HTPC Video Card Recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-14-2012, 06:52 AM - Thread Starter
scott750's Avatar
Quoted: 16 Post(s)
I think my EVGA GT430 video card isn't powerful enough in my Htpc to run my 64" plasma tv. Lately I've been having a problem while watching live tv or movies, the picture and sound will go completely off and the tv will isplay no signal, as if the Htpc is off. I have to reboot the computer to get video/audio working again.
I opened up the computer case and the heat sink on the video card was very hot to the touch. The little fan was turning at a moderate speed. I thought maybe the case airflow wasn't great, so I left the top cover off to see if that would help. After watching a movie the heat sink still felt very hot. And I can feel air flowing thru the case, so I think airflow is decent.
I downloaded GPU- Z and it's reporting the gpu temps at 65*C. That seems very high!
I've RMA'd this video card 2x in the past because the cooking fan on the video had stopped turnung, causing overheating issues.
So I'm wonder if I need a better graphics card? Or better cooling? Maybe a new case?
My Htpc setup:
64" Samsung Plasma P64D8000
Silverstone LC20B case
Core i5-3550 3.3gHz
Gigabyte z77x-ud3h
8GB DDR3-1600 G. SKILL Ripjaws X
EVGA GT430 DDR3 1GB
2x HVR- 2250 OTA tuner cards
Samsung 830 128GB SSD
1x WD Black Caviar 1TB
2x WD Black Caviar 640GB
1x WD Blue Caviar 640GB
Win 7 Home 64bit
Lite-On Bluray writer
2x Arctic Cooler 90mm fans - intake
2x Arctic Cooler 80mm fans - exhaust
Sent from my Thunderbolt using Tapatalk 2
scott750 is offline
post #2 of 9 Old 07-14-2012, 07:21 AM
DeanM's Avatar
My Htpc setup:
Core i5-3550 3.3gHz
Gigabyte z77x-ud3h
EVGA GT430 DDR3 1GB
Win 7 Home 64bit
Why not use onboard Intel HD2500 video, supported by CPU/motherboard?
joe531 likes this.
DeanM is offline
post #3 of 9 Old 07-14-2012, 08:47 AM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
I have an fanless Asus GT430 and it runs to my TV just fine, sounds like a bad video card. Top temp so far has been 56 degrees. Pretty much any integrated or even basic video card should be able to play 1080p no problem. I just had to add a video card because my HD3000 wouldn't play the mpeg4 channels on Cox and I like my DIYHD.
JackDiesel14 is offline
post #4 of 9 Old 07-14-2012, 10:23 AM - Thread Starter
scott750's Avatar
Quoted: 16 Post(s)
Will the Ivy Bridge 2500 IGP be able to handle mpeg2, bluray, and etc?
scott750 is offline
post #5 of 9 Old 07-14-2012, 10:28 AM
DeanM's Avatar
Yes.
The only thing I think there is trouble with is h264 cable channels (cablecard/Cox). Some people have trouble with 29/59 content (cablecard/HBO... others) -- I don't with my HD2000.
Looks like you are all OTA, so I was surpised you bothered with the discrete nvidia 430.
DeanM is offline
post #6 of 9 Old 07-14-2012, 12:03 PM - Thread Starter
scott750's Avatar
Quoted: 16 Post(s)
Originally Posted by DeanM View Post
Yes.
I originally bought the GT430 to update my old Htpc setup. It was a C2D E6420 and LGA775. I wanted to wait for ivy bridge before redoing the whole thing.
So I don't need to worry about H.264 content?
scott750 is offline
post #7 of 9 Old 07-14-2012, 12:18 PM - Thread Starter
scott750's Avatar
Quoted: 16 Post(s)
I'm thinking of swapping to the i5-3570k to get the hd4000 igp and selling the i5-3550. Would that handle everything I'm doing? I don't game on this computer.
scott750 is offline
post #8 of 9 Old 07-14-2012, 12:19 PM
DeanM's Avatar
Normal h.264 content works fine on my system (by normal I mean from BD rips and such). The h.264 issues are happening with cablecard content for those using HDHRp and Ceton tuners. Try it, you'll probably like it... and you'll get rid of another heat-source in your HTPC.
DeanM is offline
post #9 of 9 Old 07-14-2012, 12:49 PM
GreenEyez's Avatar
Run Furmark : http://www.ozone3d.net/benchmarks/fur/ with the stress test option, and see how hot the card goes. If it goes above 85 degrees, it`s not good. Usually GPUs have a max temp of about 85-90 degrees (Celsius)
GreenEyez is offline
Reply Home Theater Computers
