Silverstone ML03B or nMEDIAPC 1080P case? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 07-09-2012, 02:35 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I’d like to transfer my HTPC components from a mini tower case to an HTPC style case. I’ve been looking at the Silverstone ML03B and nMEDIAPC 1080P because they are reasonably priced & appear to have a nice form factor. I’m in no hurry & am waiting for a sale.
Any thoughts or experiences with these?
Mike99 is offline
post #2 of 23 Old 07-09-2012, 04:42 AM
Scallica's Avatar
I have the nMedia 1080p case and would recommend it. The 1080p can accommodate a memory card reader, LCD screen, and has a hinged front panel which hides both the memory card reader and the optical drive.
I suggest using a modular power supply for either case.
194
HTPC Enthusiast
Scallica is offline
post #3 of 23 Old 07-10-2012, 09:41 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I too have the 1080p and I like it. I put a $6 LED clock from Target that I took out of its shell. The LCD that comes from nMedia is useless if you are more than 2 feet away from the screen. It is just too tiny, and all my wife wanted "clock, just like the DVR"
I am not using modular PSU, just regular, cheapo 80+ certified unit.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #4 of 23 Old 07-10-2012, 11:22 AM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 62 Post(s)
Liked: 98
I think it comes down to aesthetics. I like the looks of the Silverstone better. I just put together a unit using the MILO. Because of the dimensions of both cases, they can be tough to work in. I think the 1080p might be a better choice if you are planning for multiple 3.5" drives. Despite the ability to physically house (3) 3.5" drives, (5) 2.5" drives, and (1) ODD, space gets tight real quick if you do use an ODD, and the number of HDD's and SSD's greatly deminishes. I've got to monkey around a bit on the insides, with cabling. I disagree that you need a modular PSU, but you do need to do your research to determine which ones will fit based on your needs. Anyone considering the MILO needs to download the manual from the Silverstone site and read it. There are a lot of bad reviews of the MILO, and mostly because the reviewers didn't plan properly. It really is a nice case.
I have the following squeezed in the MILO:
MB - Asus P8H77-M Pro
PSU - Corsair CX430
ODD - Lite On Blu Ray Burner
SSD - Crucial m4 128
HDD - WD 500GB Green
RAM - 2x2 Corsair Vengence LP DDR3 1600
CPU - i3-2120
Fans - x 2 80mm Enermax UC-8EB
I'll post pics when done squaring things away.
wiley165 is offline
post #5 of 23 Old 07-10-2012, 11:27 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Thanks for the positive comments on the nMedia 1080p case. According to the specs it's a little deeper than the Silverstone case. I don't think shallower depth of the Silverstone would be major concern but more room in the 1080p case certainly will not hurt.
I just need to wait for Newegg to have a sale and/or free shipping.
Mike99 is offline
post #6 of 23 Old 07-10-2012, 01:24 PM
Andrew Hornfeck's Avatar
Quoted: 31 Post(s)
They just HAD it on sale for $50 (plus 9.99 S/H) and I picked mine up from Amazon a few weeks back for $59.99 FREE S/H (and it's still available there). I found the build a bit tight and questioned air flow considering cable management/placement. On mine I have 2 x 3.5" 1TB HDD, 1x2.5" 64GB SSD, F1 BioStar, A6-3500 APU w/stock HSF, 2x2GB GSkill RAM and an Antec 380-Green PSU. The SSD mounts on the floor about 3mm in front of the PSU using exterior screws. My mobo has the USB-3 connection for the front ports and 4 RAM slots, only using 2. The cable routing was tricky and had to dry fit the 3.5" HDD atop the Black Nylon mounting bracket along with the power cable and front-panel cables. Also, the other 3.5" HDD is on the floor under the ODD mounting location... I think all three of these drives could benefit from 6" SATA cables to reduce the unnecessary cable length & enhance air flow. The system seems to be running at 26C and the HDDs at 39C with only the PSU & CPU fans! The mobo does a good job managing the 4-pin CPU fan. All in all I liked the appearance of the SilverStone and it seems to be working out OK. I may get the 6-inchers and try a low noise 80mm fan to see if I can drive the HDD temps down a tad.
@Wiley165 -- how's that PSU mounted? According to the manual a 120mm fan should mount DOWN which simply cools the PSU from underneath the case and out the rear, right? I opted for an 80 rear-mounted PSU fan to provide some air movement from inside the case. What are your thoughts/observations?
Andrew Hornfeck is offline
post #7 of 23 Old 07-10-2012, 01:47 PM
wiley165's Avatar
Quoted: 62 Post(s)
Liked: 98
@ Andrew - I have the PSU mounted with the 120mm fan facing down taking advantage of the pre-installed filter. So you are correct that essentially that fan will only cool the PSU. The stock Intel cooler will draw air in from the top of the case, and I have that exhausting with the (2) 80mm case fans. I have (4) total of the Enermax fans, but want to keep noise to a minimum - balanced with airflow. What I liked about the CX430, is that there are fewer connectors compared to other PSU's that are similar in size. Fewer connectors = fewer things to hide. My latest thought is to eliminate the Nylon/Plastic bracket to give the case more interior space, and hopefully better airflow.
wiley165 is offline
post #8 of 23 Old 07-10-2012, 03:02 PM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
wiley165,
Looks like you were typing about the same time I was & I missed your original posting.
Andrew,
Which case are you referring to, the 1080p? Every time I look Newegg has it for $49.99 +$9.99 shipping. Why is it that a small tower case can be had for $25 but not an HTPC case?
