PCH-A210 - Any reason I shouldn't convert this to a boat anchor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-19-2012, 02:10 PM - Thread Starter
shuasha's Avatar
I bought this about a year ago to stream BD-ISO's from my media server to my upstairs. When connected via wired 100 Mbit and 1Gbit/sec, it's stutters constantly.
I don't rip DVD's, so this thing is pretty much useless to me. Any recommendations on a replacement with a working network interface and buffering system?
shuasha is offline
post #2 of 10 Old 07-20-2012, 05:52 AM
bimmerfreak0's Avatar
Quoted: 21 Post(s)
Liked: 24
Have you checked your router settings. First, place the unit on a stable mac-address that doesn't constantly switch. You could also look to see if jumbo frames are supported. Have you tried using a wireless to wired adapter for the popcorn box???
bimmerfreak0 is offline
post #3 of 10 Old 07-20-2012, 10:32 AM
Davecraze's Avatar
Quoted: 180 Post(s)
Liked: 60
I have three a210s connected via wired 100 Mbit connections and have never had any stutter issue, even with BD-ISOs. This really does sound like a network/router issue to me.
Davecraze is offline
post #4 of 10 Old 07-20-2012, 12:24 PM
juaniquillo's Avatar
I have the A-200. For 2 years I had no issues at all, until one day started to stutter. I troubleshooted my server and network for hours and nothing. Then I checked the popcorn, nothing.
At one point I changed the video output option from 1080p24 to 1080p60... problem fixed. Finally I changed back to 1080p24, not a single issue.
Who knows, it may be an unknown bug. You may try this fix.
EDIT: Try using the 100Mb connection, save changes, this is more than enough to stream blu-ray isos
juaniquillo is offline
post #5 of 10 Old 07-20-2012, 01:57 PM
bomberjim's Avatar
Quoted: 13 Post(s)
I still use an old Popcorn A110 without problems, I agree it sounds like a network problem. Try loading a movie on an external hard drive and play it. It's not definitive, but if it plays fine, it pretty much confirms network problems.
bomberjim is offline
post #6 of 10 Old 07-30-2012, 12:58 PM - Thread Starter
shuasha's Avatar
Somehow I missed the replies.
I have no network issues, I'm using a good gigabit core switches all hard wired with CAT6. I can stream with zero problems on the same hardware to my HTPC and copy files at 300+ Mbits/sec across the network.
shuasha is offline
post #7 of 10 Old 01-19-2014, 06:34 PM
mendes9's Avatar
Yep same network issues as you, 20 years IT experience. I tried expensive switches etc. its a POS. my a300 is flawless
Save Your Frequent Flyer Miles !! Barber's jobs are also being exported to China, you will have to fly to China now for a hair cut.
mendes9 is offline
post #8 of 10 Old 01-20-2014, 02:37 AM
Tedd's Avatar
Quoted: 1075 Post(s)
Liked: 410
Could this be a heat related issue? How's the heat sink on the cpu? Correctly seated and there's a proper
amount of thermal paste? Might be worth a look before boat anchor time...
Tedd is online now
post #9 of 10 Old 01-20-2014, 07:39 AM
Fredrik's Avatar
Quoted: 29 Post(s)
Liked: 29
Don't use a PCH (had an A100) anymore but in the past I had similar issues but the problem was with my old NAS-box.
The NAS-box just couldn't cope with playing BD movies while at the same time other computers accessed it.
I guess the best way to test it (as already suggested) is to connect a USB-drive directly to the PCH and see if it still stutters.
Then at least you've ruled out the network and NAS-box if it still stutters.
21:st century Karate Kid......Logon, Logoff, Logon, Logoff..
Fredrik is offline
post #10 of 10 Old 01-21-2014, 12:08 AM
leebo's Avatar
Quoted: 541 Post(s)
Liked: 308
Do you even own a boat?
Sent from my Nexus 7
leebo is offline
Reply Home Theater Computers
