Wanting to convert .MKV files to .AVI files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-07-2012, 09:17 AM - Thread Starter
WoodiE55's Avatar
I have some .MKV files that I'd like to convert to .AVI files, what software would work best for this conversion?
WoodiE55 is offline
post #2 of 9 Old 07-07-2012, 09:39 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Why? MKV is a better container, imo.
assassin is offline
post #3 of 9 Old 07-07-2012, 10:28 AM
jlchavis0844's Avatar
Avi files do have better compatability with hardware players. Use xvid4psp. It's a pretty good all-in-one convertor.
jlchavis0844 is offline
post #4 of 9 Old 07-07-2012, 10:29 AM
Krispy Kritter's Avatar
Quoted: 53 Post(s)
I agree. And every conversion reduces quality. For best results, you need to go from the source to the desired codec to minimize any loss in quality. Any further conversions reduce quality. Not to mention that to maintain the current quality (as much as possible...some will be lost), the file size in avi format will increase.
In any case, give vidcoder a try. It's basically a GUI for handbrake.
Krispy Kritter is offline
post #5 of 9 Old 07-07-2012, 10:30 AM
wwylie8643@sbcgl's Avatar
I've used xmedia recode. Works well.
wwylie8643@sbcgl is offline
post #6 of 9 Old 07-07-2012, 10:30 AM
Quoted: 53 Post(s)
Should be a non-issue in the HTPC board.
post #7 of 9 Old 07-07-2012, 05:55 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
No loss of quality if you simply repackage the content. AVIDeMux is a program that can repackage files. Open the file, pick 'Copy' for video and audio and select AVI for the container. Don't forget to add the .AVI to the save filename.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 9 Old 07-07-2012, 09:44 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Is it really worth the effort? Why not buy something like the original WDTV for $30 off ebay.
StinDaWg is offline
post #9 of 9 Old 07-08-2012, 02:50 PM
Quoted: 53 Post(s)
True, but the same could be said for mkv. However, when most people talk about conversion, they are referring to changing the codec used, not simply moving content untouched to a different container.
Reply Home Theater Computers
