Is the mSATA port on the BOXDH77DF SATA-II or SATA-III? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-21-2012, 09:57 AM - Thread Starter
Solderbot's Avatar
I want to do a build with the BOXDH77DF with a mSATA SSD as the only disk (in a Morex 557 case with a PicoPSU). I haven't been able to figure out what speed that mSATA slot runs at. Anybody know?
Solderbot is offline
post #2 of 7 Old 07-21-2012, 11:52 AM
LexInVA's Avatar
Quoted: 520 Post(s)
Liked: 218
Unfortunately, there is no literature from Intel that says the board is mSATA compatible though it does clearly have a slot for a miniPCIe card. Assuming it is compatible, the controller is compliant with the latest SATA standards so you should be fine with whatever you throw in there if it does in fact support mSATA.
LexInVA is offline
post #3 of 7 Old 07-21-2012, 01:55 PM - Thread Starter
Solderbot's Avatar
Thanks for the feedback. There is plenty of literature from Intel (here and here) saying that it supports mSATA, just not what speed. As long as a SATA-III disk works I'll be happy.
I know it should work with mSATA from the builds I've found posted online. The Anandtech one is probably the most notable.
post #4 of 7 Old 07-21-2012, 03:02 PM
Gorath's Avatar
Block diagram on page 16
http://downloadmirror.intel.com/20950/eng/DH77DF_TechProdSpec01.pdf
mSATA connector connected (1) SATA 3.0Gb/s
eSATA connector connected (1) SATA 3.0Gb/s
-plus-
(2) SATA 3.0Gb/s connectors
(2) SATA 6.0Gb/s connectors
That fills out the 4 SATA II and 2 SATA III available on the H77 chip. There doesn't appear to be any shared connectors.
Gorath is offline
post #5 of 7 Old 07-21-2012, 09:17 PM - Thread Starter
Solderbot's Avatar
-plus-
Solid info! Thanks, Gorath.
post #6 of 7 Old 07-21-2012, 09:35 PM
dksc318's Avatar
.... There doesn't appear to be any shared connectors.
The mSATA is shared with miniPCIe.
dksc318 is offline
post #7 of 7 Old 07-23-2012, 07:31 PM
jsw98765's Avatar
I have this board, in one of my htpcs paired with an i3 2120t. love the board, hate the pcie/msata port. I could not get anything pcie to recognize (2 wireless cards and a tv tuner tested) in it. The port in the bios is listed as msata and shows in with the rest of the sata ports. Hopefully your results with msata are better then mine.
jsw98765 is offline
Reply Home Theater Computers
