Windows 7 audio configuration - set speakers to full-range or not? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-17-2012, 12:49 PM - Thread Starter
robollama's Avatar
I'm trying to bitstream all my audio from MPC-HC and Reclock + Wasapi over HDMI to my receiver. Should I choose full-range speakers in the Windows 7 audio config or not? I don't want Windows messing with the audio and I can't tell which option is the right one for no interference.
robollama is offline
post #2 of 6 Old 07-17-2012, 01:39 PM
Selden Ball's Avatar
Quoted: 3492 Post(s)
Liked: 1763
"Full range" means "send all audio on this channel unchanged".
Selden
Selden Ball is offline
post #3 of 6 Old 07-17-2012, 02:00 PM
bryansj's Avatar
Quoted: 1419 Post(s)
Liked: 645
So if it is being bitstreamed I would assume the signal is being sent unchanged no matter what the setting is in the sound device setup.
bryansj is offline
post #4 of 6 Old 07-17-2012, 02:23 PM
Hamilcar Barca's Avatar
Generally, you're correct: The "full-range" vs "satellite" setting is for analog
output. Now, you'll have to make that choice at your receiver (or whatever
decodes your bitstream'd audio.)
Hamilcar Barca is offline
post #5 of 6 Old 07-17-2012, 02:25 PM - Thread Starter
robollama's Avatar
Yeah but this is in the windows config settings for my HDMI connection? Not analog
post #6 of 6 Old 07-17-2012, 06:22 PM
Flash676's Avatar
Quoted: 31 Post(s)
I'd leave them all full-range so that your receiver is the only component handling the bass management duties.
Flash676 is offline
Reply Home Theater Computers
