Regression in Nvidia Drivers - 3D and HDMI Audio since 280.26 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-06-2012, 09:03 PM - Thread Starter
jmelan's Avatar
Quoted: 57 Post(s)
Liked: 33
Well this may just be a very specific problem, but none of th Nvidia WHQL drivers released since 280.26 are functioning correctly in my HTPC setup ever since the infamous 285.62 drivers broke 7MC (really good QC there). It seems unlikely that this is a coincidence, likely resulting from whatever fix was put in place after 285.62.
Problem:
HDMI audio only works after a computer restart. When i turn off the TV and turn the TV back on, HDMI audio is not detected and I am unable to watch recorded TV or anything else.
Setup:
Sony XBR 52 HX909 - via either HDMI or DVI-->HDMI (multiple monoprice old and high speed HDMI cables)
EVGA nvidia gt 430
nvidia 3dtv play
any nvidia drivers from 285.62 and on
This problem is not present when I unplug the 3d transmitter from the TV, at least on the most recent WHQL drivers.
This seems like an obvious bug in the Nvidia drivers.
I attempted to clone the EDID data from when the TV is connected just after restart and install as in Tulli's EDID override thread without any change in behavior.
I would be happy to hear any suggestions for a solution.
thanks!
jmelan is offline
post #2 of 4 Old 07-07-2012, 08:44 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Well, I'm still at 275.33. These are the only drivers (maybe 280.26 too, but I'm not sure) that really work for me (GTS 450), especially with custom resolutions. Unless you have a Kepler card there should be no need of installing latest drivers. But if needed you could just use the latest version of the graphic driver + an older HDMI audio driver.
jmelan likes this.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #3 of 4 Old 07-07-2012, 07:31 PM - Thread Starter
jmelan's Avatar
Quoted: 57 Post(s)
Liked: 33
thanks tulli!, that is a great point regarding the separate install of the hd audio driver. for now, i will just stay with 280.26.
I was considering an upgrade to the gt 640 when it drops in price a bit, but did not want to risk having to use newer drivers.
jmelan is offline
post #4 of 4 Old 07-08-2012, 01:27 PM
Tong Chia's Avatar
Originally Posted by jmelan View Post
Problem:
Had a similar problem since 285.xx, I will lose HDMI audio after resume and I had to reboot to get HDMI audio back. HTPC connected to an Onkyo 805 AVR, card is a GTX460.
I updated to 301.42 and the problem has not returned it has been about a week. This is on 64bit Win7, never seemed to have the problem on 32bit Win7 running on another machine running another GTX460 (same batch bought the same time), both motherboards have the X58 chipset.
Tong Chia is offline
Reply Home Theater Computers
