Why does MB hate the Transformers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 07-09-2012, 02:19 PM - Thread Starter
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
Hey Everyone,
I'm having trouble getting "Transformers: Dark of the Moon" to play in Media Browser. I've tried ripping it from 2 separate blu-ray discs using MakeMKV. Both rips do the exact same thing when played in MB but both work fine if I use a standalone player (VLC). Any suggestions?
338
337
Dropkick Murphy is offline
post #2 of 44 Old 07-09-2012, 02:56 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
MB is not alone in this.
Sammy2 is offline
post #3 of 44 Old 07-09-2012, 03:39 PM
xfett's Avatar
Are you using Shark007 codec pack ? It is a True HD 7.1 title so make sure your settings are correct. Does it try to play then just go black screen or is there a hiccup/stutter then nothing...just sits there? Double check your setting. Make sure they are the same...if you have Win 7 64.
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #4 of 44 Old 07-09-2012, 03:50 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 89
Using LAV Splitter
Audio: 455
Video: 473
The screen just shows the second pic of my first post, it will not play
post #5 of 44 Old 07-09-2012, 03:57 PM
xfett's Avatar
Go thru ALL of your setting in Shark007. Like I said if your using Win 7 64...make sure Shark007 and Shark007 x64 have the same settings not just the LAV settings.
xfett is offline
post #6 of 44 Old 07-09-2012, 04:04 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 89
I don't use Shark 007, LAV only. Interesting note about the 7.1 though. I went through all my BR rips and found only one other 7.1 - "Tron: Legacy" it's DTS-HD MA but it plays fine in MB.
I was under the impression that you would use either Shark 007, or LAV not both. Am I wrong?
post #7 of 44 Old 07-09-2012, 04:14 PM
xfett's Avatar
Shark includes LAV as well Haali...and others included in one program.
xfett is offline
post #8 of 44 Old 07-09-2012, 04:19 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
It does indeed.
I use LAV for all my library playback (Video, Audio and Splitter) but when I was having issues with live TV, an installation of Shark007 cleared things right up for me.
Sammy2 is offline
post #9 of 44 Old 07-09-2012, 04:21 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 89
If I install Shark 007, should I uninstall LAV?
post #10 of 44 Old 07-09-2012, 04:31 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
If you are going to give that a try, uninstall LAV first and let shark007 re-install it. That said, I think that this is not an issue that will be cleared up by shark007. Does your hardware support Dolby True HD?
Sammy2 is offline
post #11 of 44 Old 07-09-2012, 04:40 PM
xfett's Avatar
On my setup I must enable "set the merit of ffdshow to normal" on the H264 tab (in Shark007) in order to get Dark of the Moon to play.
xfett is offline
post #12 of 44 Old 07-09-2012, 05:02 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
xfett, are you using LAV at all?
I think it is a ffdshow codec too.
Sammy2 is offline
post #13 of 44 Old 07-09-2012, 05:16 PM
xfett's Avatar
Yes I do use LAV but like I said the only way to get Dark of the Moon to play was to change the settings.
xfett is offline
post #14 of 44 Old 07-09-2012, 05:22 PM
Dark_Slayer's Avatar
Quoted: 721 Post(s)
Liked: 449
Agreed, I had used LAV only the way your first screen indicates Dropkick, and it played this and other trueHD videos just fine. Are you sure that the receiver supports TrueHD?
Dark_Slayer is offline
post #15 of 44 Old 07-09-2012, 05:32 PM
xfett's Avatar
If he can play DTS-HD audio he should be able to play TrueHD. I dont know of any AVRs that only encode DTS-HD.
xfett is offline
post #16 of 44 Old 07-09-2012, 06:07 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 89
I don't think it's a hardware issue
Core i3-2120
> GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 ----(HDMI)----> Yamaha RX-A1010
(HDMI)
> Pioneer Plasma
Maybe I'll try ripping it again without the HD Audio just to see if that's the problem.
post #17 of 44 Old 07-09-2012, 06:21 PM
Quoted: 721 Post(s)
Liked: 449
Core i3-2120
(HDMI)
> Pioneer Plasma
No it's not hardware, was your software setup per Assassin?
Fair enough, it doesn't hurt to ask. The problem you were having, xfett, is with FFDshow and TrueHD. Shark has acknowledged and provided a fix in his forums, but not yet updated his recommended settings. (At least not as of 7/7/12 when I last tried his settings and it broke playback of my TrueHD files) http://shark007.net/forum/Thread-MKV-with-TrueHD-won-t-play-in-MC
post #18 of 44 Old 07-10-2012, 04:51 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 89
Okay, so I re-ripped the disc without the HD audio (DD 3/2+1 only) and it plays perfectly. I may try Shark's codec this weekend if I get some time but for now DD suits me fine.
post #19 of 44 Old 07-10-2012, 06:42 PM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
I may try Shark's codec this weekend.
