More RAM or Faster RAM? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-20-2012, 01:52 PM - Thread Starter
Antripodean's Avatar
I'm building my new HTPC and need to decide on RAM. For the music processing software I need 8 GB RAM. I have a dual core motherboard, ASROCK Extreme6, and my choices are:
4 x 4G DDR3 1600
2 x 8G DDR3 1600
2 x 4G DDR3 2400
What is the best way to go? Prices are similar for these options. For the music software low latency is critical as it is processing, XO and EQ, real time
explore the music
Antripodean is offline
post #2 of 10 Old 07-20-2012, 03:39 PM
walford's Avatar
If you have a family of 4 you do not need and 8 passenger minivan but you may want a larger engine in the 4-5 passenger vehicle you get instead. Also the faster memory is the best choice.
walford is offline
post #3 of 10 Old 07-20-2012, 03:53 PM
bwdutton's Avatar
http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3/8
Faster memory might be a bit faster in some applications, however, if you run out of memory then having more slower memory will be many times faster. I think it'll depend on how much memory your music application wants or needs.
Take my advice with a grain of salt, I'm a family of 4 with a mini van :P
bwdutton is offline
post #4 of 10 Old 07-20-2012, 04:01 PM
CSMR's Avatar
What music software needs 8GB RAM.
RAM speed is measured in MHz, i.e. fractions of a microsecond. It is not going to contribute to latency, which is measured in milliseconds.
CSMR is offline
post #5 of 10 Old 07-20-2012, 04:25 PM - Thread Starter
Good article, thanks! It seems 1600MHz is the sweetspot for RAM speed/value
Ultimate Equalizer needs 4GB and I will also be playing movies at the same time, hence 8GB needed. Thanks for the explanation on RAM speed
Thanks also for your reply Walford
explore the music
post #6 of 10 Old 07-20-2012, 04:40 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
don't you need to overclock to go over 1600?
Andy_Steb is offline
post #7 of 10 Old 07-20-2012, 05:54 PM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
How much do timings improve memory performance? Like 8-8-8-24 in comparison to 7-7-7-24.
JackDiesel14 is offline
post #8 of 10 Old 07-20-2012, 08:32 PM
Diverge's Avatar
The only way your gonna notice differences in timing for ram is benchmarks. Other then that you're really just wasting your money (IMO). Buy more ram, it's more useful.
Diverge is offline
post #9 of 10 Old 07-20-2012, 08:37 PM
dksc318's Avatar
That's one clock cycle or about 1nSec for 1000Mhz clock. CAS latency happens once every column address strobe. So you saved 1nsec assuming same clock rate between 8-8-8-24 and 7-7-7-24 after the initial start. It is a very small savings in actuality. Google's "blink of an eye' response is 500mSec, or 500 million times longer.
For CL=8 that's 8nSec. Twenty years ago CAC (column address access) was about 15nSec. So things haven't improved that much on initial access. But once the memory page gets rolling, you get subsequent data much faster, something like twenty times faster.
dksc318 is offline
post #10 of 10 Old 07-21-2012, 03:19 PM
CSMR's Avatar
Try out both applications to see memory use in the task manager. I expect that they both use small amounts of RAM. My guess is for both applications combined between 50 and 300MB.
So: speed does not matter, and neither does amount of memory. Get at least 4GB of reliable (brand name) RAM.
CSMR is offline
Reply Home Theater Computers
