $50 that does this.
I guess if nobody knows of such a product, I will have to go hunting for the Cables Unlimited Wireless kit at smaller online stores. It's really too bad that Cables Unlimited went out of business. I was at least able to find the Win7 64 software/drivers for this in case I do find the product for sale online.
MKANET is offline
post #8 of 11 Old 07-05-2012, 12:24 PM
hirent's Avatar
Gotcha.
I did look at the link but simply added USB and Wireless to come up with Wireless USB adapter.
Have you checked ebay?
Sometimes these kind of products abound on ebay.
hirent is offline
post #9 of 11 Old 07-05-2012, 12:39 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Yes, I check EBay. Unfortunately, without knowing exactly what product I'm looking for, it doesn't help much since this kind of a product doesn't have a category of its own. Typing in wireless USB brings up pretty much only usb wifi dongles. I was hoping someone had a similar need as me in the past. I die find one vendor that definitely has the item I posted in the first post. So, I ordered it. If I find something else that's beter its not too late to return it.
MKANET is offline
post #10 of 11 Old 07-05-2012, 04:19 PM
Tong Chia's Avatar
Are you looking for a wireless usb extender?
http://www.iogear.com/product/GUWH204KIT/
The receiver side looks quire small
Tong Chia is offline
post #11 of 11 Old 07-06-2012, 11:07 AM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Yes exactly. Except a compact one meant for a single device like the one in the original post.
MKANET is offline
Reply Home Theater Computers