From my Setup and usage page...
"To playback MKV's containing TrueHD audio, either select the LAV splitter on the MKV TAB or Disable LAV audio on the Audio TAB."
I continue to default the MKV splitter to Haali because the benifits outweigh the issues. (at this time)
The one major issue when using Haali to split MKV files is TrueHD support is broken.
For simple setup of my software, select the [x] SUGGESTED settings checkbox (which sets LAV to do most decoding with subtitles enabled)
Then go to the Audio TAB and select your Audio configuration from the upper right. The leftside speaker selection is automated, allow that, leave it be. This will playback almost everything except TrueHD as outlined above
Use Shark007 Codecs and retain your sanity.
Shark007 is online now
post #20 of 44 Old 07-11-2012, 12:34 PM
Quoted: 721 Post(s)
Liked: 449
Try it out, use his instructions.
Still puzzled that your LAV setup didn't work. I've used them w/o Shark's and didn't have any problems with TrueHD. Follow the WMC knowledge base guide again to make sure. Or just be happy with DD. I didn't purchase a new AVR to listen to standard DD, but it's a personal choice
post #21 of 44 Old 07-12-2012, 05:13 AM - Thread Starter
Quoted: 72 Post(s)
Liked: 89
I have other movies in my collection that are TrueHD that play without a problem. This is the only one currently in my collection that is 7.1. Maybe I'll stop by Best Buy today and pick up another 7.1 disc just to test the theory.
Anyone seen any good movies lately?
post #22 of 44 Old 07-12-2012, 09:45 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Dances with Wolves
3:10 to Yuma
Hugo
To name a few but I think that they're all dts-HD/MA and not Dolby TrueHD.
Sammy2 is offline
post #23 of 44 Old 07-12-2012, 10:49 AM
mcnauge's Avatar
I am having the same problem...
Any DTS, DTS-HD and TrueHD (5.1) mkv files play perfectly. However, i used makemkv like usual to convert the movie and when i try to play it i get no video, no audio and the track length says its 523 Hours...
Just to test it i tried playing it through TMT5 and it works so i think its a Lav Splitter issue (All i use is MediaBrowser and Lav Filters to bitstream all the audio).
But i have no idea why doing the same thing with the same disc, just using DD 5.1 instead as the audio track works perfectly....
I am going to ask Nev on the Doom forums, but i have to wait the 5 day registration period.........
Anyone have any other ideas?
mcnauge is offline
post #24 of 44 Old 07-12-2012, 01:19 PM
Quoted: 721 Post(s)
Liked: 449
You could ask the same Nev on this forum. I saw a post of his recently, just PM
post #25 of 44 Old 07-12-2012, 01:23 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
I have no problem with 7.1 HD Audio (dts anyhow, haven't used DD)
Sammy2 is offline
post #26 of 44 Old 07-12-2012, 02:53 PM
mcnauge's Avatar
I will see if i can PM Nev.
I can make and play any mkv using DD, DTS, DTS+HD or TrueHD (Transformers 1 is TrueHD 5.1 and works fine, Transformers 2 is DTS-HD and works fine) but the problem comes up with Transformers 3 which is the TrueHD 7.1....
Very odd...and frustrating, but ill use the 5.1 track until i get this sorted out...any other Blu-rays that people know of that are TrueHD 7.1?? and i will see if it works/fails with that one too.
mcnauge is offline
post #27 of 44 Old 07-12-2012, 03:40 PM
xfett's Avatar
Friday
Megamind
Mission: Impossible - Ghost Protocol
The Nightmare Before Christmas
Shrek
Shrek 2
Super 8 .....are all True Hd 7.1
Just to confirm Super 8 behaves the same as Dark of the Moon. Will only work with ffdshow for me.
xfett is offline
post #28 of 44 Old 07-12-2012, 03:49 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Super 8 played fine for me using MPC-HC, LAV and MadVR.
Sammy2 is offline
post #29 of 44 Old 07-12-2012, 05:14 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Not everyone wants to use MPC-HC
Andy_Steb is offline
post #30 of 44 Old 07-12-2012, 05:26 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
True and it shouldn't matter either as this is a splitter / codec issue.
Dropkick,Have you looked at thes in Graph Studio to see where the pins are?
What version of LAV are you using?
BTW, I haven't had problems with Ghost Protocal either.
Sammy2 is offline
Reply Home Theater Computers