Mike99 is offline
post #9 of 23 Old 07-10-2012, 03:21 PM
Quoted: 31 Post(s)
Good catch... I'm referring to the SilverStone ML03B as I thought you were waiting to be on sale. Seems BOTH of us were slightly unclear in our posts. I suppose it's clever marketing of HTPC that drives the price up - sorta like buying a HDTV Digital UHF antenna! Personally I'm enjoying the SilverStone. Its form, fit, finish is all nice. The USB-3 connection just fit onto my mobo. Buttons are smooth and I'll be placing it in my bedroom on a shelf I used to have my DirecTV box!
post #10 of 23 Old 07-18-2012, 08:22 PM
wiley165's Avatar
Quoted: 62 Post(s)
Liked: 98
Finally got everything up and running. Here are a couple pics inside the ML03 (Milo).
The HDD is under the ODD (Lite-On BluRay Burner). Left the SSD on the bracket. All the unused power cords are tucked in between the PSU and ODD/HDD bracket. The 2 Enermax fans are whisper quiet. Honestly the only thing you can hear is the ODD at times. All the fans are inaudible.
Just a note, Ideally I would have put the HDD on the plastic bracket, but it is nearly impossible with the 24pin ATX and USB 3.0 header placement with this board, though it is doable. An HDD (3.5") has to fit slightly under the lip of the chassis in that spot. Board selection is critical if you're going to pack this case full.
wiley165 is offline
post #11 of 23 Old 07-18-2012, 10:15 PM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
wiley165,
Thanks for sharing.
I would like to see one of these cases in person. Fry's has some Silverstone cases such as the GD04 & GD05, so at least I can see something of what they make. But nMEDIAPC seems to be sold only by Newegg.com & Directron.com, both online stores. At this time I'll just wait for a sale as I'm in no hurry.
Mike99 is offline
post #12 of 23 Old 12-05-2012, 03:48 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2699
Mike99 did you ever decide ?
Mfusick is offline
post #13 of 23 Old 12-05-2012, 06:10 PM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I'm the one who re-used my old Dell PC case & hide it in the corner. At this point in time I see no reason to change the setup. But if I did decide to rebuild the HTPC then there's a .99 probability that I'd go with the ML03 case.
Mike99 is offline
post #14 of 23 Old 12-06-2012, 06:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2699
Yeah I know that's what I thought .
I'm curious about that case.
That's why I asked.
Mfusick is offline
post #15 of 23 Old 12-07-2012, 09:02 AM
jhhoffma's Avatar
I have both, and it would depend upon the usage for what I would recommend.
If you prioritize sound level over appearance/functionality, go with the Silverstone. Much more open case, better ventilation (I'm not using any chassis fans in mine, just CPU PSU and passive ventilation).
If you like the media component look and don't mind a little white noise, then the nMedia is more to the liking. Tried to use the nMedia pico-PSU with this case (silent), but it wasn't powerful enough for the build and you really need the PSU van to aid in cooling the case.
However, I'm quite simple in my needs. I always rip out any HDD cage and use sorbothane pads to mount a drive on (even if it's SSD--I'm obsessed), so I don't ever have more than one drive installed, as I have my WHS for storage.
For your PC silencing needs...check out www.silentpcreview.com
For your WHS needs...check out www.wegotserved.co.uk
jhhoffma is offline
post #16 of 23 Old 12-07-2012, 10:37 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
It would be nice to see a nMEDIAPC 1080P case, but their website "where to buy" lists only 2 online sources. I did notice the depth was about 3" more than the ML03 which may be a factor for some people.
Mike99 is offline
post #17 of 23 Old 12-09-2012, 07:48 PM
jhhoffma's Avatar
What's wrong with Newegg?
jhhoffma is offline
post #18 of 23 Old 12-09-2012, 09:41 PM
tomandbeth's Avatar
Son of a gun...THAT's a slick and obvious solution to a little problem I have.
tomandbeth is offline
post #19 of 23 Old 12-09-2012, 11:49 PM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Nothing is wrong with Newegg & I do buy from them. My posting said it would be nice to see an nMEDIAPC case but I can't do that from an online vendor. Therefore I have no first hand knowledge or experience regarding the quality of their products.
Mike99 is offline
post #20 of 23 Old 01-04-2013, 12:52 PM
pkscout's Avatar
Quoted: 12 Post(s)
I just finished my build with the ML03. It's a nice case, but things can definitely be tight.
http://www.avsforum.com/t/931459/show-your-htpc-setup/960#post_22783107
pkscout is online now
post #21 of 23 Old 01-05-2013, 01:11 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Thanks for sharing & posting the photos.
Mike99 is offline
post #22 of 23 Old 01-05-2013, 12:12 PM
Quoted: 31 Post(s)
I too built the ML03 and did manage to install my SSD on the bottom behind the PSU and have 2 of the WD Green SATA-III 2TB HDDs (one under the Optical (in from the side) and the other on the pedistal where you mounted your SSD). I'm running a stock AMD A6-3500 with no case fans and it's amazingly cool! My BIOS allows several CPU fan options - I'm running what it calls quiet mode. Sure, it's a tight install but the results are fantastic! (Can a mainlander say: Aloha!)
post #23 of 23 Old 01-20-2013, 01:51 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2699
Congrats!! Thanks for sharing !
Mfusick is offline
Reply Home Theater Computers
