HTPC from Laptop i7 - AVS Forum | Home Theater Discussions And Reviews
Old 07-10-2012, 12:09 PM - Thread Starter
theknub's Avatar
So, I sent my computer in for service and "magically" there is some water damage on the inside. HP won't fix a design problem in their laptop. Luckily, I had a personal item policy with my ins co. and I will get a laptop replacement.
However, that leaves me with a laptop that has an i7 2720qm in it, fully functioning ram, etc. So, I'm looking to do a HTPC build with it.
So, I understand the chip uses a slightly different socket than a regular chip.
Here's what I'm looking at.
MB:
Jetway JNC9B http://www.newegg.com/Product/Product.aspx?Item=N82E16813153214
Ram:
Current 8 gigs
HD:
Current SSD
Graphics:
Onboard
Case:
iwill S197-H80 http://www.ecosmartpc.com/s197h80.html
PSU:
Not sure. Ideas? This type of build is new to me. Given that it is already a mobile processor, it's power draw should be less than a regular chip. I'm thinking some type of pico but I'm sure you all may have more experience in this arena.
Am I missing anything?
theknub is offline
Old 07-10-2012, 02:32 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So I take it the water damage didn't harm the CPU or RAM?
That looks like a decent build for re-using parts from a laptop otherwise the processor is probably over-kill.
You are missing a HDD or SDD.
Sammy2 is offline
Old 07-10-2012, 06:09 PM - Thread Starter
theknub's Avatar
Aside from a design flaw in the video switching, it works great. I actually just sent it in for other work less than a month ago (and they didn't fix this). So I'm thinking they made something up to keep from repairing it (read that they didn't actually break anything). Since I have the insurance policy, I just used it.
It does have a SSD which I noted in the original post. I do agree that the processor is overkill, but why not given the circumstance. Would have been nice to have had happen before I built my i5.
So, any thoughts on PSU?
theknub is offline
Old 07-12-2012, 08:22 AM
C17chief's Avatar
Liked: 24
Arent most all mobile CPU's soldered to the board and not socketed these days? Might want to check that out before digging to deep into repurposing your laptop processor. Could put a huge dampner on your plans.
C17chief is offline
Old 07-12-2012, 10:49 PM - Thread Starter
theknub's Avatar
not at all, mine is fully replaecable. you might be thinking of atom processors
theknub is offline
Old 07-13-2012, 12:37 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Originally Posted by http://ark.intel.com/products/50067/Intel-Core-i7-2720QM-Processor-(6M-Cache-up-to-3_30-GHz)
Sockets Supported FCBGA1224, FCPGA988
Originally Posted by http://www.newegg.com/Product/Product.aspx?Item=N82E16813153214
Socket G2 (rPGA 988B)
I'm not sure they are the same socket...
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 07-13-2012, 09:10 AM - Thread Starter
theknub's Avatar
two lines above:
37.5 x 37.5mm (rPGA988B); 31.0 x 24.0mm (BGA1224)
there are a lot of names and what not thrown around, especially for the mobile chips
theknub is offline
Old 07-13-2012, 11:18 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
olyteddy is offline
Old 10-15-2012, 11:16 PM - Thread Starter
theknub's Avatar
quick update, build went great and system works great. i think my SSD is having a few issues from time to time, but otherwise it's a great build.
theknub is offline
